Attention is currently required from: Sean Rhodes, Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/58798
Change subject: soc/intel/tigerlake/apci: Only use SCM for ChromeOS ......................................................................
Software Connection Manager doesn't work with Linux 5.13 or later and results in TBT ports timing out. Not advertising this results in Firmware Connection Manager being used and TBT works correctly.
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: Ib947c3c9cd843e54d4664509c15336178c0bc99e --- M src/soc/intel/tigerlake/acpi/tcss.asl 1 file changed, 7 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/58798/9
