Attention is currently required from: Sean Rhodes, Martin Roth, Tim Wawrzynczak, Angel Pons. Hello build bot (Jenkins), Martin Roth, Tim Wawrzynczak, Angel Pons,
https://review.coreboot.org/c/coreboot/+/58854
to look at the new patch set (#19).
Change subject: [WIP] util: Add coreboot Configurator ......................................................................
A simply GUI to change settings in coreboot's CBFS, via the nvramtool utility.
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: Ie654f6aca57a792be0c295afc081a95ed4d875d1 --- A util/coreboot-configurator/README.md A util/coreboot-configurator/contrib/PKGBUILD A util/coreboot-configurator/contrib/README.md A util/coreboot-configurator/contrib/debian/changelog A util/coreboot-configurator/contrib/debian/compat A util/coreboot-configurator/contrib/debian/control A util/coreboot-configurator/contrib/debian/copyright A util/coreboot-configurator/contrib/debian/files A util/coreboot-configurator/contrib/debian/rules A util/coreboot-configurator/contrib/debian/source/format A util/coreboot-configurator/contrib/flatpak/coreboot-configurator.json A util/coreboot-configurator/contrib/flatpak/org.coreboot.coreboot-configurator.json A util/coreboot-configurator/meson.build A util/coreboot-configurator/meson_options.txt A util/coreboot-configurator/screenshots/coreboot-configurator.gif A util/coreboot-configurator/screenshots/coreboot-configurator.png A util/coreboot-configurator/src/Documentation.txt A util/coreboot-configurator/src/application/aboutwindow.cpp A util/coreboot-configurator/src/application/aboutwindow.h A util/coreboot-configurator/src/application/aboutwindow.ui A util/coreboot-configurator/src/application/categories.yaml A util/coreboot-configurator/src/application/configuration.cpp A util/coreboot-configurator/src/application/configuration.h A util/coreboot-configurator/src/application/coreboot_configurator.cpp A util/coreboot-configurator/src/application/coreboot_configurator.h A util/coreboot-configurator/src/application/coreboot_configurator.ui A util/coreboot-configurator/src/application/images.qrc A util/coreboot-configurator/src/application/main.cpp A util/coreboot-configurator/src/application/meson.build A util/coreboot-configurator/src/application/qtyaml.h A util/coreboot-configurator/src/application/toggle-off.svg A util/coreboot-configurator/src/application/toggle-on.svg A util/coreboot-configurator/src/meson.build A util/coreboot-configurator/src/static/aboutIcon.png A util/coreboot-configurator/src/static/coreboot-configurator.desktop A util/coreboot-configurator/src/static/coreboot_configurator.svg A util/coreboot-configurator/src/static/meson.build A util/coreboot-configurator/src/static/org.coreboot.nvramtool.policy A util/coreboot-configurator/src/static/org.coreboot.reboot.policy 39 files changed, 2,927 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/54/58854/19
