Marc Jones has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49494 )
Change subject: soc/intel/xeon_sp/acpi.c: Add ACPI C-State table ......................................................................
Add ACPI _CST table.
Tested on deltalake with acpi_idle driver. Note, intel_idle may not use ACPI _CST table.
Change-Id: I359daa9556edbe263ab0a7f1849c96c8fe1a0da0 Signed-off-by: Marc Jones marcjones@sysproconsulting.com --- M src/soc/intel/xeon_sp/acpi.c 1 file changed, 42 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/49494/1
diff --git a/src/soc/intel/xeon_sp/acpi.c b/src/soc/intel/xeon_sp/acpi.c index b271264..473263e 100644 --- a/src/soc/intel/xeon_sp/acpi.c +++ b/src/soc/intel/xeon_sp/acpi.c @@ -6,10 +6,50 @@ #include <soc/util.h> #include <string.h>
+#define MWAIT_RES(state, sub_state) \ + { \ + .addrl = (((state) << 4) | (sub_state)), \ + .space_id = ACPI_ADDRESS_SPACE_FIXED, \ + .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, \ + .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, \ + .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, \ + } + +static acpi_cstate_t cstate_map[] = { + { + /* C1 */ + .ctype = 1, /* ACPI C1 */ + .latency = 1, + .power = 0x3e8, + .resource = MWAIT_RES(0, 0), + }, + { + /* C3 */ + .ctype = 2, /* ACPI C2 */ + .latency = 15, + .power = 0x1f4, + .resource = MWAIT_RES(1, 0), + }, + { + /* C6 */ + .ctype = 3, /* ACPI C3 */ + .latency = 41, + .power = 0x15e, + .resource = MWAIT_RES(2, 0), + }, + { + /* C7 */ + .ctype = 3, /* ACPI C3 */ + .latency = 41, + .power = 0x0c8, + .resource = MWAIT_RES(3, 0), + } +}; + acpi_cstate_t *soc_get_cstate_map(size_t *entries) { - *entries = 0; - return NULL; + *entries = ARRAY_SIZE(cstate_map); + return cstate_map; }
static void print_madt_ioapic(int socket, int stack,
