Rob Barnes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42800 )
Change subject: mb/google/zork: Disable unsupported SOC usb ports ......................................................................
Disable USB ports that are not supported by the SOC. Handles Dali, Picasso and Pollock.
BUG=b:158096224 TEST=Boot Picasso Ezkinil, observe ports disabled
Change-Id: Ie37e2ac6a3a26edf77823193e592310eb10b9f9c Signed-off-by: Rob Barnes robbarnes@google.com --- M src/soc/amd/picasso/chip.c 1 file changed, 30 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/42800/1
diff --git a/src/soc/amd/picasso/chip.c b/src/soc/amd/picasso/chip.c index c510efe..fb5fb98 100644 --- a/src/soc/amd/picasso/chip.c +++ b/src/soc/amd/picasso/chip.c @@ -9,6 +9,7 @@ #include <soc/data_fabric.h> #include <soc/iomap.h> #include <soc/pci_devs.h> +#include <soc/soc_util.h> #include <soc/southbridge.h> #include "chip.h" #include <fsp/api.h> @@ -127,12 +128,40 @@ } }
+/** + * Disables USB ports not supported on the SOC variant. + */ +static void disable_unsupported_usb_ports(void) { + struct device *bus_a, *xhci0, *xhci1, *hub, *port; + + bus_a = pcidev_path_on_root(PCI_DEVFN(8, 1)); + xhci0 = pcidev_path_behind(bus_a->link_list, PCI_DEVFN(0,3)); + hub = xhci0->link_list->children; + port = NULL; + while ((port = dev_bus_each_child(hub->link_list, port)) != NULL) { + unsigned int port_id = port->path.usb.port_id; + /* Picasso SOC only has 4 USB ports on XHCI0 */ + if(!soc_is_raven2() && port->enabled && port_id > 3) { + printk(BIOS_INFO,"Disabling XHCI0 USB port %s because it is not supported on this SOC\n", dev_path(port)); + dev_set_enabled(port, 0); + } + } + + xhci1 = pcidev_path_behind(bus_a->link_list, PCI_DEVFN(0,4)); + hub = xhci1->link_list->children; + /* Dali and Pollock do not have USB ports on XHCI1 */ + if(soc_is_raven2() && hub->enabled) { + printk(BIOS_INFO,"Disabling XHCI1 USB hub because it is not supported on this SOC\n"); + disable_children(hub->bus); + } +} + static void soc_init(void *chip_info) { default_dev_ops_root.write_acpi_tables = agesa_write_acpi_tables;
fsp_silicon_init(acpi_is_wakeup_s3()); - + disable_unsupported_usb_ports(); data_fabric_set_mmio_np(); southbridge_init(chip_info); }
Rob Barnes has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/42800 )
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/42800/2
Rob Barnes has uploaded a new patch set (#3). ( https://review.coreboot.org/c/coreboot/+/42800 )
Change-Id: Ie37e2ac6a3a26edf77823193e592310eb10b9f9c Signed-off-by: Rob Barnes robbarnes@google.com --- M src/soc/amd/picasso/chip.c 1 file changed, 32 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/42800/3
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42800 )
Patch Set 4:
(2 comments)
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c File src/soc/amd/picasso/chip.c:
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c@... PS4, Line 144: 4 USB 4 USB 3 ports, but IIRC additionally 2 USB 2 ports on the same XHCI 0 controller
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c@... PS4, Line 154: /* Dali and Pollock do not have USB ports on XHCI1 */ they don't have XHCI 1; only XHCI 0
Patch Set 4:
(2 comments)
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c@... PS4, Line 145: soc_is_raven2 both RV2 and fused-down PCO, which can also be used in a Dali SKU, have a reduced number of ports. get_soc_type() == SOC_PICASSO is probably what should be used here. that doesn't take possible AM4 SKUs into consideration though.
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c@... PS4, Line 155: soc_is_raven2 get_soc_type != SOC_PICASSO maybe? same to possible AM4 SKUs as above.
Patch Set 4:
should I add a soc_is_defeatured_sku() to soc_util? i think that's what we should be exporting there instead of soc_is_dali()
Patch Set 4:
Patch Set 4:
See CB:42833
Rob Barnes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42800 )
Patch Set 4:
(4 comments)
I'm referencing Chapter 11 of FP5 Processor Motherboard Design Guide. FP5 Type 1 (Picasso) has 4 USB2 + 4 USB3 ports on XHCI0 and 2 USB2 ports + 1 USB3 port on XHCI1. FP5 Type 2 (Dali) has 4 USB3 and 6 USB2 ports on XHCI0 and no XHCI1.
both RV2 and fused-down PCO, which can also be used in a Dali SKU, have a reduced number of ports. […]
Commit 30c62ab9130c95871ebb9f517894a9b6b9c4f7d8 has soc_is_picasso helper. We should get that upstream so it can be used here.
So disable disable_children(xhci1->bus).
Ack
Raul Rangel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42800 )
Patch Set 4:
https://review.coreboot.org/c/coreboot/+/42800/4/src/soc/amd/picasso/chip.c@... PS4, Line 166: disable_unsupported_usb_ports Maybe we add this code to the driver? https://review.coreboot.org/c/coreboot/+/41900/6
It knows how many ports exist for each controller.
Patch Set 4:
Maybe we add this code to the driver? https://review.coreboot.org/c/coreboot/+/41900/6 […]
https://review.coreboot.org/c/coreboot/+/43354/2 adds the functionality to the driver. We can abandon this CL now.
Rob Barnes has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/42800 )
Abandoned
