Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17647
commit 69746967afd6cf4d517e8063386fbfdb1fcc277f Author: Aaron Durbin adurbin@chromium.org Date: Tue Nov 29 21:22:42 2016 -0600
romstage_handoff: add helper to determine resume status
Instead of having callers query the romstage handoff resume status by inspecing the object themselves add romstage_handoff_is_resume() so that the same information can be queried easily.
Change-Id: I40f3769b7646bf296ee4bc323a9ab1d5e5691e21 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/x86/acpi_s3.c | 9 +-------- src/include/romstage_handoff.h | 16 ++++++++++++++++ src/lib/prog_loaders.c | 25 ++++++++++++------------- src/soc/intel/apollolake/chip.c | 4 +--- src/soc/intel/quark/chip.c | 5 +---- src/soc/intel/skylake/chip_fsp20.c | 7 +------ 6 files changed, 32 insertions(+), 34 deletions(-)
diff --git a/src/arch/x86/acpi_s3.c b/src/arch/x86/acpi_s3.c index ffec64d..f3cb097 100644 --- a/src/arch/x86/acpi_s3.c +++ b/src/arch/x86/acpi_s3.c @@ -32,14 +32,7 @@ int acpi_slp_type = -1; #if IS_ENABLED(CONFIG_EARLY_CBMEM_INIT) int acpi_get_sleep_type(void) { - struct romstage_handoff *handoff; - - handoff = cbmem_find(CBMEM_ID_ROMSTAGE_INFO); - - if (handoff == NULL) { - printk(BIOS_DEBUG, "Unknown boot method, assuming normal.\n"); - return ACPI_S0; - } else if (handoff->s3_resume) { + if (romstage_handoff_is_resume()) { printk(BIOS_DEBUG, "S3 Resume.\n"); return ACPI_S3; } else { diff --git a/src/include/romstage_handoff.h b/src/include/romstage_handoff.h index 175cf09..b36ff9f 100644 --- a/src/include/romstage_handoff.h +++ b/src/include/romstage_handoff.h @@ -90,4 +90,20 @@ static inline int romstage_handoff_init(int is_s3_resume) return 0; }
+/* Return 1 if resuming or 0 if not. */ +static inline int romstage_handoff_is_resume(void) +{ + struct romstage_handoff *handoff; + + if (!cbmem_available()) + return 0; + + handoff = cbmem_find(CBMEM_ID_ROMSTAGE_INFO); + + if (handoff == NULL) + return 0; + + return handoff->s3_resume; +} + #endif /* ROMSTAGE_HANDOFF_H */ diff --git a/src/lib/prog_loaders.c b/src/lib/prog_loaders.c index 3a6f2e2..58c1a8a 100644 --- a/src/lib/prog_loaders.c +++ b/src/lib/prog_loaders.c @@ -85,19 +85,19 @@ static void ramstage_cache_invalid(void) } }
-static void run_ramstage_from_resume(struct romstage_handoff *handoff, - struct prog *ramstage) +static void run_ramstage_from_resume(struct prog *ramstage) { - if (handoff != NULL && handoff->s3_resume) { - /* Load the cached ramstage to runtime location. */ - stage_cache_load_stage(STAGE_RAMSTAGE, ramstage); - - if (prog_entry(ramstage) != NULL) { - printk(BIOS_DEBUG, "Jumping to image.\n"); - prog_run(ramstage); - } - ramstage_cache_invalid(); + if (!romstage_handoff_is_resume()) + return; + + /* Load the cached ramstage to runtime location. */ + stage_cache_load_stage(STAGE_RAMSTAGE, ramstage); + + if (prog_entry(ramstage) != NULL) { + printk(BIOS_DEBUG, "Jumping to image.\n"); + prog_run(ramstage); } + ramstage_cache_invalid(); }
static int load_relocatable_ramstage(struct prog *ramstage) @@ -136,8 +136,7 @@ void run_ramstage(void) if (IS_ENABLED(CONFIG_ARCH_X86) && !IS_ENABLED(CONFIG_NO_STAGE_CACHE) && IS_ENABLED(CONFIG_EARLY_CBMEM_INIT)) - run_ramstage_from_resume(romstage_handoff_find_or_add(), - &ramstage); + run_ramstage_from_resume(&ramstage);
if (prog_locate(&ramstage)) goto fail; diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index ef5908c..32d68cc 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -260,7 +260,6 @@ static void set_power_limits(void) static void soc_init(void *data) { struct global_nvs_t *gnvs; - struct romstage_handoff *handoff;
/* Save VBT info and mapping */ vbt = vbt_get(&vbt_rdev); @@ -269,8 +268,7 @@ static void soc_init(void *data) * default policy that doesn't honor boards' requirements. */ itss_snapshot_irq_polarities(GPIO_IRQ_START, GPIO_IRQ_END);
- handoff = romstage_handoff_find_or_add(); - fsp_silicon_init(handoff->s3_resume); + fsp_silicon_init(romstage_handoff_is_resume());
/* Restore GPIO IRQ polarities back to previous settings. */ itss_restore_irq_polarities(GPIO_IRQ_START, GPIO_IRQ_END); diff --git a/src/soc/intel/quark/chip.c b/src/soc/intel/quark/chip.c index 150df12..5e80463 100644 --- a/src/soc/intel/quark/chip.c +++ b/src/soc/intel/quark/chip.c @@ -102,8 +102,6 @@ static const struct reg_script thermal_init_script[] = {
static void chip_init(void *chip_info) { - struct romstage_handoff *handoff; - /* Validate the temperature settings */ ASSERT(PLATFORM_CATASTROPHIC_TRIP_CELSIUS <= 255); ASSERT(PLATFORM_CATASTROPHIC_TRIP_CELSIUS @@ -120,8 +118,7 @@ static void chip_init(void *chip_info) | TS_LOCK_AUX_TRIP_PT_REGS_ENABLE));
/* Perform silicon specific init. */ - handoff = romstage_handoff_find_or_add(); - fsp_silicon_init(handoff->s3_resume); + fsp_silicon_init(romstage_handoff_is_resume()); }
static void pci_domain_set_resources(device_t dev) diff --git a/src/soc/intel/skylake/chip_fsp20.c b/src/soc/intel/skylake/chip_fsp20.c index f90f6bc..0768779 100644 --- a/src/soc/intel/skylake/chip_fsp20.c +++ b/src/soc/intel/skylake/chip_fsp20.c @@ -35,13 +35,8 @@
void soc_init_pre_device(void *chip_info) { - struct romstage_handoff *handoff; - - /* Get S3 status to pass to silicon init. */ - handoff = romstage_handoff_find_or_add(); - /* Perform silicon specific init. */ - fsp_silicon_init(handoff->s3_resume); + fsp_silicon_init(romstage_handoff_is_resume()); }
