Attention is currently required from: Nico Huber, Paul Menzel.
Hello Nico Huber, Paul Menzel,
https://review.coreboot.org/c/coreboot/+/82632?usp=email
Change subject: sio/nuvoton: Implement a common ramstage ACPI LDN helper ......................................................................
With few exceptions, Nuvoton super I/O chips have the same configuration registers.
This patch provides a helper function for configuring the ACPI logical device on Nuvoton SIOs, covering system power state after power loss and switching PS/2 port roles between keyboard and mouse, both controllable using nvram options.
This patch covers nct5572d, nct6776, nct6779d, nct6791d. Change all to use this common code, and add HAVE_POWER_STATE_AFTER_FAILURE Kconfig to all that don't have it already.
It extends these features to Nuvoton SIOs that currently lack them, with additional improvements:
1. Enable waking up the system from PS/2 keyboard and/or mouse. 2. Establish an "off" state for "user-defined" power state after failure. This mode is not used by coreboot.
The nvram options have to be added individually to mainboards.
TEST=Both features boot tested on asus/p8z77-m which uses sio/nuvoton/nct6779d.
Change-Id: Ibaddcaa2d77c5b06ddfbb6dbaac00df5e72dd4bd Signed-off-by: Keith Hui buurin@gmail.com --- M src/superio/nuvoton/Makefile.mk A src/superio/nuvoton/common/common.c A src/superio/nuvoton/common/common.h M src/superio/nuvoton/nct5572d/superio.c M src/superio/nuvoton/nct6776/Kconfig M src/superio/nuvoton/nct6776/superio.c M src/superio/nuvoton/nct6779d/Kconfig M src/superio/nuvoton/nct6779d/superio.c M src/superio/nuvoton/nct6791d/Kconfig M src/superio/nuvoton/nct6791d/superio.c 10 files changed, 116 insertions(+), 14 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/82632/4
