Hello Felix Singer, V Sowmya, Nico Huber, Furquan Shaikh, Tim Wawrzynczak, Subrata Banik, Arthur Heymans, Michael Niewöhner, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/48567
Change subject: soc/intel/cannonlake: Drop unreferenced devicetree settings ......................................................................
No mainboard uses these settings, nor does SoC code. Drop them.
Change-Id: Ia9c8347cad479c6b4e678630921f768e0fdee6d9 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/cannonlake/chip.h 1 file changed, 0 insertions(+), 32 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/48567/1
diff --git a/src/soc/intel/cannonlake/chip.h b/src/soc/intel/cannonlake/chip.h index 70aab92..492ebca 100644 --- a/src/soc/intel/cannonlake/chip.h +++ b/src/soc/intel/cannonlake/chip.h @@ -78,24 +78,6 @@ /* TCC activation offset */ uint32_t tcc_offset;
- uint64_t PlatformMemorySize; - uint8_t SmramMask; - uint8_t MrcFastBoot; - uint32_t TsegSize; - uint16_t MmioSize; - - /* DDR Frequency Limit. Maximum Memory Frequency Selections in Mhz. - * Options : 1067, 1333, 1600, 1867, 2133, 2400, 2667, 2933, 0(Auto) */ - uint16_t DdrFreqLimit; - - /* SAGV Low Frequency Selections in Mhz. - * Options : 1067, 1333, 1600, 1867, 2133, 2400, 2667, 2933, 0(Auto) */ - uint16_t FreqSaGvLow; - - /* SAGV Mid Frequency Selections in Mhz. - * Options : 1067, 1333, 1600, 1867, 2133, 2400, 2667, 2933, 0(Auto) */ - uint16_t FreqSaGvMid; - /* System Agent dynamic frequency support. Only effects ULX/ULT CPUs. * For CNL, options are as following * When enabled, memory will be training at three different frequencies. @@ -119,7 +101,6 @@ /* USB related */ struct usb2_port_config usb2_ports[16]; struct usb3_port_config usb3_ports[10]; - uint8_t SsicPortEnable; /* Wake Enable Bitmap for USB2 ports */ uint16_t usb2_wake_enable_bitmap; /* Wake Enable Bitmap for USB3 ports */ @@ -222,27 +203,14 @@ /* Enable/disable SD card write protect pin configuration on CML */ uint8_t ScsSdCardWpPinEnabled;
- /* Integrated Sensor */ - uint8_t PchIshEnable; - /* Heci related */ uint8_t DisableHeciRetry;
/* Gfx related */ - uint8_t IgdDvmt50PreAlloc; uint8_t SkipExtGfxScan;
- uint32_t GraphicsConfigPtr; uint8_t Device4Enable;
- /* GPIO IRQ Select. The valid value is 14 or 15 */ - uint8_t GpioIrqRoute; - /* SCI IRQ Select. The valid value is 9, 10, 11, 20, 21, 22, 23 */ - uint8_t SciIrqSelect; - /* TCO IRQ Select. The valid value is 9, 10, 11, 20, 21, 22, 23 */ - uint8_t TcoIrqSelect; - uint8_t TcoIrqEnable; - /* CPU PL2/4 Config * Performance: Maximum PLs for maximum performance. * Baseline: Baseline PLs for balanced performance at lower power.
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48567 )
Patch Set 1: Code-Review+1
Just noting that some of these are unused because mainboards are setting UPDs directly
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48567 )
Patch Set 1:
Yeah, I've seen that. I guess devicetree isn't flexible enough sometimes.
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48567 )
Patch Set 1: Code-Review+2
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48567 )
Hung-Te Lin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/48567 )
Change-Id: Ia9c8347cad479c6b4e678630921f768e0fdee6d9 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/48567 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/cannonlake/chip.h 1 file changed, 0 insertions(+), 32 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Tim Wawrzynczak: Looks good to me, but someone else must approve Michael Niewöhner: Looks good to me, approved
