Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43312 )
Change subject: soc/amd/picasso: Add driver for handling PCIE GPP bridges ......................................................................
This change adds a driver pcie_gpp.c which provides device_operations for external and internal PCIe GPP bridges. These device operations include standard PCI bridge operations as well as operations for generating ACPI node for the device and returning appropriate ACPI name for it.
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I9f8809c2735bdc09435deda91a570c89e71e8062 --- M src/soc/amd/picasso/Makefile.inc M src/soc/amd/picasso/chip.c A src/soc/amd/picasso/pcie_gpp.c 3 files changed, 61 insertions(+), 36 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/43312/1
diff --git a/src/soc/amd/picasso/Makefile.inc b/src/soc/amd/picasso/Makefile.inc index 593d17b..b6c0ddb 100644 --- a/src/soc/amd/picasso/Makefile.inc +++ b/src/soc/amd/picasso/Makefile.inc @@ -78,6 +78,7 @@ ramstage-y += config.c ramstage-y += update_microcode.c ramstage-y += graphics.c +ramstage-y += pcie_gpp.c
smm-y += smihandler.c smm-y += smi_util.c diff --git a/src/soc/amd/picasso/chip.c b/src/soc/amd/picasso/chip.c index 2e5fae5..7d56323 100644 --- a/src/soc/amd/picasso/chip.c +++ b/src/soc/amd/picasso/chip.c @@ -56,24 +56,6 @@ return "GNB"; case IOMMU_DEVFN: return "IOMM"; - case PCIE_GPP_0_DEVFN: - return "PBR0"; - case PCIE_GPP_1_DEVFN: - return "PBR1"; - case PCIE_GPP_2_DEVFN: - return "PBR2"; - case PCIE_GPP_3_DEVFN: - return "PBR3"; - case PCIE_GPP_4_DEVFN: - return "PBR4"; - case PCIE_GPP_5_DEVFN: - return "PBR5"; - case PCIE_GPP_6_DEVFN: - return "PBR6"; - case PCIE_GPP_A_DEVFN: - return "PBRA"; - case PCIE_GPP_B_DEVFN: - return "PBRB"; case LPC_DEVFN: return "LPCB"; case SMBUS_DEVFN: @@ -111,15 +93,6 @@ .acpi_name = soc_acpi_name, };
-static struct device_operations pci_ops_ops_bus_ab = { - .read_resources = pci_bus_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_bus_enable_resources, - .scan_bus = pci_scan_bridge, - .reset_bus = pci_bus_reset, - .acpi_fill_ssdt = acpi_device_write_pci_dev, -}; - static void set_mmio_dev_ops(struct device *dev) { switch (dev->path.mmio.addr) { @@ -144,15 +117,6 @@ dev->ops = &pci_domain_ops; } else if (dev->path.type == DEVICE_PATH_CPU_CLUSTER) { dev->ops = &cpu_bus_ops; - } else if (dev->path.type == DEVICE_PATH_PCI) { - if (dev->bus->dev->path.type == DEVICE_PATH_DOMAIN) { - switch (dev->path.pci.devfn) { - case PCIE_GPP_A_DEVFN: - case PCIE_GPP_B_DEVFN: - dev->ops = &pci_ops_ops_bus_ab; - } - } - sb_enable(dev); } else if (dev->path.type == DEVICE_PATH_MMIO) { set_mmio_dev_ops(dev); } diff --git a/src/soc/amd/picasso/pcie_gpp.c b/src/soc/amd/picasso/pcie_gpp.c new file mode 100644 index 0000000..651855a --- /dev/null +++ b/src/soc/amd/picasso/pcie_gpp.c @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpigen.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <soc/pci_devs.h> +#include <stdio.h> + +static const char *pcie_gpp_acpi_name(const struct device *dev) +{ + if (dev->path.type != DEVICE_PATH_PCI) + return NULL; + + switch (dev->path.pci.devfn) { + case PCIE_GPP_0_DEVFN: + return "PBR0"; + case PCIE_GPP_1_DEVFN: + return "PBR1"; + case PCIE_GPP_2_DEVFN: + return "PBR2"; + case PCIE_GPP_3_DEVFN: + return "PBR3"; + case PCIE_GPP_4_DEVFN: + return "PBR4"; + case PCIE_GPP_5_DEVFN: + return "PBR5"; + case PCIE_GPP_6_DEVFN: + return "PBR6"; + case PCIE_GPP_A_DEVFN: + return "PBRA"; + case PCIE_GPP_B_DEVFN: + return "PBRB"; + } + + return NULL; +} + +static struct device_operations pcie_gpp_ops = { + .read_resources = pci_bus_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_bus_enable_resources, + .scan_bus = pci_scan_bridge, + .reset_bus = pci_bus_reset, + .acpi_name = pcie_gpp_acpi_name, + .acpi_fill_ssdt = acpi_device_write_pci_dev, +}; + +static const unsigned short pci_device_ids[] = { + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP, + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP_BUSA, + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP_BUSB, + 0 +}; + +static const struct pci_driver sata0_driver __pci_driver = { + .ops = &pcie_gpp_ops, + .vendor = PCI_VENDOR_ID_AMD, + .devices = pci_device_ids, +};
Hello Patrick Georgi, Martin Roth,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/43312/2
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43312 )
Patch Set 2: Code-Review+2
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43312 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/43312/2/src/soc/amd/picasso/pcie_gp... File src/soc/amd/picasso/pcie_gpp.c:
https://review.coreboot.org/c/coreboot/+/43312/2/src/soc/amd/picasso/pcie_gp... PS2, Line 15: switch (dev->path.pci.devfn) { switch and case should be at the same indent
Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Aaron Durbin,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/43312/3
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43312 )
Patch Set 3:
Done.
Patch Set 3: Code-Review+2
Aaron Durbin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43312 )
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I9f8809c2735bdc09435deda91a570c89e71e8062 Reviewed-on: https://review.coreboot.org/c/coreboot/+/43312 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Aaron Durbin adurbin@chromium.org --- M src/soc/amd/picasso/Makefile.inc M src/soc/amd/picasso/chip.c A src/soc/amd/picasso/pcie_gpp.c 3 files changed, 61 insertions(+), 36 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
-static struct device_operations pci_ops_ops_bus_ab = { - .read_resources = pci_bus_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_bus_enable_resources, - .scan_bus = pci_scan_bridge, - .reset_bus = pci_bus_reset, - .acpi_fill_ssdt = acpi_device_write_pci_dev, -}; - static void set_mmio_dev_ops(struct device *dev) { switch (dev->path.mmio.addr) { @@ -144,15 +117,6 @@ dev->ops = &pci_domain_ops; } else if (dev->path.type == DEVICE_PATH_CPU_CLUSTER) { dev->ops = &cpu_bus_ops; - } else if (dev->path.type == DEVICE_PATH_PCI) { - if (dev->bus->dev->path.type == DEVICE_PATH_DOMAIN) { - switch (dev->path.pci.devfn) { - case PCIE_GPP_A_DEVFN: - case PCIE_GPP_B_DEVFN: - dev->ops = &pci_ops_ops_bus_ab; - } - } - sb_enable(dev); } else if (dev->path.type == DEVICE_PATH_MMIO) { set_mmio_dev_ops(dev); } diff --git a/src/soc/amd/picasso/pcie_gpp.c b/src/soc/amd/picasso/pcie_gpp.c new file mode 100644 index 0000000..73de803 --- /dev/null +++ b/src/soc/amd/picasso/pcie_gpp.c @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <acpi/acpigen.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <soc/pci_devs.h> +#include <stdio.h> + +static const char *pcie_gpp_acpi_name(const struct device *dev) +{ + if (dev->path.type != DEVICE_PATH_PCI) + return NULL; + + switch (dev->path.pci.devfn) { + case PCIE_GPP_0_DEVFN: + return "PBR0"; + case PCIE_GPP_1_DEVFN: + return "PBR1"; + case PCIE_GPP_2_DEVFN: + return "PBR2"; + case PCIE_GPP_3_DEVFN: + return "PBR3"; + case PCIE_GPP_4_DEVFN: + return "PBR4"; + case PCIE_GPP_5_DEVFN: + return "PBR5"; + case PCIE_GPP_6_DEVFN: + return "PBR6"; + case PCIE_GPP_A_DEVFN: + return "PBRA"; + case PCIE_GPP_B_DEVFN: + return "PBRB"; + } + + return NULL; +} + +static struct device_operations pcie_gpp_ops = { + .read_resources = pci_bus_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_bus_enable_resources, + .scan_bus = pci_scan_bridge, + .reset_bus = pci_bus_reset, + .acpi_name = pcie_gpp_acpi_name, + .acpi_fill_ssdt = acpi_device_write_pci_dev, +}; + +static const unsigned short pci_device_ids[] = { + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP, + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP_BUSA, + PCI_DEVICE_ID_AMD_FAM17H_PCIE_GPP_BUSB, + 0 +}; + +static const struct pci_driver pcie_gpp_driver __pci_driver = { + .ops = &pcie_gpp_ops, + .vendor = PCI_VENDOR_ID_AMD, + .devices = pci_device_ids, +};
