Attention is currently required from: Benjamin Doron, Angel Pons. Benjamin Doron has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40625 )
Change subject: [WIP] skl: PEG for Optimus ......................................................................
Patch Set 15:
Commit Message:
https://review.coreboot.org/c/coreboot/+/40625/comment/d0f5e877_56a55431 PS9, Line 7: PEG
PEG usually refers to the PCIe root port that is directly attached to the CPU (PCI device 00:01.0). If this is actually for the PCIe root ports on the PCH, I would be against calling it "PEG" to avoid confusion.
What would you prefer? Note that this attempts to handle both situations, although I cannot test CPU PEG.
Note that SKL-U, SKL-Y and friends (e.g. KBL) do not have the PEG PCI devices (00:01.0) at all.
(FWIW, note that PEG can be bifurcated, in which case additional PCI functions 1 and 2 can be present for PEG)
Would a dGPU have function 2? I am aware that an HDA controller at function 1 is sometimes present.
