Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13968
commit 5dfce9f383b59c885e724e1b533b94e787f26bd9 Author: Patrick Georgi pgeorgi@chromium.org Date: Tue Mar 8 21:42:00 2016 +0100
mediatek/mt8173: Enable ARM trusted firmware integration
In Chromium OS downstream this was done together with adding the support for ATF, but unfortunately ATF upstream isn't ready yet. This commit is a reminder to enable things once ATF caught up.
Change-Id: Id0d6908d906a1e54cdda4f232d572d996d9c556f Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- src/soc/mediatek/mt8173/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/src/soc/mediatek/mt8173/Kconfig b/src/soc/mediatek/mt8173/Kconfig index 91a8d4f..ec3481e 100644 --- a/src/soc/mediatek/mt8173/Kconfig +++ b/src/soc/mediatek/mt8173/Kconfig @@ -6,6 +6,7 @@ config SOC_MEDIATEK_MT8173 select ARCH_RAMSTAGE_ARMV8_64 select ARCH_ROMSTAGE_ARMV8_64 select ARCH_VERSTAGE_ARMV8_64 + select ARM64_USE_ARM_TRUSTED_FIRMWARE select BOOTBLOCK_CONSOLE select HAVE_UART_SPECIAL select SPI_ATOMIC_SEQUENCING if SPI_FLASH
