Eric Lai has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84925?usp=email )
Change subject: mb/google/nissa/var/glassway: Add initial LTE related settings ......................................................................
1. Add DB_1C_LTE 4 on DB_USB fw_config. 2. Implement WWAN power sequencing. 3. Disable LTE-related GPIOs based on fw_config. 4. Add I2C SX9324 (P-sensor) support. Refer Schematic file: CA31AC_R10_MB_SUB_240903A_P.pdf
BUG=b:374666995 BRANCH=firmware-nissa-15217.B TEST=emerge-nissa coreboot chromeos-bootimage Confirm the device node i2c-STH9324:00 created correctly, and command for # i2cdump -f -y 11 0x28 is workable.
Change-Id: Ida56ff338d82f48aef419a65830a3380c83123d5 Signed-off-by: Daniel Peng Daniel_Peng@pegatron.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84925 Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Eric Lai ericllai@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Paul Menzel paulepanter@mailbox.org --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/variants/glassway/fw_config.c M src/mainboard/google/brya/variants/glassway/include/variant/gpio.h M src/mainboard/google/brya/variants/glassway/overridetree.cb 4 files changed, 117 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Paul Menzel: Looks good to me, but someone else must approve Eric Lai: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 20207f4..fadb977 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -278,7 +278,10 @@ select CHROMEOS_WIFI_SAR if CHROMEOS select DRIVERS_GENERIC_GPIO_KEYS select DRIVERS_GENESYSLOGIC_GL9750 + select DRIVERS_I2C_SX9324 + select DRIVERS_I2C_SX9324_SUPPORT_LEGACY_LINUX_DRIVER select EC_GOOGLE_CHROMEEC_INCLUDE_SSFC_IN_FW_CONFIG + select HAVE_WWAN_POWER_SEQUENCE select INTEL_GMA_HAVE_VBT
config BOARD_GOOGLE_GOTHRAX diff --git a/src/mainboard/google/brya/variants/glassway/fw_config.c b/src/mainboard/google/brya/variants/glassway/fw_config.c index b4dfc50..3cca3fe 100644 --- a/src/mainboard/google/brya/variants/glassway/fw_config.c +++ b/src/mainboard/google/brya/variants/glassway/fw_config.c @@ -5,6 +5,19 @@ #include <console/console.h> #include <fw_config.h>
+static const struct pad_config lte_disable_pads[] = { + /* A8 : WWAN_RF_DISABLE_ODL */ + PAD_NC(GPP_A8, NONE), + /* D6 : WWAN_EN */ + PAD_NC(GPP_D6, NONE), + /* F12 : WWAN_RST_L */ + PAD_NC_LOCK(GPP_F12, NONE, LOCK_CONFIG), + /* H19 : SOC_I2C_SUB_INT_ODL */ + PAD_NC(GPP_H19, NONE), + /* H23 : WWAN_SAR_DETECT_ODL */ + PAD_NC(GPP_H23, NONE), +}; + static const struct pad_config stylus_disable_pads[] = { /* F13 : SOC_PEN_DETECT_R_ODL */ PAD_NC_LOCK(GPP_F13, NONE, LOCK_CONFIG), @@ -14,6 +27,12 @@
void fw_config_gpio_padbased_override(struct pad_config *padbased_table) { + if (!fw_config_probe(FW_CONFIG(DB_USB, DB_1C_LTE))) { + printk(BIOS_INFO, "Disable LTE-related GPIO pins on Glassway serial projects.\n"); + gpio_padbased_override(padbased_table, lte_disable_pads, + ARRAY_SIZE(lte_disable_pads)); + } + if (fw_config_probe(FW_CONFIG(STYLUS, STYLUS_ABSENT))) { printk(BIOS_INFO, "Disable Stylus GPIO pins.\n"); gpio_padbased_override(padbased_table, stylus_disable_pads, diff --git a/src/mainboard/google/brya/variants/glassway/include/variant/gpio.h b/src/mainboard/google/brya/variants/glassway/include/variant/gpio.h index c4fe342..c96b01f 100644 --- a/src/mainboard/google/brya/variants/glassway/include/variant/gpio.h +++ b/src/mainboard/google/brya/variants/glassway/include/variant/gpio.h @@ -5,4 +5,8 @@
#include <baseboard/gpio.h>
+#define WWAN_FCPO GPP_D6 +#define WWAN_RST GPP_F12 +#define T2_OFF_MS 20 + #endif diff --git a/src/mainboard/google/brya/variants/glassway/overridetree.cb b/src/mainboard/google/brya/variants/glassway/overridetree.cb index 85c08db..b8751c7 100644 --- a/src/mainboard/google/brya/variants/glassway/overridetree.cb +++ b/src/mainboard/google/brya/variants/glassway/overridetree.cb @@ -8,10 +8,11 @@ option AUDIO_ALC5650_ALC5650 1 end field DB_USB 5 7 - option DB_NONE 0 - option DB_1C 1 - option DB_1A 2 - option DB_1C_1A 3 + option DB_NONE 0 + option DB_1C 1 + option DB_1A 2 + option DB_1C_1A 3 + option DB_1C_LTE 4 end field SD_CARD 8 option SD_ABSENT 0 @@ -426,6 +427,78 @@ end end end #I2C1 + device ref i2c2 on + chip drivers/i2c/sx9324 + register "desc" = ""SAR Proximity Sensor"" + register "irq" = "ACPI_IRQ_LEVEL_LOW(GPP_H19_IRQ)" + register "speed" = "I2C_SPEED_FAST" + register "uid" = "1" + register "reg_gnrl_ctrl0" = "0x16" + register "reg_gnrl_ctrl1" = "0x21" + register "reg_afe_ctrl0" = "0x20" + register "reg_afe_ctrl3" = "0x00" + register "reg_afe_ctrl4" = "0x46" + register "reg_afe_ctrl6" = "0x00" + register "reg_afe_ctrl7" = "0x46" + register "reg_afe_ph0" = "0x3d" + register "reg_afe_ph1" = "0x1b" + register "reg_afe_ph2" = "0x1f" + register "reg_afe_ph3" = "0x3d" + register "reg_afe_ctrl8" = "0x12" + register "reg_afe_ctrl9" = "0x08" + register "reg_prox_ctrl0" = "0x0b" + register "reg_prox_ctrl1" = "0x0b" + register "reg_prox_ctrl2" = "0x20" + register "reg_prox_ctrl3" = "0x20" + register "reg_prox_ctrl4" = "0x0c" + register "reg_prox_ctrl5" = "0x00" + register "reg_prox_ctrl6" = "0x20" + register "reg_prox_ctrl7" = "0xc0" + register "reg_adv_ctrl0" = "0x00" + register "reg_adv_ctrl1" = "0x00" + register "reg_adv_ctrl2" = "0x00" + register "reg_adv_ctrl3" = "0x00" + register "reg_adv_ctrl4" = "0x00" + register "reg_adv_ctrl5" = "0x05" + register "reg_adv_ctrl6" = "0x00" + register "reg_adv_ctrl7" = "0x00" + register "reg_adv_ctrl8" = "0x00" + register "reg_adv_ctrl9" = "0x00" + register "reg_adv_ctrl10" = "0x00" + register "reg_adv_ctrl11" = "0x00" + register "reg_adv_ctrl12" = "0x00" + register "reg_adv_ctrl13" = "0x00" + register "reg_adv_ctrl14" = "0x80" + register "reg_adv_ctrl15" = "0x0c" + register "reg_adv_ctrl16" = "0x04" + register "reg_adv_ctrl17" = "0x70" + register "reg_adv_ctrl18" = "0x20" + register "reg_adv_ctrl19" = "0x00" + register "reg_adv_ctrl20" = "0x00" + register "reg_irq_msk" = "0x60" + register "reg_irq_cfg0" = "0x00" + register "reg_irq_cfg1" = "0x80" + register "reg_irq_cfg2" = "0x00" + + register "ph0_pin" = "{1, 3, 3}" + register "ph1_pin" = "{3, 2, 1}" + register "ph2_pin" = "{3, 3, 1}" + register "ph3_pin" = "{1, 3, 3}" + register "ph01_resolution" = "512" + register "ph23_resolution" = "512" + register "startup_sensor" = "1" + register "ph01_proxraw_strength" = "3" + register "ph23_proxraw_strength" = "3" + register "avg_pos_strength" = "256" + register "cs_idle_sleep" = ""gnd"" + register "int_comp_resistor" = ""lowest"" + register "input_precharge_resistor_ohms" = "4000" + register "input_analog_gain" = "1" + device i2c 28 on + probe DB_USB DB_1C_LTE + end + end + end #I2C2 device ref i2c3 on chip drivers/i2c/generic register "hid" = ""RTL5682"" @@ -598,6 +671,13 @@ end end chip drivers/usb/acpi + register "desc" = ""USB2 WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port4 on + probe DB_USB DB_1C_LTE + end + end + chip drivers/usb/acpi register "desc" = ""USB2 Camera"" register "type" = "UPC_TYPE_INTERNAL" device ref usb2_port6 on end @@ -632,6 +712,13 @@ probe DB_USB DB_1C_1A end end + chip drivers/usb/acpi + register "desc" = ""USB3 WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb3_port2 on + probe DB_USB DB_1C_LTE + end + end end end end
