Mike Banon has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/52655 )
Change subject: asus/am1i-a: create the correct MP tables ......................................................................
Based on CB:48605 and our discussion at CB:38313 (which dropped the old incorrect MP tables for many boards including asus/am1i-a).
Signed-off-by: Mike Banon mikebdp2@gmail.com Change-Id: I174e09950b83ecf381c9de8fd7fefa017138a000 --- M src/mainboard/asus/am1i-a/Kconfig M src/mainboard/asus/am1i-a/mainboard.c A src/mainboard/asus/am1i-a/mptable.c 3 files changed, 207 insertions(+), 47 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/55/52655/1
diff --git a/src/mainboard/asus/am1i-a/Kconfig b/src/mainboard/asus/am1i-a/Kconfig index 78948b2..172d808 100644 --- a/src/mainboard/asus/am1i-a/Kconfig +++ b/src/mainboard/asus/am1i-a/Kconfig @@ -10,6 +10,7 @@ select USE_OPTION_TABLE select HAVE_CMOS_DEFAULT select HAVE_PIRQ_TABLE + select HAVE_MP_TABLE select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES select NORTHBRIDGE_AMD_AGESA_FAMILY16_KB diff --git a/src/mainboard/asus/am1i-a/mainboard.c b/src/mainboard/asus/am1i-a/mainboard.c index e105910..4793897 100644 --- a/src/mainboard/asus/am1i-a/mainboard.c +++ b/src/mainboard/asus/am1i-a/mainboard.c @@ -7,35 +7,8 @@ #include <southbridge/amd/common/amd_pci_util.h> #include <northbridge/amd/agesa/family16kb/pci_devs.h>
-static const u8 mainboard_picr_data[FCH_INT_TABLE_SIZE] = { - /* INTA# - INTH# */ - [0x00] = 0x03,0x04,0x05,0x07,0x1F,0x1F,0x1F,0x1F, - /* Misc-nil,0,1,2, INT from Serial irq */ - [0x08] = 0x5A,0xF1,0x00,0x00,0x1F,0x1F,0x1F,0x1F, - /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerMon, SD */ - [0x10] = 0x1F,0x1F,0x1F,0x03,0x1F,0x1F,0x1F,0x1F, - /* IMC INT0 - 5 */ - [0x20] = 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, - /* USB Devs 18/19/22 INTA-B */ - [0x30] = 0x05,0x04,0x05,0x04,0x05,0x04,0x1F,0x1F, - /* RSVD, SATA */ - [0x40] = 0x1F, 0x07 -}; - -static const u8 mainboard_intr_data[FCH_INT_TABLE_SIZE] = { - /* INTA# - INTH# */ - [0x00] = 0x10,0x11,0x12,0x13,0x1F,0x1F,0x1F,0x1F, - /* Misc-nil,0,1,2, INT from Serial irq */ - [0x08] = 0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F, - /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerMon, SD */ - [0x10] = 0x09,0x1F,0x1F,0x10,0x1F,0x1F,0x1F,0x1F, - /* IMC INT0 - 5 */ - [0x20] = 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, - /* USB Devs 18/19/22 INTA-B */ - [0x30] = 0x12,0x11,0x12,0x11,0x12,0x11,0x1F,0x1F, - /* RSVD, SATA */ - [0x40] = 0x1F, 0x13 -}; +extern const u8 mainboard_picr_data[FCH_INT_TABLE_SIZE]; +extern const u8 mainboard_intr_data[FCH_INT_TABLE_SIZE];
/* * This table defines the index into the picr/intr_data @@ -45,23 +18,23 @@ * PCI_INTR register 0xC00/0xC01. This index will define * the interrupt that it should use. Putting PIRQ_A into * the PIN A index for a device will tell that device to - * use PIC IRQ 10 if it uses PIN A for its hardware INT. + * use PIC IRQ picr_data[PIRQ_A] if it uses PIN A for its hardware INT. */ static const struct pirq_struct mainboard_pirq_data[] = { - /* {PCI_devfn, {PIN A, PIN B, PIN C, PIN D}}, */ - {GFX_DEVFN, {PIRQ_A, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* VGA: 01.0 */ - {ACTL_DEVFN,{PIRQ_NC, PIRQ_B, PIRQ_NC, PIRQ_NC}}, /* Audio: 01.1 */ - {NB_PCIE_PORT1_DEVFN, {PIRQ_A, PIRQ_B, PIRQ_C, PIRQ_D}}, /* x4 PCIe: 02.1 */ - {NB_PCIE_PORT5_DEVFN, {PIRQ_B, PIRQ_C, PIRQ_D, PIRQ_A}}, /* Edge: 02.5 */ - {XHCI_DEVFN, {PIRQ_C, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* XHCI: 10.0 */ - {SATA_DEVFN, {PIRQ_SATA, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* SATA: 11.0 */ - {OHCI1_DEVFN, {PIRQ_OHCI1, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI1: 12.0 */ - {EHCI1_DEVFN, {PIRQ_NC, PIRQ_EHCI1, PIRQ_NC, PIRQ_NC}}, /* EHCI1: 12.2 */ - {OHCI2_DEVFN, {PIRQ_OHCI2, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI2: 13.0 */ - {EHCI2_DEVFN, {PIRQ_NC, PIRQ_EHCI2, PIRQ_NC, PIRQ_NC}}, /* EHCI2: 13.2 */ - {OHCI3_DEVFN, {PIRQ_OHCI3, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI3: 16.0 */ - {EHCI3_DEVFN, {PIRQ_NC, PIRQ_EHCI3, PIRQ_NC, PIRQ_NC}}, /* EHCI3: 16.2 */ - {HDA_DEVFN, {PIRQ_HDA, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* HDA: 14.2 */ + /* {PCI_devfn, {PIN A, PIN B, PIN C, PIN D} }, */ + {GFX_DEVFN, {PIRQ_A, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* APU Integrated Graphics: 0:01.00 - IRQ 3 */ + {ACTL_DEVFN, {PIRQ_NC, PIRQ_B, PIRQ_NC, PIRQ_NC} }, /* APU HDMI Audio Controller: 0:01.01 - IRQ 4 */ + {NB_PCIE_PORT1_DEVFN, {PIRQ_A, PIRQ_B, PIRQ_C, PIRQ_D} }, /* PCIe GPP to dGPU 1:00.00: 0:02.01 - IRQ 3 */ + {NB_PCIE_PORT5_DEVFN, {PIRQ_B, PIRQ_C, PIRQ_D, PIRQ_A} }, /* PCIe GPP to Eth 2:00.00: 0:02.05 - IRQ 4 */ + {XHCI_DEVFN, {PIRQ_C, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* USB XHCI: 0:10.00 - IRQ 5 */ + {SATA_DEVFN, {PIRQ_SATA, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* SATA: 0:11.00 - IRQ 7 */ + {OHCI1_DEVFN, {PIRQ_OHCI1, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* USB OHCI1: 0:12.00 - IRQ 5 */ + {EHCI1_DEVFN, {PIRQ_NC, PIRQ_EHCI1, PIRQ_NC, PIRQ_NC} }, /* USB EHCI1: 0:12.02 - IRQ 4 */ + {OHCI2_DEVFN, {PIRQ_OHCI2, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* USB OHCI2: 0:13.00 - IRQ 5 */ + {EHCI2_DEVFN, {PIRQ_NC, PIRQ_EHCI2, PIRQ_NC, PIRQ_NC} }, /* USB EHCI2: 0:13.02 - IRQ 4 */ + {OHCI3_DEVFN, {PIRQ_OHCI3, PIRQ_NC, PIRQ_NC, PIRQ_NC} }, /* USB OHCI3: 0:16.00 - IRQ 5 */ + {EHCI3_DEVFN, {PIRQ_NC, PIRQ_EHCI3, PIRQ_NC, PIRQ_NC} }, /* USB EHCI3: 0:16.02 - IRQ 4 */ + {HDA_DEVFN, {PIRQ_HDA, PIRQ_NC, PIRQ_NC, PIRQ_NC} } /* Southbridge HD Audio: 0:14.02 - IRQ 3 */ };
/* PIRQ Setup */ @@ -73,9 +46,7 @@ picr_data_ptr = mainboard_picr_data; }
-/********************************************** - * enable the dedicated function in mainboard. - **********************************************/ +/* dedicated "enable" function */ static void mainboard_enable(struct device *dev) { /* Initialize the PIRQ data structures for consumption */ diff --git a/src/mainboard/asus/am1i-a/mptable.c b/src/mainboard/asus/am1i-a/mptable.c new file mode 100644 index 0000000..736af64 --- /dev/null +++ b/src/mainboard/asus/am1i-a/mptable.c @@ -0,0 +1,188 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <arch/smp/mpspec.h> +#include <arch/ioapic.h> +#include <stdint.h> +#include <string.h> +#include <southbridge/amd/common/amd_pci_util.h> +#include <drivers/generic/ioapic/chip.h> + +/* + * Based on 48751_16h_bkdg.pdf. Acronyms: + * + * SCI - System Controller Interrupt, + * SMBUS - System Management Bus, + * ASF - Advanced Synchronization Facility, + * HDA - HD Audio, + * FC - Flash Controller, + * GEC - Gigabit Ethernet Controller, + * PerMon - Performance Monitor, + * SD - SD Flash Controller, + * IMC - Integrated Memory Controller, + * RSVD - Reserved. + */ + +const u8 mainboard_picr_data[FCH_INT_TABLE_SIZE] = { + /* INTA# - INTH# */ + [0x00] = 0x03, 0x04, 0x05, 0x07, 0x1F, 0x1F, 0x1F, 0x1F, + /* Misc-nil,0,1,2, INTA-INTD from Serial irq */ + [0x08] = 0xAA, 0xF1, 0x00, 0x00, 0x1F, 0x1F, 0x1F, 0x1F, + /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerMon, SD */ + [0x10] = 0x09, 0x1F, 0x1F, 0x03, 0x1F, 0x1F, 0x1F, 0x1F, + /* IMC INT0-INT5 */ + [0x20] = 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, + /* USB Devs: 18 INTA#,B#; 19 INTA#,B#; 22 INTA#,B# */ + [0x30] = 0x05, 0x04, 0x05, 0x04, 0x05, 0x04, + /* RSVD, SATA */ + [0x40] = 0x1F, 0x07 +}; + +const u8 mainboard_intr_data[FCH_INT_TABLE_SIZE] = { + /* INTA# - INTH# */ + [0x00] = 0x10, 0x11, 0x12, 0x13, 0x1F, 0x1F, 0x1F, 0x1F, + /* Misc-nil,0,1,2, INTA-INTD from Serial irq */ + [0x08] = 0x00, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x1F, 0x1F, + /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerMon, SD */ + [0x10] = 0x09, 0x1F, 0x1F, 0x10, 0x1F, 0x1F, 0x1F, 0x1F, + /* IMC INT0-INT5 */ + [0x20] = 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, + /* USB Devs: 18 INTA#,B#; 19 INTA#,B#; 22 INTA#,B# */ + [0x30] = 0x12, 0x11, 0x12, 0x11, 0x12, 0x11, + /* RSVD, SATA */ + [0x40] = 0x1F, 0x13 +}; + +static void smp_add_mpc_entry(struct mp_config_table *mc, unsigned int length) +{ + mc->mpc_length += length; + mc->mpc_entry_count++; +} + +static void my_smp_write_bus(struct mp_config_table *mc, + unsigned char id, const char *bustype) +{ + struct mpc_config_bus *mpc; + mpc = smp_next_mpc_entry(mc); + memset(mpc, '\0', sizeof(*mpc)); + mpc->mpc_type = MP_BUS; + mpc->mpc_busid = id; + memcpy(mpc->mpc_bustype, bustype, sizeof(mpc->mpc_bustype)); + smp_add_mpc_entry(mc, sizeof(*mpc)); +} + +static void *smp_write_config_table(void *v) +{ + struct mp_config_table *mc; + int bus_isa; + + /* + * By the time this function gets called, the IOAPIC registers + * have been written so they can be read to get the correct + * APIC ID and Version + */ + u8 ioapic_id = (io_apic_read(VIO_APIC_VADDR, 0x00) >> 24); + u8 ioapic_ver = (io_apic_read(VIO_APIC_VADDR, 0x01) & 0xFF); + + /* Initialize the MP_Table */ + mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); + + mptable_init(mc, LOCAL_APIC_ADDR); + memcpy(mc->mpc_oem, "AMD ", 8); + + /* + * Type 0: Processor Entries: + * LAPIC ID, LAPIC Version, CPU Flags:EN/BP, + * CPU Signature (Stepping, Model, Family), + * Feature Flags + */ + smp_write_processors(mc); + + /* + * Type 1: Bus Entries: + * Bus ID, Bus Type + */ + // mptable_write_buses(mc, NULL, &bus_isa); + my_smp_write_bus(mc, 0, "PCI "); + my_smp_write_bus(mc, 1, "PCI "); + bus_isa = 0x02; + my_smp_write_bus(mc, bus_isa, "ISA "); + + /* + * Type 2: I/O APICs: + * APIC ID, Version, APIC Flags:EN, Address + */ + smp_write_ioapic(mc, ioapic_id, ioapic_ver, VIO_APIC_VADDR); + + /* + * Type 3: I/O Interrupt Table Entries: + * Int Type, Int Polarity, Int Level, Source Bus ID, + * Source Bus IRQ, Dest APIC ID, Dest PIN# + */ + mptable_add_isa_interrupts(mc, bus_isa, ioapic_id, 0); + + /* PCI interrupts are level triggered, and are + * associated with a specific bus/device/function tuple. + */ +#define PCI_INT(bus, dev, fn, pin) \ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, (bus), (((dev)<<2)|(fn)), ioapic_id, (pin)) + + /* APU Integrated Graphics: 0:01.00 - IRQ 3 */ + PCI_INT(0x0, 0x01, 0x0, intr_data_ptr[PIRQ_A]); + /* APU HDMI Audio Controller: 0:01.01 - IRQ 4 */ + PCI_INT(0x0, 0x01, 0x1, intr_data_ptr[PIRQ_B]); + + /* PCIe GPP Ports */ + /* PCIe GPP to dGPU 1:00.00: 0:02.01 - IRQ 3 */ + PCI_INT(0x0, 0x02, 0x1, intr_data_ptr[PIRQ_A]); + /* PCIe GPP to Eth 2:00.00: 0:02.05 - IRQ 4 */ + PCI_INT(0x0, 0x02, 0x5, intr_data_ptr[PIRQ_B]); + + /* USB XHCI: 0:10.00 - IRQ 5 */ + PCI_INT(0x0, 0x10, 0x0, intr_data_ptr[PIRQ_C]); + /* SATA: 0:11.00 - IRQ 7 */ + PCI_INT(0x0, 0x11, 0x0, intr_data_ptr[PIRQ_SATA]); + /* USB OHCI1: 0:12.00 - IRQ 5 */ + PCI_INT(0x0, 0x12, 0x0, intr_data_ptr[PIRQ_OHCI1]); + /* USB EHCI1: 0:12.02 - IRQ 4 */ + PCI_INT(0x0, 0x12, 0x2, intr_data_ptr[PIRQ_EHCI1]); + /* USB OHCI2: 0:13.00 - IRQ 5 */ + PCI_INT(0x0, 0x13, 0x0, intr_data_ptr[PIRQ_OHCI2]); + /* USB EHCI2: 0:13.02 - IRQ 4 */ + PCI_INT(0x0, 0x13, 0x2, intr_data_ptr[PIRQ_EHCI2]); + /* USB OHCI3: 0:16.00 - IRQ 5 */ + PCI_INT(0x0, 0x16, 0x0, intr_data_ptr[PIRQ_OHCI3]); + /* USB EHCI3: 0:16.02 - IRQ 4 */ + PCI_INT(0x0, 0x16, 0x2, intr_data_ptr[PIRQ_EHCI3]); + /* Southbridge HD Audio: 0:14.02 - IRQ 3 */ + PCI_INT(0x0, 0x14, 0x2, intr_data_ptr[PIRQ_HDA]); + + /* Discrete Graphics (dGPU) 1:00.00 behind a 0:02.01 PCIe GPP - IRQ 3 */ + PCI_INT(0x1, 0x0, 0x0, intr_data_ptr[PIRQ_A]); + PCI_INT(0x1, 0x0, 0x1, intr_data_ptr[PIRQ_B]); + PCI_INT(0x1, 0x0, 0x2, intr_data_ptr[PIRQ_C]); + PCI_INT(0x1, 0x0, 0x3, intr_data_ptr[PIRQ_D]); + + /* Onboard Ethernet (Eth) 2:00.00 behind a 0:02.05 PCIe GPP - IRQ 4 */ + PCI_INT(0x2, 0x0, 0x0, intr_data_ptr[PIRQ_B]); + PCI_INT(0x2, 0x0, 0x1, intr_data_ptr[PIRQ_C]); + PCI_INT(0x2, 0x0, 0x2, intr_data_ptr[PIRQ_D]); + PCI_INT(0x2, 0x0, 0x3, intr_data_ptr[PIRQ_A]); + + /*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ +#define IO_LOCAL_INT(type, intr, apicid, pin) \ + smp_write_lintsrc(mc, (type), MP_IRQ_TRIGGER_EDGE | MP_IRQ_POLARITY_HIGH, bus_isa, (intr), (apicid), (pin)) + + IO_LOCAL_INT(mp_ExtINT, 0x0, MP_APIC_ALL, 0x0); + IO_LOCAL_INT(mp_NMI, 0x0, MP_APIC_ALL, 0x1); + /* There is no extension information... */ + + /* Compute the checksums */ + return mptable_finalize(mc); +} + +unsigned long write_smp_table(unsigned long addr) +{ + void *v; + v = smp_write_floating_table(addr, 0); + return (unsigned long)smp_write_config_table(v); +}
