Hello Patrick Rudolph, Aaron Durbin, Piotr Król, Paul Menzel, build bot (Jenkins), Hannah Williams, Nico Huber, Michał Żygowski, Patrick Georgi,
https://review.coreboot.org/c/coreboot/+/29284
Change subject: soc/intel/braswell/chip.c: Configure LPSS devices in correct mode ......................................................................
LPSS (SIO 0/24/0 and 0/30/0) are configured to ACPI mode if 'lpss_acpi_mode' = '1' or PcdEnableDma0/PcdEnableDma1 is configured in ACPI mode. When function 0 is configured in ACPI mode, functions > 1 are not available on the PCI bus, even pcdEnableXXXXX is set to PCI mode. For SIO DMA0: - HSUARTS ports not visible on PCI bus. For SIO DMA1: - I2C ports not visible on PCI bus.
Force 'function > 1' devices in ACPI mode when function 0 is configured in ACPI mode.
Intel FSP documentation does not mention that PcdEnable* devices in LPSS supports ACPI Mode (value 0x2). For these devices value '0x1' is used for PCI Mode.
BUG=N/A TEST=Booting embedded Linux at Portwell PQ7-M107, LPSS device are configured in ACPI mode when 'lpss_acpi_mode' = '1'. Could not verify using these devices, because no devices/connections are available.
Change-Id: Ie271d8cb9f30f0c0ba538f1530cfb82f1306fea8 Signed-off-by: Frans Hendriks fhendriks@eltan.com --- M src/soc/intel/braswell/chip.c 1 file changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/29284/11
