Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8364
commit 06c444f683061dae1432ce488a8df118e4e27452 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Feb 5 08:12:20 2015 +0200
AMD K8 fam10: Eliminate local variable min_bus
Some cases of max==0xff wrapping around the 8-bit link->secondary register remain to be solved.
Change-Id: I01e2ab6b2f23a03dbac49207ab584eccd1ca9b1f Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/northbridge/amd/amdfam10/northbridge.c | 19 +++++++------------ src/northbridge/amd/amdk8/northbridge.c | 16 +++++++--------- 2 files changed, 14 insertions(+), 21 deletions(-)
diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 287f468..a81dd82 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -166,7 +166,6 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool int i; u32 ht_c_index; u32 ht_unitid_base[4]; // here assume only 4 HT device on chain - u32 min_bus; u32 busses; u32 max_devfn;
@@ -198,25 +197,21 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool */
if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) { - min_bus = ++max; + max++; } else if (is_sblink) { - // first chain will on bus 0 - min_bus = max; /* actually max is 0 here */ + } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 1) { - min_bus = ++max; + max++; } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) { - // second chain will be on 0x40, third 0x80, forth 0xc0 - // i would refined that to 2, 3, 4 ==> 0, 0x, 40, 0x80, 0xc0 - // >4 will use more segments, // We can have 16 segmment and every segment have 256 bus, // For that case need the kernel support mmio pci config.
// one node can have 8 link and segn is the same - min_bus = (((max & 0xff)>>3) + 1) << 3; - max = (max & ~0xff) | min_bus; + max++; + max = ALIGN_UP(max, 8); }
- link->secondary = min_bus; + link->secondary = max; link->subordinate = (max & ~0xff) | 0xfc;
/* Read the existing primary/secondary/subordinate bus @@ -245,7 +240,7 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool }
//if ext conf is enabled, only need use 0x1f - if (min_bus == 0) + if (link->secondary == 0) max_devfn = (0x17<<3) | 7; else max_devfn = (0x1f<<3) | 7; diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index d96e113..8fe38ff 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -93,7 +93,6 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ u32 busses, config_busses; u32 free_reg, config_reg; u32 ht_unitid_base[4]; // here assume only 4 HT device on chain - u32 min_bus; u32 max_devfn;
link->cap = 0x80 + (link->link_num * 0x20); @@ -141,19 +140,18 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ * so we set the subordinate bus number to 0xff for the moment. */ if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) { - min_bus = ++max; + max++; } else if (is_sblink) { - // first chain will on bus 0 - min_bus = max; /* actually max is 0 here */ + } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 == 1) { - min_bus = ++max; + max++; } else if (CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) { // second chain will be on 0x40, third 0x80, forth 0xc0 - min_bus = (max & ~0x3f) + 0x40; - max = min_bus; + max++; + max = ALIGN_UP(max, 0x40); }
- link->secondary = min_bus; + link->secondary = max; link->subordinate = 0xff;
/* Read the existing primary/secondary/subordinate bus @@ -188,7 +186,7 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ ht_unitid_base[i] = 0x20; }
