Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62922 )
Change subject: Makefile.inc: Explicitly delete coreboot.pre ......................................................................
coreboot.pre doesn't follow the standard Make conventions. It gets modified by multiple rules, and thus we can't compute the dependencies correctly. This means we need to manually delete it before starting the dependency calculations.
i.e., Building firmware with the seabios payload now works correctly.
Fixes: dd6efce934f ("Makefile: Add .SECONDARY") Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: If5fa3f0b8d314369a044658e452bd75bc7709397 Reviewed-on: https://review.coreboot.org/c/coreboot/+/62922 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michael Niewöhner foss@mniewoehner.de --- M Makefile.inc 1 file changed, 4 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Michael Niewöhner: Looks good to me, approved
diff --git a/Makefile.inc b/Makefile.inc index 929c236..377ddff 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -1116,6 +1116,10 @@ TS_OPTIONS := -j $(CONFIG_INTEL_TOP_SWAP_BOOTBLOCK_SIZE) endif
+# coreboot.pre doesn't follow the standard Make conventions. It gets modified +# by multiple rules, and thus we can't compute the dependencies correctly. +$(shell rm -f $(obj)/coreboot.pre) + ifneq ($(CONFIG_UPDATE_IMAGE),y) $(obj)/coreboot.pre: $(objcbfs)/bootblock.bin $$(prebuilt-files) $(CBFSTOOL) $(obj)/fmap.fmap $(obj)/fmap.desc $(CBFSTOOL) $@.tmp create -M $(obj)/fmap.fmap -r $(shell cat $(obj)/fmap.desc)
1 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
