Tao Xia has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/56828 )
Change subject: mb/google/dedede/var/storo: Fixed iasl can not run on Dut ......................................................................
The TSR1._PSV has been redefined. It will report errors when disassembling the ACPI tables with the iasl. It is OK when Removing the TSR1._PSV and adding the TSR0._PSV
BUG=b:194509417 BRANCH=dedede TEST=The iasl can run on Dut successfully
Signed-off-by: Tao Xia xiatao5@huaqin.corp-partner.google.com Change-Id: I524255c79d3c71573d122944da5058389f79d95d --- M src/mainboard/google/dedede/variants/storo/overridetree.cb 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/56828/1
diff --git a/src/mainboard/google/dedede/variants/storo/overridetree.cb b/src/mainboard/google/dedede/variants/storo/overridetree.cb index aedb285..90ad9ad 100644 --- a/src/mainboard/google/dedede/variants/storo/overridetree.cb +++ b/src/mainboard/google/dedede/variants/storo/overridetree.cb @@ -86,7 +86,7 @@ chip drivers/intel/dptf ## Passive Policy register "policies.passive" = "{ - [0] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 67, 3000), + [0] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 67, 3000), [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_2, 67, 3000), [2] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_1, 67, 3000),}" ## Critical Policy
