Attention is currently required from: Andrey Pronin, Aseda Aboagye, Aaron Durbin. Julius Werner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/52919 )
Change subject: chromeos/Kconfig: Add TPM20_CREATE_FWMP ......................................................................
Patch Set 5:
(4 comments)
Patchset:
PS5:
I added a new API in vboot_reference. […]
You need to uprev the submodule. First, the vboot change needs to get merged. Then, go into your coreboot checkout, cd into 3rdparty/vboot, fetch and checkout the new updated main branch (you may need to add it separately as a remote first), then go back into the coreboot toplevel directory and you can check that in like a commit. See older patches like CB:47784
File src/security/vboot/secdata_tpm.c:
https://review.coreboot.org/c/coreboot/+/52919/comment/196abef7_ba4dca5f PS1, Line 243: rv = tlcl_define_space(FWMP_NV_INDEX, VB2_SECDATA_FWMP_MAX_SIZE,
I'm initializing the space now.
Well, reading through the TPM spec I guess it should actually return TPM_RC_NV_UNINITIALIZED, but that's not good either. We have special consideration for the FMWP not existing at all (BADINDEX) in depthcharge, but not for any other error code. See depthcharge/src/vboot/secdata_tpm.c#secdata_fwmp_read()
https://review.coreboot.org/c/coreboot/+/52919/comment/a69f1641_a0397001 PS5, Line 200: VB2_SECDATA_FWMP_MAX_SIZE Actually, thinking it through again this needs to be the size of the currently used FWMP structure, not MAX_SIZE (see explanation in CL:2875533 for the difference). That size should really come from the result of the create() function. Maybe we should reshuffle these set_xxx_space() functions a bit so they take the whole context pointer and call the respective create() function themselves so they can use that result right away (and maybe they should be called setup_xxx_space() or something? Just "set" sounds more like (over-)writing than creating...).
File src/vendorcode/google/chromeos/Kconfig:
https://review.coreboot.org/c/coreboot/+/52919/comment/1db82b80_2d24598a PS1, Line 95: config TPM20_CREATE_FWMP
(sorry, missed this comment earlier) I had the same question myself. […]
Let's just switch all boards over at once and avoid more fragmentation.
