Martin Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/67308 )
Change subject: mb/google/skyrim/var/winterhold: Update devicetree setting ......................................................................
Initialize winterhold devicetree.
BUG=b:241196632 TEST=emerge-skyrim coreboot
Signed-off-by: EricKY Cheng ericky_cheng@compal.corp-partner.google.com Change-Id: I9fe224cdc2acb1f13d3bf9341b487892c15f8ea2 Reviewed-on: https://review.coreboot.org/c/coreboot/+/67308 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Martin Roth martin.roth@amd.corp-partner.google.com --- M src/mainboard/google/skyrim/variants/winterhold/overridetree.cb 1 file changed, 192 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved
diff --git a/src/mainboard/google/skyrim/variants/winterhold/overridetree.cb b/src/mainboard/google/skyrim/variants/winterhold/overridetree.cb index 7a56f93..1e46f2b 100644 --- a/src/mainboard/google/skyrim/variants/winterhold/overridetree.cb +++ b/src/mainboard/google/skyrim/variants/winterhold/overridetree.cb @@ -1,5 +1,178 @@ # SPDX-License-Identifier: GPL-2.0-or-later
chip soc/amd/mendocino - device domain 0 on end + device domain 0 on + device ref gpp_bridge_a on # Internal GPP Bridge 0 to Bus A + device ref xhci_1 on # XHCI1 controller + chip drivers/usb/acpi + device ref xhci_1_root_hub on # XHCI1 root hub + chip drivers/usb/acpi + device ref usb3_port3 on # USB 3.1 port3 + chip drivers/usb/hub + register "desc" = ""USB Hub"" + register "name" = ""VL822"" + register "port_count" = "4" + device usb 0.0 on # VL822 USB3 hub + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A0 (DB)"" + register "type" = "UPC_TYPE_USB3_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(2, 2))" + device usb 3.0 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + register "group" = "ACPI_PLD_GROUP(2, 2)" + register "has_power_resource" = "1" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_42)" + register "reset_off_delay_ms" = "20" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_8)" + register "enable_delay_ms" = "20" + device usb 3.1 on end + end + end # VL822 USB3 hub + end + end # USB 3.1 port3 + end + chip drivers/usb/acpi + device ref usb2_port3 on # USB 2 port3 + chip drivers/usb/hub + register "desc" = ""USB Hub"" + register "name" = ""VL822"" + register "port_count" = "4" + device usb 0.0 on # VL822 USB2 hub + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A0 (DB)"" + register "type" = "UPC_TYPE_USB3_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(2, 2))" + device usb 2.0 on end + end + chip drivers/usb/acpi + register "desc" = ""WWAN"" + register "type" = "UPC_TYPE_INTERNAL" + register "group" = "ACPI_PLD_GROUP(2, 2)" + device usb 2.1 on end + end + end # VL822 USB2 hub + end + end # USB 2 port3 + end + end # XHCI1 root hub + end + end # XHCI1 controller + end # Internal GPP Bridge 0 to Bus A + end # domain + + device ref i2c_0 on + chip drivers/i2c/generic + register "hid" = ""ELAN0000"" + register "desc" = ""ELAN Touchpad"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_LOW(GPIO_40)" + register "wake" = "GEVENT_20" + register "probed" = "1" + device i2c 15 on end + end + chip drivers/i2c/hid + register "generic.hid" = ""GXTP7863"" + register "generic.desc" = ""Goodix Touchpad"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPIO_40)" + register "generic.wake" = "GEVENT_20" + register "generic.probed" = "1" + register "hid_desc_reg_offset" = "0x20" + device i2c 2c on end + end + end # I2C0 + device ref i2c_1 on + chip drivers/i2c/hid + register "generic.hid" = ""GDIX0000"" + register "generic.desc" = ""Goodix Touchscreen"" + register "generic.irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPIO_29)" + register "generic.probed" = "1" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_131)" + register "generic.enable_delay_ms" = "10" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPIO_136)" + register "generic.reset_off_delay_ms" = "1" + register "generic.reset_delay_ms" = "10" + register "generic.stop_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPIO_76)" + register "generic.stop_delay_ms" = "180" + register "generic.stop_off_delay_ms" = "1" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 5d on end + end + chip drivers/i2c/generic + register "hid" = ""ELAN0001"" + register "desc" = ""ELAN Touchscreen"" + register "probed" = "1" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_LOW(GPIO_29)" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_131)" + register "enable_delay_ms" = "1" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPIO_136)" + register "reset_delay_ms" = "20" + register "reset_off_delay_ms" = "2" + register "stop_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPIO_76)" + register "stop_off_delay_ms" = "2" + register "has_power_resource" = "1" + register "disable_gpio_export_in_crs" = "1" + device i2c 10 on end + end + chip drivers/generic/gpio_keys + register "name" = ""PENH"" + register "gpio" = "ACPI_GPIO_INPUT_ACTIVE_LOW(GPIO_3)" + register "key.dev_name" = ""EJCT"" + register "key.wakeup_event_action" = "EV_ACT_DEASSERTED" + register "key.linux_code" = "SW_PEN_INSERTED" + register "key.linux_input_type" = "EV_SW" + register "key.label" = ""pen_eject"" + register "key.debounce_interval" = "100" + register "key.wakeup_route" = "WAKEUP_ROUTE_GPIO_IRQ" + device generic 0 on end + end + end # I2C1 + device ref i2c_2 on + chip drivers/i2c/generic + register "hid" = ""RTL5682"" + register "name" = ""RT58"" + register "desc" = ""Realtek RT5682"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPIO_90)" + register "property_count" = "1" + register "property_list[0].type" = "ACPI_DP_TYPE_INTEGER" + register "property_list[0].name" = ""realtek,jd-src"" + register "property_list[0].integer" = "1" + device i2c 1a on end + end + chip drivers/i2c/generic + register "hid" = ""10EC1019"" + register "desc" = ""Realtek SPK AMP R"" + register "uid" = "1" + device i2c 29 on end + end + chip drivers/i2c/generic + register "hid" = ""10EC1019"" + register "desc" = ""Realtek SPK AMP L"" + register "uid" = "2" + register "probed" = "1" + device i2c 2a on end + end + end # I2C2 + + device ref uart_1 on + chip drivers/uart/acpi + register "name" = ""CRFP"" + register "desc" = ""Fingerprint Reader"" + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "compat_string" = ""google,cros-ec-uart"" + register "irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPIO_24)" + register "wake" = "GEVENT_15" + register "uart" = "ACPI_UART_RAW_DEVICE(3000000, 64)" + register "has_power_resource" = "1" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPIO_12)" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_4)" + register "enable_delay_ms" = "3" + device generic 0 alias fpmcu on end + end + end # UART1 + end # chip soc/amd/mendocino
