Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38359 )
Change subject: nb/intel/nehalem: Try to clean up code ......................................................................
Looks like raminit.c desperately needs a serious refactor.
Using BUILD_TIMELESS=1, this does not change packardbell/ms2290 builds.
Change-Id: I4d2501317faf3e4a7cf8a0ccb471d334232bfeae Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/nehalem/acpi.c M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/finalize.c M src/northbridge/intel/nehalem/gma.c M src/northbridge/intel/nehalem/nehalem.h M src/northbridge/intel/nehalem/northbridge.c M src/northbridge/intel/nehalem/raminit.c 7 files changed, 1,504 insertions(+), 1,686 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/1
diff --git a/src/northbridge/intel/nehalem/acpi.c b/src/northbridge/intel/nehalem/acpi.c index 462cdc0..42d7efe 100644 --- a/src/northbridge/intel/nehalem/acpi.c +++ b/src/northbridge/intel/nehalem/acpi.c @@ -38,32 +38,34 @@
switch ((pciexbar_reg >> 1) & 3) { case 0: // 256MB - pciexbar = - pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | - (1 << 28)); + pciexbar = pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | (1 << 28)); + max_buses = 256; break; + case 1: // 128M - pciexbar = - pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | - (1 << 28) | (1 << 27)); + pciexbar = pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | (1 << 28) + | (1 << 27)); + max_buses = 128; break; + case 2: // 64M - pciexbar = - pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | - (1 << 28) | (1 << 27) | (1 << 26)); + pciexbar = pciexbar_reg & ((1 << 31) | (1 << 30) | (1 << 29) | (1 << 28) + | (1 << 27) | (1 << 26)); + max_buses = 64; break; - default: // RSVD + + default: // RSVD return current; }
if (!pciexbar) return current;
- current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *) current, - pciexbar, 0x0, 0x0, max_buses - 1); + current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *) current, pciexbar, 0x0, + 0x0, max_buses - 1);
return current; } diff --git a/src/northbridge/intel/nehalem/early_init.c b/src/northbridge/intel/nehalem/early_init.c index a809121..f81ade4 100644 --- a/src/northbridge/intel/nehalem/early_init.c +++ b/src/northbridge/intel/nehalem/early_init.c @@ -41,23 +41,27 @@ printk(BIOS_DEBUG, " done.\n");
printk(BIOS_DEBUG, "Disabling Watchdog reboot..."); + /* No reset */ RCBA32(GCS) = RCBA32(GCS) | (1 << 5); + /* halt timer */ outw((1 << 11), DEFAULT_PMBASE | 0x60 | 0x08); + /* halt timer */ - outw(inw(DEFAULT_PMBASE | 0x60 | 0x06) | 2, - DEFAULT_PMBASE | 0x60 | 0x06); + outw(inw(DEFAULT_PMBASE | 0x60 | 0x06) | 2, DEFAULT_PMBASE | 0x60 | 0x06); + printk(BIOS_DEBUG, " done.\n");
printk(BIOS_DEBUG, "Setting up static northbridge registers..."); + /* Set up all hardcoded northbridge BARs */ pci_write_config32(PCI_DEV(0, 0x00, 0), EPBAR, DEFAULT_EPBAR | 1); - pci_write_config32(PCI_DEV(0, 0x00, 0), EPBAR + 4, - (0LL + DEFAULT_EPBAR) >> 32); + pci_write_config32(PCI_DEV(0, 0x00, 0), EPBAR + 4, (0LL + DEFAULT_EPBAR) >> 32); + pci_write_config32(PCI_DEV(0, 0x00, 0), MCHBAR, (uintptr_t)DEFAULT_MCHBAR | 1); pci_write_config32(PCI_DEV(0, 0x00, 0), MCHBAR + 4, - (0LL + (uintptr_t)DEFAULT_MCHBAR) >> 32); + (0LL + (uintptr_t)DEFAULT_MCHBAR) >> 32);
pci_write_config32(PCI_DEV(0, 0x00, 0), DMIBAR, (uintptr_t)DEFAULT_DMIBAR | 1); pci_write_config32(PCI_DEV(0, 0x00, 0), DMIBAR + 4, @@ -82,12 +86,12 @@ /* bit 0 = disable multicore, bit 1 = disable quadcore, bit 8 = disable hyperthreading. */ - pci_write_config32(PCI_DEV(0xff, 0x00, 0), 0x80, - (pci_read_config32(PCI_DEV(0xff, 0x0, 0x0), 0x80) & 0xfffffefc) | 0x10000); + pci_write_config32(PCI_DEV(0xff, 0x0, 0), 0x80, (pci_read_config32( + PCI_DEV(0xff, 0x0, 0), 0x80) & 0xfffffefc) | 0x10000);
u8 reg8; - struct cpuid_result result; - result = cpuid_ext(0x6, 0x8b); + struct cpuid_result result = cpuid_ext(0x6, 0x8b); + if (!(result.eax & 0x2)) { m = rdmsr(MSR_FSB_CLOCK_VCC); reg8 = ((m.lo & 0xff00) >> 8) + 1; @@ -122,6 +126,7 @@
/* Device ID Override Enable should be done very early */ capid0_a = pci_read_config32(PCI_DEV(0, 0, 0), 0xe4); + if (capid0_a & (1 << 10)) { reg8 = pci_read_config8(PCI_DEV(0, 0, 0), 0xf3); reg8 &= ~7; /* Clear 2:0 */ @@ -136,21 +141,20 @@ nehalem_setup_bars();
s3_resume = (inw(DEFAULT_PMBASE + PM1_STS) & WAK_STS) && - (((inl(DEFAULT_PMBASE + PM1_CNT) >> 10) & 7) == SLP_TYP_S3); + (((inl(DEFAULT_PMBASE + PM1_CNT) >> 10) & 7) == SLP_TYP_S3);
elog_boot_notify(s3_resume);
/* Device Enable */ - pci_write_config32(PCI_DEV(0, 0, 0), D0F0_DEVEN, - DEVEN_IGD | DEVEN_PEG10 | DEVEN_HOST); + pci_write_config32(PCI_DEV(0, 0, 0), D0F0_DEVEN, DEVEN_IGD | DEVEN_PEG10 | DEVEN_HOST);
early_cpu_init();
pci_write_config32(PCI_DEV(0, 0x16, 0), 0x10, (uintptr_t)DEFAULT_HECIBAR); - pci_write_config32(PCI_DEV(0, 0x16, 0), PCI_COMMAND, - PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY); + pci_write_config32(PCI_DEV(0, 0x16, 0), PCI_COMMAND, PCI_COMMAND_MASTER | + PCI_COMMAND_MEMORY);
- /* Magic for S3 resume. Must be done early. */ + /* Magic for S3 resume. Must be done early. */ if (s3_resume) { MCHBAR32 (0x1e8) = (MCHBAR32(0x1e8) & ~1) | 6; MCHBAR32 (0x1e8) = (MCHBAR32(0x1e8) & ~3) | 4; diff --git a/src/northbridge/intel/nehalem/finalize.c b/src/northbridge/intel/nehalem/finalize.c index c03b067..c197f1b 100644 --- a/src/northbridge/intel/nehalem/finalize.c +++ b/src/northbridge/intel/nehalem/finalize.c @@ -16,8 +16,6 @@
#include "nehalem.h"
-#define PCI_DEV_SNB PCI_DEV(0, 0, 0) - void intel_nehalem_finalize_smm(void) { MCHBAR32_OR(0x5500, 1 << 0); /* PAVP */ diff --git a/src/northbridge/intel/nehalem/gma.c b/src/northbridge/intel/nehalem/gma.c index d717e48..fa07601 100644 --- a/src/northbridge/intel/nehalem/gma.c +++ b/src/northbridge/intel/nehalem/gma.c @@ -35,11 +35,10 @@ #include "chip.h" #include "nehalem.h"
-/* some vga option roms are used for several chipsets but they only have one - * PCI ID in their header. If we encounter such an option rom, we need to do - * the mapping ourselves +/* + * Some VGA option roms are used for several chipsets, but they only have one PCI ID in their + * header. If we encounter such an option rom, we need to do the mapping ourselves */ - u32 map_oprom_vendev(u32 vendev) { u32 new_vendev = vendev; @@ -71,6 +70,7 @@ data = gtt_read(reg); if ((data & mask) == value) return 1; + udelay(10); }
@@ -148,15 +148,15 @@ { u16 reg16;
- /* clear DMISCI status */ + /* Clear DMISCI status */ reg16 = inw(DEFAULT_PMBASE + TCO1_STS); reg16 &= DMISCI_STS; outw(DEFAULT_PMBASE + TCO1_STS, reg16);
- /* clear acpi tco status */ + /* Clear ACPI TCO status */ outl(DEFAULT_PMBASE + GPE0_STS, TCOSCI_STS);
- /* enable acpi tco scis */ + /* Enable ACPI TCO SCIs */ reg16 = inw(DEFAULT_PMBASE + GPE0_EN); reg16 |= TCOSCI_EN; outw(DEFAULT_PMBASE + GPE0_EN, reg16); @@ -175,16 +175,16 @@ if (!gtt_res || !gtt_res->base) return;
- if (!acpi_is_wakeup_s3() && - CONFIG(MAINBOARD_USE_LIBGFXINIT)) { + if (!acpi_is_wakeup_s3() && CONFIG(MAINBOARD_USE_LIBGFXINIT)) { + struct northbridge_intel_nehalem_config *conf = dev->chip_info; int lightup_ok; printk(BIOS_SPEW, "Initializing VGA without OPROM.");
gma_gfxinit(&lightup_ok); + /* Linux relies on VBT for panel info. */ - generate_fake_intel_oprom(&conf->gfx, dev, - "$VBT IRONLAKE-MOBILE"); + generate_fake_intel_oprom(&conf->gfx, dev, "$VBT IRONLAKE-MOBILE"); } else { /* PCI Init, will run VBIOS */ pci_dev_init(dev); @@ -216,8 +216,7 @@ res->size = (resource_t) 0x10000000; }
-const struct i915_gpu_controller_info * -intel_gma_get_controller_info(void) +const struct i915_gpu_controller_info *intel_gma_get_controller_info(void) { struct device *dev = pcidev_on_root(0x2, 0); if (!dev) { @@ -237,10 +236,8 @@ drivers_intel_gma_displays_ssdt_generate(gfx); }
-static unsigned long -gma_write_acpi_tables(struct device *const dev, - unsigned long current, - struct acpi_rsdp *const rsdp) +static unsigned long gma_write_acpi_tables(struct device *const dev, unsigned long current, + struct acpi_rsdp *const rsdp) { igd_opregion_t *opregion = (igd_opregion_t *)current; global_nvs_t *gnvs; @@ -255,6 +252,7 @@ if (gnvs) { /* IGD OpRegion Base Address */ gma_set_gnvs_aslb(gnvs, (uintptr_t)opregion); + } else { printk(BIOS_ERR, "Error: GNVS table not found.\n"); } @@ -276,14 +274,12 @@ .scan_bus = 0, .enable = 0, .ops_pci = &gma_pci_ops, - .write_acpi_tables = gma_write_acpi_tables, + .write_acpi_tables = gma_write_acpi_tables, };
+/* FIXME: Looks like some of these are for SNB/IVB. */ static const unsigned short pci_device_ids[] = { - 0x0046, 0x0102, 0x0106, 0x010a, 0x0112, - 0x0116, 0x0122, 0x0126, 0x0156, - 0x0166, - 0 + 0x0046, 0x0102, 0x0106, 0x010a, 0x0112, 0x0116, 0x0122, 0x0126, 0x0156, 0x0166, 0 };
static const struct pci_driver gma __pci_driver = { diff --git a/src/northbridge/intel/nehalem/nehalem.h b/src/northbridge/intel/nehalem/nehalem.h index 493c5b1..5705109 100644 --- a/src/northbridge/intel/nehalem/nehalem.h +++ b/src/northbridge/intel/nehalem/nehalem.h @@ -35,7 +35,7 @@
/* The setup is one DIMM per channel, so there's no need to find a common timing setup between multiple chips (but chip and controller - still need to be coordinated */ + still need to be coordinated) */ typedef struct { int txt_enabled; int cores; @@ -52,83 +52,73 @@
#define DEFAULT_HECIBAR ((u8 *)0xfed17000)
- -#define IOMMU_BASE1 0xfed90000 -#define IOMMU_BASE2 0xfed91000 -#define IOMMU_BASE3 0xfed92000 -#define IOMMU_BASE4 0xfed93000 +#define IOMMU_BASE1 0xfed90000 +#define IOMMU_BASE2 0xfed91000 +#define IOMMU_BASE3 0xfed92000 +#define IOMMU_BASE4 0xfed93000
/* * D0:F0 */ -#define D0F0_EPBAR_LO 0x40 -#define D0F0_EPBAR_HI 0x44 -#define D0F0_MCHBAR_LO 0x48 -#define D0F0_MCHBAR_HI 0x4c -#define D0F0_GGC 0x52 -#define D0F0_DEVEN 0x54 -#define DEVEN_IGD (1 << 3) -#define DEVEN_PEG10 (1 << 1) -#define DEVEN_HOST (1 << 0) -#define D0F0_PCIEXBAR_LO 0x60 -#define D0F0_PCIEXBAR_HI 0x64 -#define D0F0_DMIBAR_LO 0x68 -#define D0F0_DMIBAR_HI 0x6c -#define D0F0_PMBASE 0x78 -#define QPD0F1_PAM(x) (0x40+(x)) /* 0-6*/ -#define D0F0_REMAPBASE 0x98 -#define D0F0_REMAPLIMIT 0x9a -#define D0F0_TOM 0xa0 -#define D0F0_TOUUD 0xa2 -#define D0F0_IGD_BASE 0xa4 -#define D0F0_GTT_BASE 0xa8 -#define D0F0_TOLUD 0xb0 -#define D0F0_SKPD 0xdc /* Scratchpad Data */ +#define D0F0_EPBAR_LO 0x40 +#define D0F0_EPBAR_HI 0x44 +#define D0F0_MCHBAR_LO 0x48 +#define D0F0_MCHBAR_HI 0x4c +#define D0F0_GGC 0x52 +#define D0F0_DEVEN 0x54 +#define DEVEN_IGD (1 << 3) +#define DEVEN_PEG10 (1 << 1) +#define DEVEN_HOST (1 << 0) +#define D0F0_PCIEXBAR_LO 0x60 +#define D0F0_PCIEXBAR_HI 0x64 +#define D0F0_DMIBAR_LO 0x68 +#define D0F0_DMIBAR_HI 0x6c +#define D0F0_PMBASE 0x78 +#define QPD0F1_PAM(x) (0x40+(x)) /* 0-6*/ +#define D0F0_REMAPBASE 0x98 +#define D0F0_REMAPLIMIT 0x9a +#define D0F0_TOM 0xa0 +#define D0F0_TOUUD 0xa2 +#define D0F0_IGD_BASE 0xa4 +#define D0F0_GTT_BASE 0xa8 +#define D0F0_TOLUD 0xb0 +#define D0F0_SKPD 0xdc /* Scratchpad Data */
-#define D0F0_CAPID0 0xe0 +#define D0F0_CAPID0 0xe0
-#define TSEG 0xac /* TSEG base */ +#define TSEG 0xac /* TSEG base */
/* * D1:F0 PEG */ -#define PEG_CAP 0xa2 -#define SLOTCAP 0xb4 -#define PEGLC 0xec -#define D1F0_VCCAP 0x104 -#define D1F0_VC0RCTL 0x114 +#define PEG_CAP 0xa2 +#define SLOTCAP 0xb4 +#define PEGLC 0xec +#define D1F0_VCCAP 0x104 +#define D1F0_VC0RCTL 0x114
/* Chipset types */ #define NEHALEM_MOBILE 0 #define NEHALEM_DESKTOP 1 #define NEHALEM_SERVER 2
-/* Device ID for SandyBridge and IvyBridge */ +/* Device ID for SandyBridge */ #define BASE_REV_SNB 0x00 -#define BASE_REV_IVB 0x50 #define BASE_REV_MASK 0x50
/* SandyBridge CPU stepping */ #define SNB_STEP_D0 (BASE_REV_SNB + 5) /* Also J0 */ #define SNB_STEP_D1 (BASE_REV_SNB + 6) -#define SNB_STEP_D2 (BASE_REV_SNB + 7) /* Also J1/Q0 */ - -/* IvyBridge CPU stepping */ -#define IVB_STEP_A0 (BASE_REV_IVB + 0) -#define IVB_STEP_B0 (BASE_REV_IVB + 2) -#define IVB_STEP_C0 (BASE_REV_IVB + 4) -#define IVB_STEP_K0 (BASE_REV_IVB + 5) -#define IVB_STEP_D0 (BASE_REV_IVB + 6)
/* Northbridge BARs */ #ifndef __ACPI__ #define DEFAULT_MCHBAR ((u8 *)0xfed10000) /* 16 KB */ #define DEFAULT_DMIBAR ((u8 *)0xfed18000) /* 4 KB */ #else -#define DEFAULT_MCHBAR 0xfed10000 /* 16 KB */ -#define DEFAULT_DMIBAR 0xfed18000 /* 4 KB */ +#define DEFAULT_MCHBAR 0xfed10000 /* 16 KB */ +#define DEFAULT_DMIBAR 0xfed18000 /* 4 KB */ #endif -#define DEFAULT_EPBAR 0xfed19000 /* 4 KB */ +#define DEFAULT_EPBAR 0xfed19000 /* 4 KB */ #define DEFAULT_RCBABASE ((u8 *)0xfed1c000)
#define QUICKPATH_BUS 0xff @@ -138,8 +128,9 @@ /* Everything below this line is ignored in the DSDT */ #ifndef __ACPI__
-/* Device 0:0.0 PCI configuration space (Host Bridge) */ - +/* + * Device 0:0.0 PCI configuration space (Host Bridge) + */ #define EPBAR 0x40 #define MCHBAR 0x48 #define PCIEXBAR 0x60 @@ -147,41 +138,37 @@ #define X60BAR 0x60
#define LAC 0x87 /* Legacy Access Control */ -#define QPD0F1_SMRAM 0x4d /* System Management RAM Control */ +#define QPD0F1_SMRAM 0x4d /* System Management RAM Control */
#define SKPAD 0xdc /* Scratchpad Data */
- -/* Device 0:2.0 PCI configuration space (Graphics Device) */ - +/* + * Device 0:2.0 PCI configuration space (Graphics Device) + */ #define MSAC 0x62 /* Multi Size Aperture Control */
/* * MCHBAR */ +#define MCHBAR8(x) (*((volatile u8 *) (DEFAULT_MCHBAR + (x)))) +#define MCHBAR16(x) (*((volatile u16 *)(DEFAULT_MCHBAR + (x)))) +#define MCHBAR32(x) (*((volatile u32 *)(DEFAULT_MCHBAR + (x)))) +#define MCHBAR8_AND(x, and) (MCHBAR8(x) = MCHBAR8(x) & (and)) +#define MCHBAR16_AND(x, and) (MCHBAR16(x) = MCHBAR16(x) & (and)) +#define MCHBAR32_AND(x, and) (MCHBAR32(x) = MCHBAR32(x) & (and)) +#define MCHBAR8_OR(x, or) (MCHBAR8(x) = MCHBAR8(x) | (or)) +#define MCHBAR16_OR(x, or) (MCHBAR16(x) = MCHBAR16(x) | (or)) +#define MCHBAR32_OR(x, or) (MCHBAR32(x) = MCHBAR32(x) | (or)) +#define MCHBAR8_AND_OR(x, and, or) (MCHBAR8(x) = (MCHBAR8(x) & (and)) | (or)) +#define MCHBAR16_AND_OR(x, and, or) (MCHBAR16(x) = (MCHBAR16(x) & (and)) | (or)) +#define MCHBAR32_AND_OR(x, and, or) (MCHBAR32(x) = (MCHBAR32(x) & (and)) | (or))
-#define MCHBAR8(x) (*((volatile u8 *)(DEFAULT_MCHBAR + (x)))) -#define MCHBAR16(x) (*((volatile u16 *)(DEFAULT_MCHBAR + (x)))) -#define MCHBAR32(x) (*((volatile u32 *)(DEFAULT_MCHBAR + (x)))) -#define MCHBAR8_AND(x, and) (MCHBAR8(x) = MCHBAR8(x) & (and)) -#define MCHBAR8_OR(x, or) (MCHBAR8(x) = MCHBAR8(x) | (or)) -#define MCHBAR8_AND_OR(x, and, or) \ - (MCHBAR8(x) = (MCHBAR8(x) & (and)) | (or)) -#define MCHBAR16_AND(x, and) (MCHBAR16(x) = MCHBAR16(x) & (and)) -#define MCHBAR16_OR(x, or) (MCHBAR16(x) = MCHBAR16(x) | (or)) -#define MCHBAR16_AND_OR(x, and, or) \ - (MCHBAR16(x) = (MCHBAR16(x) & (and)) | (or)) -#define MCHBAR32_AND(x, and) (MCHBAR32(x) = MCHBAR32(x) & (and)) -#define MCHBAR32_OR(x, or) (MCHBAR32(x) = MCHBAR32(x) | (or)) -#define MCHBAR32_AND_OR(x, and, or) \ - (MCHBAR32(x) = (MCHBAR32(x) & (and)) | (or)) /* * EPBAR - Egress Port Root Complex Register Block */ - -#define EPBAR8(x) (*((volatile u8 *)(DEFAULT_EPBAR + (x)))) -#define EPBAR16(x) (*((volatile u16 *)(DEFAULT_EPBAR + (x)))) -#define EPBAR32(x) (*((volatile u32 *)(DEFAULT_EPBAR + (x)))) +#define EPBAR8(x) (*((volatile u8 *) (DEFAULT_EPBAR + (x)))) +#define EPBAR16(x) (*((volatile u16 *)(DEFAULT_EPBAR + (x)))) +#define EPBAR32(x) (*((volatile u32 *)(DEFAULT_EPBAR + (x))))
#define EPPVCCAP1 0x004 /* 32bit */ #define EPPVCCAP2 0x008 /* 32bit */ @@ -209,10 +196,9 @@ /* * DMIBAR */ - -#define DMIBAR8(x) (*((volatile u8 *)(DEFAULT_DMIBAR + (x)))) -#define DMIBAR16(x) (*((volatile u16 *)(DEFAULT_DMIBAR + (x)))) -#define DMIBAR32(x) (*((volatile u32 *)(DEFAULT_DMIBAR + (x)))) +#define DMIBAR8(x) (*((volatile u8 *) (DEFAULT_DMIBAR + (x)))) +#define DMIBAR16(x) (*((volatile u16 *)(DEFAULT_DMIBAR + (x)))) +#define DMIBAR32(x) (*((volatile u32 *)(DEFAULT_DMIBAR + (x))))
#define DMIVCECH 0x000 /* 32bit */ #define DMIPVCCAP1 0x004 /* 32bit */ @@ -246,9 +232,6 @@
#ifndef __ASSEMBLER__
-#define PCI_DEVICE_ID_SB 0x0104 -#define PCI_DEVICE_ID_IB 0x0154 - void intel_nehalem_finalize_smm(void);
int bridge_silicon_revision(void); diff --git a/src/northbridge/intel/nehalem/northbridge.c b/src/northbridge/intel/nehalem/northbridge.c index 1718307..bd4fc47 100644 --- a/src/northbridge/intel/nehalem/northbridge.c +++ b/src/northbridge/intel/nehalem/northbridge.c @@ -34,10 +34,10 @@ int bridge_silicon_revision(void) { if (bridge_revision_id < 0) { - uint8_t stepping = cpuid_eax(1) & 0xf; + uint8_t stepping = cpuid_eax(1) & 0xf; uint8_t bridge_id = - pci_read_config16(pcidev_on_root(0, 0), - PCI_DEVICE_ID) & 0xf0; + pci_read_config16(pcidev_on_root(0, 0), PCI_DEVICE_ID) & 0xf0; + bridge_revision_id = bridge_id | stepping; } return bridge_revision_id; @@ -67,13 +67,12 @@ resource = new_resource(dev, index++); resource->base = (resource_t) 0xfed00000; resource->size = (resource_t) 0x00100000; - resource->flags = IORESOURCE_MEM | IORESOURCE_RESERVE | - IORESOURCE_FIXED | IORESOURCE_STORED | IORESOURCE_ASSIGNED; + resource->flags = IORESOURCE_MEM | IORESOURCE_RESERVE | IORESOURCE_FIXED | + IORESOURCE_STORED | IORESOURCE_ASSIGNED;
- mmio_resource(dev, index++, legacy_hole_base_k, - (0xc0000 >> 10) - legacy_hole_base_k); - reserved_ram_resource(dev, index++, 0xc0000 >> 10, - (0x100000 - 0xc0000) >> 10); + mmio_resource(dev, index++, legacy_hole_base_k, (0xc0000 >> 10) - legacy_hole_base_k); + + reserved_ram_resource(dev, index++, 0xc0000 >> 10, (0x100000 - 0xc0000) >> 10);
#if CONFIG(CHROMEOS_RAMOOPS) reserved_ram_resource(dev, index++, @@ -127,8 +126,7 @@ mmconf_resource(dev, 0x50);
tseg_base = pci_read_config32(pcidev_on_root(0, 0), TSEG); - TOUUD = pci_read_config16(pcidev_on_root(0, 0), - D0F0_TOUUD); + TOUUD = pci_read_config16(pcidev_on_root(0, 0), D0F0_TOUUD);
printk(BIOS_DEBUG, "ram_before_4g_top: 0x%x\n", tseg_base); printk(BIOS_DEBUG, "TOUUD: 0x%x\n", (unsigned int)TOUUD); @@ -140,22 +138,23 @@ mmio_resource(dev, 5, tseg_base >> 10, CONFIG_SMM_TSEG_SIZE >> 10);
reg16 = pci_read_config16(pcidev_on_root(0, 0), D0F0_GGC); - const int uma_sizes_gtt[16] = - { 0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4, 42, 42, 42, 42 }; - /* Igd memory */ + + const int uma_sizes_gtt[16] = { 0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4, 42, 42, 42, 42 }; + + /* IGD memory */ const int uma_sizes_igd[16] = { 0, 0, 0, 0, 0, 32, 48, 64, 128, 256, 96, 160, 224, 352, 256, 512 }; + u32 igd_base, gtt_base; int uma_size_igd, uma_size_gtt;
- uma_size_igd = uma_sizes_igd[(reg16 >> 4) & 0xF]; - uma_size_gtt = uma_sizes_gtt[(reg16 >> 8) & 0xF]; + uma_size_igd = uma_sizes_igd[(reg16 >> 4) & 0xf]; + uma_size_gtt = uma_sizes_gtt[(reg16 >> 8) & 0xf];
- igd_base = - pci_read_config32(pcidev_on_root(0, 0), D0F0_IGD_BASE); - gtt_base = - pci_read_config32(pcidev_on_root(0, 0), D0F0_GTT_BASE); + igd_base = pci_read_config32(pcidev_on_root(0, 0), D0F0_IGD_BASE); + gtt_base = pci_read_config32(pcidev_on_root(0, 0), D0F0_GTT_BASE); + mmio_resource(dev, 6, gtt_base >> 10, uma_size_gtt << 10); mmio_resource(dev, 7, igd_base >> 10, uma_size_igd << 10);
@@ -199,6 +198,7 @@ reg32 = DMIBAR32(0x1f8); reg32 |= (1 << 16); DMIBAR32(0x1f8) = reg32; + } else if (bridge_silicon_revision() >= SNB_STEP_D1) { reg32 = DMIBAR32(0x1f8); reg32 &= ~(1 << 26); @@ -210,7 +210,11 @@ DMIBAR32(0x1fc) = reg32; }
- /* Enable ASPM on SNB link, should happen before PCH link */ + /* + * Enable ASPM on SNB link, should happen before PCH link. + * + * FIXME: This is not Sandy Bridge! Is this correct? + */ if ((bridge_silicon_revision() & BASE_REV_MASK) == BASE_REV_SNB) { reg32 = DMIBAR32(0xd04); reg32 |= (1 << 4); @@ -282,6 +286,7 @@ /* Set the operations if it is a special bus type */ if (dev->path.type == DEVICE_PATH_DOMAIN) { dev->ops = &pci_domain_ops; + } else if (dev->path.type == DEVICE_PATH_CPU_CLUSTER) { dev->ops = &cpu_bus_ops; } diff --git a/src/northbridge/intel/nehalem/raminit.c b/src/northbridge/intel/nehalem/raminit.c index 7735522..852e733 100644 --- a/src/northbridge/intel/nehalem/raminit.c +++ b/src/northbridge/intel/nehalem/raminit.c @@ -44,11 +44,11 @@ #include "raminit.h" #include "raminit_tables.h"
-#define NORTHBRIDGE PCI_DEV(0, 0, 0) -#define SOUTHBRIDGE PCI_DEV(0, 0x1f, 0) -#define GMA PCI_DEV (0, 0x2, 0x0) -#define HECIDEV PCI_DEV(0, 0x16, 0) -#define HECIBAR 0x10 +#define NORTHBRIDGE PCI_DEV(0, 0, 0) +#define SOUTHBRIDGE PCI_DEV(0, 0x1f, 0) +#define GMA PCI_DEV(0, 0x2, 0x0) +#define HECIDEV PCI_DEV(0, 0x16, 0) +#define HECIBAR 0x10
#define FOR_ALL_RANKS \ for (channel = 0; channel < NUM_CHANNELS; channel++) \ @@ -125,8 +125,7 @@ MCHBAR32(0x1d0) = 0; while (MCHBAR32(0x1d0) & 0x800000) ; - MCHBAR32(0x1d4) = - (val & ((1 << bits) - 1)) | (2 << bits) | (flag << bits); + MCHBAR32(0x1d4) = (val & ((1 << bits) - 1)) | (2 << bits) | (flag << bits); MCHBAR32(0x1d0) = 0x40000000 | addr; while (MCHBAR32(0x1d0) & 0x800000) ; @@ -139,8 +138,7 @@ MCHBAR32(0x1d0) = 0; while (MCHBAR32(0x1d0) & 0x800000) ; - MCHBAR32(0x1d0) = - 0x80000000 | (((MCHBAR8(0x246) >> 2) & 3) + 0x361 - addr); + MCHBAR32(0x1d0) = 0x80000000 | (((MCHBAR8(0x246) >> 2) & 3) + 0x361 - addr); while (MCHBAR32(0x1d0) & 0x800000) ; val = MCHBAR32(0x1d8); @@ -187,10 +185,10 @@ #define gav(x) gav_real (__LINE__, (x))
struct raminfo { - u16 clock_speed_index; /* clock_speed (REAL, not DDR) / 133.(3) - 3 */ - u16 fsb_frequency; /* in 1.(1)/2 MHz. */ - u8 is_x16_module[2][2]; /* [CHANNEL][SLOT] */ - u8 density[2][2]; /* [CHANNEL][SLOT] */ + u16 clock_speed_index; /* clock_speed (REAL, not DDR) / 133.(3) - 3 */ + u16 fsb_frequency; /* in 1.(1)/2 MHz. */ + u8 is_x16_module[2][2]; /* [CHANNEL][SLOT] */ + u8 density[2][2]; /* [CHANNEL][SLOT] */ u8 populated_ranks[2][2][2]; /* [CHANNEL][SLOT][RANK] */ int rank_start[2][2][2]; u8 cas_latency; @@ -199,7 +197,7 @@ u8 revision; u8 max_supported_clock_speed_index; u8 uma_enabled; - u8 spd[2][2][151]; /* [CHANNEL][SLOT][BYTE] */ + u8 spd[2][2][151]; /* [CHANNEL][SLOT][BYTE] */ u8 silicon_revision; u8 populated_ranks_mask[2]; u8 max_slots_used_in_channel; @@ -230,13 +228,10 @@ /* Global allocation of timings_car */ timing_bounds_t timings_car[64];
-static void -write_500(struct raminfo *info, int channel, u32 val, u16 addr, int bits, - int flag); +static void write_500(struct raminfo *info, int channel, u32 val, u16 addr, int bits, int flag);
/* OK */ -static u16 -read_500(struct raminfo *info, int channel, u16 addr, int split) +static u16 read_500(struct raminfo *info, int channel, u16 addr, int split) { u32 val; info->last_500_command[channel] = 0x80000000; @@ -244,8 +239,7 @@ while (MCHBAR32(0x500 + (channel << 10)) & 0x800000) ; MCHBAR32(0x500 + (channel << 10)) = - 0x80000000 | (((MCHBAR8(0x246 + (channel << 10)) >> 2) & 3) - + 0xb88 - addr); + 0x80000000 | (((MCHBAR8(0x246 + (channel << 10)) >> 2) & 3) + 0xb88 - addr); while (MCHBAR32(0x500 + (channel << 10)) & 0x800000) ; val = MCHBAR32(0x508 + (channel << 10)); @@ -253,9 +247,7 @@ }
/* OK */ -static void -write_500(struct raminfo *info, int channel, u32 val, u16 addr, int bits, - int flag) +static void write_500(struct raminfo *info, int channel, u32 val, u16 addr, int bits, int flag) { if (info->last_500_command[channel] == 0x80000000) { info->last_500_command[channel] = 0x40000000; @@ -311,20 +303,16 @@ return ok; }
-static void -program_timings(struct raminfo *info, u16 base, int channel, int slot, int rank) +static void program_timings(struct raminfo *info, u16 base, int channel, int slot, int rank) { int lane; for (lane = 0; lane < 8; lane++) { - write_500(info, channel, - base + - info->training. - lane_timings[2][channel][slot][rank][lane], + write_500(info, channel, base + + info->training.lane_timings[2][channel][slot][rank][lane], get_timing_register_addr(lane, 2, slot, rank), 9, 0); - write_500(info, channel, - base + - info->training. - lane_timings[3][channel][slot][rank][lane], + + write_500(info, channel, base + + info->training.lane_timings[3][channel][slot][rank][lane], get_timing_register_addr(lane, 3, slot, rank), 9, 0); } } @@ -365,31 +353,21 @@ for (i = 0; i < 2; i++) for (lane = 0; lane < 8; lane++) write_500(info, channel, - info->training.lane_timings[i + - 1][channel][slot] - [rank][lane], get_timing_register_addr(lane, - i + 1, - slot, - rank), - 9, 0); + info->training.lane_timings[i + 1][channel][slot][rank][lane], + get_timing_register_addr(lane, i + 1, slot, rank), 9, 0);
write_1d0(1, 0x103, 6, 1); for (lane = 0; lane < 8; lane++) write_500(info, channel, - info->training. - lane_timings[0][channel][slot][rank][lane], + info->training.lane_timings[0][channel][slot][rank][lane], get_timing_register_addr(lane, 0, slot, rank), 9, 0);
for (i = 0; i < 2; i++) { for (lane = 0; lane < 8; lane++) write_500(info, channel, - info->training.lane_timings[i + - 1][channel][slot] - [rank][lane], get_timing_register_addr(lane, - i + 1, - slot, - rank), - 9, 0); + info->training.lane_timings[i + 1][channel][slot][rank][lane], + get_timing_register_addr(lane, i + 1, slot, rank), 9, 0); + gav(get_580(channel, ((i + 1) << 2) | (rank << 5))); }
@@ -398,14 +376,15 @@ MCHBAR8(0x5ff) = 0x80; write_1d0(0x2, 0x142, 3, 1); for (lane = 0; lane < 8; lane++) { - // printk (BIOS_ERR, "before: %x\n", info->training.lane_timings[2][channel][slot][rank][lane]); +// printk(BIOS_ERR, "before: %x\n", +// info->training.lane_timings[2][channel][slot][rank][lane]); info->training.lane_timings[2][channel][slot][rank][lane] = - read_500(info, channel, - get_timing_register_addr(lane, 2, slot, rank), 9); - //printk (BIOS_ERR, "after: %x\n", info->training.lane_timings[2][channel][slot][rank][lane]); + read_500(info, channel, get_timing_register_addr(lane, 2, slot, rank), 9); + +// printk(BIOS_ERR, "after: %x\n", +// info->training.lane_timings[2][channel][slot][rank][lane]); info->training.lane_timings[3][channel][slot][rank][lane] = - info->training.lane_timings[2][channel][slot][rank][lane] + - 0x20; + info->training.lane_timings[2][channel][slot][rank][lane] + 0x20; } }
@@ -419,8 +398,7 @@ return res; }
-static void -config_rank(struct raminfo *info, int s3resume, int channel, int slot, int rank) +static void config_rank(struct raminfo *info, int s3resume, int channel, int slot, int rank) { int add;
@@ -478,23 +456,19 @@ c = 0x5f5f;
for (k = 0; k < 2; k++) { - MCHBAR32(0x138 + 8 * k) = - (channel << 26) | (j << 24); + MCHBAR32(0x138 + 8 * k) = (channel << 26) | (j << 24); gav(vd8[1][(channel << 3) | (j << 1) | k] = - MCHBAR32(0x138 + 8 * k)); + MCHBAR32(0x138 + 8 * k)); gav(vd8[0][(channel << 3) | (j << 1) | k] = - MCHBAR32(0x13c + 8 * k)); + MCHBAR32(0x13c + 8 * k)); }
- MCHBAR32(0x334 + (channel << 10) + (j * 0x44)) = - zero ? 0 : val3[j]; + MCHBAR32(0x334 + (channel << 10) + (j * 0x44)) = zero ? 0 : val3[j]; MCHBAR32(0x32c + (channel << 10) + (j * 0x44)) = zero ? 0 : (0x18191819 & lmask); MCHBAR16(0x34a + (channel << 10) + (j * 0x44)) = c; - MCHBAR32(0x33c + (channel << 10) + (j * 0x44)) = - zero ? 0 : (a & lmask); - MCHBAR32(0x344 + (channel << 10) + (j * 0x44)) = - zero ? 0 : (a & lmask); + MCHBAR32(0x33c + (channel << 10) + (j * 0x44)) = zero ? 0 : (a & lmask); + MCHBAR32(0x344 + (channel << 10) + (j * 0x44)) = zero ? 0 : (a & lmask); } }
@@ -562,13 +536,9 @@ for (channel = 0; channel < NUM_CHANNELS; channel++) for (slot = 0; slot < NUM_SLOTS; slot++) if (info->populated_ranks[channel][slot][0]) - supported_cas_latencies &= - 2 * - (info-> - spd[channel][slot][CAS_LATENCIES_LSB] | - (info-> - spd[channel][slot][CAS_LATENCIES_MSB] << - 8)); + supported_cas_latencies &= 2 * + (info->spd[channel][slot][CAS_LATENCIES_LSB] | + (info->spd[channel][slot][CAS_LATENCIES_MSB] << 8));
max_clock_index = MIN(3, info->max_supported_clock_speed_index);
@@ -578,24 +548,20 @@ for (channel = 0; channel < NUM_CHANNELS; channel++) for (slot = 0; slot < NUM_SLOTS; slot++) if (info->populated_ranks[channel][slot][0]) { - unsigned int timebase; - timebase = - 1000 * - info-> - spd[channel][slot][TIMEBASE_DIVIDEND] / - info->spd[channel][slot][TIMEBASE_DIVISOR]; - cycletime = - MAX(cycletime, - timebase * + unsigned int timebase = 1000 + * info->spd[channel][slot][TIMEBASE_DIVIDEND] + / info->spd[channel][slot][TIMEBASE_DIVISOR]; + + cycletime = MAX(cycletime, timebase * info->spd[channel][slot][CYCLETIME]); - cas_latency_time = - MAX(cas_latency_time, - timebase * - info-> - spd[channel][slot][CAS_LATENCY_TIME]); + + cas_latency_time = MAX(cas_latency_time, timebase * + info->spd[channel][slot][CAS_LATENCY_TIME]); } + if (cycletime > min_cycletime[0]) die("RAM init: Decoded SPD DRAM freq is slower than the controller minimum!"); + for (clock_speed_index = 0; clock_speed_index < 3; clock_speed_index++) { if (cycletime == min_cycletime[clock_speed_index]) break; @@ -612,7 +578,7 @@ if (cas_latency <= min_cas_latency) break; supported_cas_latencies &= - ~(1 << find_highest_bit_set(supported_cas_latencies)); + ~(1 << find_highest_bit_set(supported_cas_latencies)); }
if (cas_latency != min_cas_latency && clock_speed_index) @@ -620,6 +586,7 @@
if (cas_latency * min_cycletime[clock_speed_index] > 20000) die("Couldn't configure DRAM"); + info->clock_speed_index = clock_speed_index; info->cas_latency = cas_latency; } @@ -635,139 +602,100 @@ if (info->silicon_revision == 0) for (channel = 0; channel < NUM_CHANNELS; channel++) for (slot = 0; slot < NUM_SLOTS; slot++) - if ((info-> - spd[channel][slot][MODULE_TYPE] & 0xF) == - 3) + if ((info->spd[channel][slot][MODULE_TYPE] & 0xf) == 3) extended_silicon_revision = 4;
for (channel = 0; channel < NUM_CHANNELS; channel++) { - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_SLOTS; rank++) { - int card_timing_2; - if (!info->populated_ranks[channel][slot][rank]) - continue; + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_SLOTS; rank++) {
- for (lane = 0; lane < 9; lane++) { - int tm_reg; - int card_timing; + int card_timing_2; + if (!info->populated_ranks[channel][slot][rank]) + continue;
- card_timing = 0; - if ((info-> - spd[channel][slot][MODULE_TYPE] & - 0xF) == 3) { - int reference_card; - reference_card = - info-> - spd[channel][slot] - [REFERENCE_RAW_CARD_USED] & - 0x1f; - if (reference_card == 3) - card_timing = - u16_ffd1188[0][lane] - [info-> - clock_speed_index]; - if (reference_card == 5) - card_timing = - u16_ffd1188[1][lane] - [info-> - clock_speed_index]; - } + for (lane = 0; lane < 9; lane++) { + int tm_reg; + int card_timing;
- info->training. - lane_timings[0][channel][slot][rank] - [lane] = - u8_FFFD1218[info-> - clock_speed_index]; - info->training. - lane_timings[1][channel][slot][rank] - [lane] = 256; + card_timing = 0; + if ((info->spd[channel][slot][MODULE_TYPE] & 0xf) == 3) { + int reference_card = info->spd[channel][slot] + [REFERENCE_RAW_CARD_USED] & 0x1f;
- for (tm_reg = 2; tm_reg < 4; tm_reg++) - info->training. - lane_timings[tm_reg] - [channel][slot][rank][lane] - = - u8_FFFD1240[channel] - [extended_silicon_revision] - [lane][2 * slot + - rank][info-> - clock_speed_index] - + info->max4048[channel] - + - u8_FFFD0C78[channel] - [extended_silicon_revision] - [info-> - mode4030[channel]][slot] - [rank][info-> - clock_speed_index] - + card_timing; - for (tm_reg = 0; tm_reg < 4; tm_reg++) - write_500(info, channel, - info->training. - lane_timings[tm_reg] - [channel][slot][rank] - [lane], - get_timing_register_addr - (lane, tm_reg, slot, - rank), 9, 0); + if (reference_card == 3) + card_timing = + u16_ffd1188[0][lane][info->clock_speed_index]; + + if (reference_card == 5) + card_timing = + u16_ffd1188[1][lane][info->clock_speed_index]; }
- card_timing_2 = 0; - if (!(extended_silicon_revision != 4 - || (info-> - populated_ranks_mask[channel] & 5) == - 5)) { - if ((info-> - spd[channel][slot] - [REFERENCE_RAW_CARD_USED] & 0x1F) - == 3) - card_timing_2 = - u16_FFFE0EB8[0][info-> - clock_speed_index]; - if ((info-> - spd[channel][slot] - [REFERENCE_RAW_CARD_USED] & 0x1F) - == 5) - card_timing_2 = - u16_FFFE0EB8[1][info-> - clock_speed_index]; + info->training.lane_timings[0][channel][slot][rank][lane] = + u8_FFFD1218[info->clock_speed_index]; + + info->training.lane_timings[1][channel][slot][rank][lane] = 256; + + for (tm_reg = 2; tm_reg < 4; tm_reg++) { + info->training.lane_timings[tm_reg][channel][slot] + [rank][lane] + = + u8_FFFD1240[channel][extended_silicon_revision][lane] + [2 * slot + rank][info->clock_speed_index] + + + info->max4048[channel] + + + u8_FFFD0C78[channel][extended_silicon_revision] + [info->mode4030[channel]][slot][rank] + [info->clock_speed_index] + + + card_timing; }
- for (i = 0; i < 3; i++) - write_500(info, channel, - (card_timing_2 + - info->max4048[channel] - + - u8_FFFD0EF8[channel] - [extended_silicon_revision] - [info-> - mode4030[channel]][info-> - clock_speed_index]), - u16_fffd0c50[i][slot][rank], - 8, 1); - write_500(info, channel, - (info->max4048[channel] + - u8_FFFD0C78[channel] - [extended_silicon_revision][info-> - mode4030 - [channel]] - [slot][rank][info-> - clock_speed_index]), - u16_fffd0c70[slot][rank], 7, 1); + for (tm_reg = 0; tm_reg < 4; tm_reg++) + write_500( + info, channel, + info->training.lane_timings + [tm_reg][channel][slot][rank][lane], + get_timing_register_addr(lane, tm_reg, slot, rank), + 9, 0 + ); } + + card_timing_2 = 0; + if (!(extended_silicon_revision != 4 + || (info->populated_ranks_mask[channel] & 5) == 5)) { + + if ((info->spd[channel][slot][REFERENCE_RAW_CARD_USED] & 0x1F) + == 3) + card_timing_2 = + u16_FFFE0EB8[0][info->clock_speed_index]; + if ((info->spd[channel][slot][REFERENCE_RAW_CARD_USED] & 0x1F) + == 5) + card_timing_2 = + u16_FFFE0EB8[1][info->clock_speed_index]; + } + + for (i = 0; i < 3; i++) + write_500(info, channel, (card_timing_2 + info->max4048[channel] + + u8_FFFD0EF8[channel][extended_silicon_revision] + [info->mode4030[channel]][info->clock_speed_index]), + u16_fffd0c50[i][slot][rank], 8, 1); + + write_500(info, channel, (info->max4048[channel] + u8_FFFD0C78[channel] + [extended_silicon_revision][info->mode4030[channel]][slot][rank] + [info->clock_speed_index]), u16_fffd0c70[slot][rank], 7, 1); + + }} /* for each slot, rank */ if (!info->populated_ranks_mask[channel]) continue; + for (i = 0; i < 3; i++) - write_500(info, channel, - (info->max4048[channel] + - info->avg4044[channel] - + - u8_FFFD17E0[channel] - [extended_silicon_revision][info-> - mode4030 - [channel]][info-> - clock_speed_index]), - u16_fffd0c68[i], 8, 1); + write_500( + info, channel, (info->max4048[channel] + info->avg4044[channel] + + u8_FFFD17E0[channel][extended_silicon_revision][info->mode4030[channel]] + [info->clock_speed_index]), u16_fffd0c68[i], 8, 1 + ); } }
@@ -828,89 +756,106 @@ if (!info->silicon_revision) for (channel = 0; channel < NUM_CHANNELS; channel++) for (slot = 0; slot < NUM_SLOTS; slot++) - if ((info-> - spd[channel][slot][MODULE_TYPE] & 0xF) == - 3) + if ((info->spd[channel][slot][MODULE_TYPE] & 0xF) == 3) extended_silicon_revision = 4; + if (info->board_lane_delay[7] < 5) info->board_lane_delay[7] = 5; + info->revision_flag_1 = 2; if (info->silicon_revision == 2 || info->silicon_revision == 3) info->revision_flag_1 = 0; + if (info->revision < 16) info->revision_flag_1 = 0;
if (info->revision < 8) info->revision_flag_1 = 0; - if (info->revision >= 8 && (info->silicon_revision == 0 - || info->silicon_revision == 1)) + + if (info->revision >= 8 && + (info->silicon_revision == 0 || info->silicon_revision == 1)) some_delay_2_ps = 735; else some_delay_2_ps = 750;
- if (info->revision >= 0x10 && (info->silicon_revision == 0 - || info->silicon_revision == 1)) + if (info->revision >= 16 && + (info->silicon_revision == 0 || info->silicon_revision == 1)) some_delay_1_ps = 3929; else some_delay_1_ps = 3490;
some_delay_1_cycle_floor = some_delay_1_ps / cycle_ps(info); - some_delay_1_cycle_ceil = some_delay_1_ps / cycle_ps(info); + some_delay_1_cycle_ceil = some_delay_1_ps / cycle_ps(info); + if (some_delay_1_ps % cycle_ps(info)) some_delay_1_cycle_ceil++; else some_delay_1_cycle_floor--; + info->some_delay_1_cycle_floor = some_delay_1_cycle_floor; + if (info->revision_flag_1) some_delay_2_ps = halfcycle_ps(info) >> 6; - some_delay_2_ps += - MAX(some_delay_1_ps - 30, - 2 * halfcycle_ps(info) * (some_delay_1_cycle_ceil - 1) + 1000) + - 375; - some_delay_3_ps = - halfcycle_ps(info) - some_delay_2_ps % halfcycle_ps(info); + + some_delay_2_ps += MAX( + some_delay_1_ps - 30, + 2 * halfcycle_ps(info) * (some_delay_1_cycle_ceil - 1) + 1000 + ) + 375; + + some_delay_3_ps = halfcycle_ps(info) - some_delay_2_ps % halfcycle_ps(info); + if (info->revision_flag_1) { if (some_delay_3_ps >= 150) { const int some_delay_3_halfcycles = - (some_delay_3_ps << 6) / halfcycle_ps(info); + (some_delay_3_ps << 6) / halfcycle_ps(info); + some_delay_3_ps_rounded = - halfcycle_ps(info) * some_delay_3_halfcycles >> 6; + halfcycle_ps(info) * some_delay_3_halfcycles >> 6; } } some_delay_2_halfcycles_ceil = - (some_delay_2_ps + halfcycle_ps(info) - 1) / halfcycle_ps(info) - - 2 * (some_delay_1_cycle_ceil - 1); + (some_delay_2_ps + halfcycle_ps(info) - 1) / halfcycle_ps(info) - 2 * + (some_delay_1_cycle_ceil - 1); + if (info->revision_flag_1 && some_delay_3_ps < 150) some_delay_2_halfcycles_ceil++; + some_delay_2_halfcycles_floor = some_delay_2_halfcycles_ceil; - if (info->revision < 0x10) - some_delay_2_halfcycles_floor = - some_delay_2_halfcycles_ceil - 1; + + if (info->revision < 16) + some_delay_2_halfcycles_floor = some_delay_2_halfcycles_ceil - 1; + if (!info->revision_flag_1) some_delay_2_halfcycles_floor++; + info->some_delay_2_halfcycles_ceil = some_delay_2_halfcycles_ceil; + info->some_delay_3_ps_rounded = some_delay_3_ps_rounded; + if ((info->populated_ranks[0][0][0] && info->populated_ranks[0][1][0]) - || (info->populated_ranks[1][0][0] - && info->populated_ranks[1][1][0])) + || (info->populated_ranks[1][0][0] && info->populated_ranks[1][1][0])) info->max_slots_used_in_channel = 2; else info->max_slots_used_in_channel = 1; + for (channel = 0; channel < 2; channel++) - MCHBAR32(0x244 + (channel << 10)) = - ((info->revision < 8) ? 1 : 0x200) | - ((2 - info->max_slots_used_in_channel) << 17) | - (channel << 21) | + MCHBAR32(0x244 + (channel << 10)) = ((info->revision < 8) ? 1 : 0x200) | + ((2 - info->max_slots_used_in_channel) << 17) | (channel << 21) | (info->some_delay_1_cycle_floor << 18) | 0x9510; + if (info->max_slots_used_in_channel == 1) { info->mode4030[0] = (count_ranks_in_channel(info, 0) == 2); info->mode4030[1] = (count_ranks_in_channel(info, 1) == 2); } else { - info->mode4030[0] = ((count_ranks_in_channel(info, 0) == 1) || (count_ranks_in_channel(info, 0) == 2)) ? 2 : 3; /* 2 if 1 or 2 ranks */ - info->mode4030[1] = ((count_ranks_in_channel(info, 1) == 1) - || (count_ranks_in_channel(info, 1) == - 2)) ? 2 : 3; + /* 2 if 1 or 2 ranks, else 3 */ + info->mode4030[0] = + ((count_ranks_in_channel(info, 0) == 1) || + (count_ranks_in_channel(info, 0) == 2)) ? 2 : 3; + info->mode4030[1] = + ((count_ranks_in_channel(info, 1) == 1) || + (count_ranks_in_channel(info, 1) == 2)) ? 2 : 3; } + for (channel = 0; channel < NUM_CHANNELS; channel++) { int max_of_unk; int min_of_unk_2; @@ -928,84 +873,58 @@ count = 0; for (i = 0; i < 3; i++) { int unk1; + if (info->revision < 8) - unk1 = - u8_FFFD1891[0][channel][info-> - clock_speed_index] - [i]; - else if (! - (info->revision >= 0x10 - || info->revision_flag_1)) - unk1 = - u8_FFFD1891[1][channel][info-> - clock_speed_index] - [i]; + unk1 = u8_FFFD1891[0][channel][info->clock_speed_index][i]; + else if (!(info->revision >= 16 || info->revision_flag_1)) + unk1 = u8_FFFD1891[1][channel][info->clock_speed_index][i]; else unk1 = 0; - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) { - int a = 0; - int b = 0;
- if (!info-> - populated_ranks[channel][slot] - [rank]) - continue; - if (extended_silicon_revision == 4 - && (info-> - populated_ranks_mask[channel] & - 5) != 5) { - if ((info-> - spd[channel][slot] - [REFERENCE_RAW_CARD_USED] & - 0x1F) == 3) { - a = u16_ffd1178[0] - [info-> - clock_speed_index]; - b = u16_fe0eb8[0][info-> - clock_speed_index]; - } else - if ((info-> - spd[channel][slot] - [REFERENCE_RAW_CARD_USED] - & 0x1F) == 5) { - a = u16_ffd1178[1] - [info-> - clock_speed_index]; - b = u16_fe0eb8[1][info-> - clock_speed_index]; - } - } - min_of_unk_2 = MIN(min_of_unk_2, a); - min_of_unk_2 = MIN(min_of_unk_2, b); - if (rank == 0) { - sum += a; - count++; - } - { - int t; - t = b + - u8_FFFD0EF8[channel] - [extended_silicon_revision] - [info-> - mode4030[channel]][info-> - clock_speed_index]; - if (unk1 >= t) - max_of_unk = - MAX(max_of_unk, - unk1 - t); + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + int a = 0; + int b = 0; + + if (!info->populated_ranks[channel][slot][rank]) + continue; + + if (extended_silicon_revision == 4 + && (info->populated_ranks_mask[channel] & 5) != 5) { + + if ((info->spd[channel][slot] + [REFERENCE_RAW_CARD_USED] & 0x1F) == 3) { + a = u16_ffd1178[0][info->clock_speed_index]; + b = u16_fe0eb8 [0][info->clock_speed_index]; + + } else if ((info->spd[channel][slot] + [REFERENCE_RAW_CARD_USED] & 0x1F) == 5) { + a = u16_ffd1178[1][info->clock_speed_index]; + b = u16_fe0eb8 [1][info->clock_speed_index]; } } - { - int t = - u8_FFFD17E0[channel] - [extended_silicon_revision][info-> - mode4030 - [channel]] - [info->clock_speed_index] + min_of_unk_2; + min_of_unk_2 = MIN(min_of_unk_2, a); + min_of_unk_2 = MIN(min_of_unk_2, b); + + if (rank == 0) { + sum += a; + count++; + } + + int t = b + u8_FFFD0EF8[channel][extended_silicon_revision] + [info->mode4030[channel]][info->clock_speed_index]; + if (unk1 >= t) max_of_unk = MAX(max_of_unk, unk1 - t); - } + + }} /* for each slot, rank */ + + int t = u8_FFFD17E0[channel][extended_silicon_revision] + [info->mode4030[channel]][info->clock_speed_index] + min_of_unk_2; + + if (unk1 >= t) + max_of_unk = MAX(max_of_unk, unk1 - t); + }
if (count == 0) @@ -1016,22 +935,19 @@ } }
-static void jedec_read(struct raminfo *info, - int channel, int slot, int rank, - int total_rank, u8 addr3, unsigned int value) +static void jedec_read(struct raminfo *info, int channel, int slot, int rank, int total_rank, + u8 addr3, unsigned int value) { /* Handle mirrored mapping. */ if ((rank & 1) && (info->spd[channel][slot][RANK1_ADDRESS_MAPPING] & 1)) - addr3 = (addr3 & 0xCF) | ((addr3 & 0x10) << 1) | - ((addr3 >> 1) & 0x10); + addr3 = (addr3 & 0xCF) | ((addr3 & 0x10) << 1) | ((addr3 >> 1) & 0x10); + MCHBAR8(0x271) = addr3 | (MCHBAR8(0x271) & 0xC1); MCHBAR8(0x671) = addr3 | (MCHBAR8(0x671) & 0xC1);
/* Handle mirrored mapping. */ if ((rank & 1) && (info->spd[channel][slot][RANK1_ADDRESS_MAPPING] & 1)) - value = - (value & ~0x1f8) | ((value >> 1) & 0xa8) | ((value & 0xa8) - << 1); + value = (value & ~0x1f8) | ((value >> 1) & 0xa8) | ((value & 0xa8) << 1);
read32p((value << 3) | (total_rank << 28));
@@ -1078,19 +994,15 @@ write_recovery = 6; } FOR_POPULATED_RANKS { - auto_self_refresh &= - (info->spd[channel][slot][THERMAL_AND_REFRESH] >> 2) & 1; - self_refresh_temperature &= - info->spd[channel][slot][THERMAL_AND_REFRESH] & 1; + auto_self_refresh &= (info->spd[channel][slot][THERMAL_AND_REFRESH] >> 2) & 1; + self_refresh_temperature &= info->spd[channel][slot][THERMAL_AND_REFRESH] & 1; } if (auto_self_refresh == 1) self_refresh_temperature = 0;
dll_on = ((info->silicon_revision != 2 && info->silicon_revision != 3) - || (info->populated_ranks[0][0][0] - && info->populated_ranks[0][1][0]) - || (info->populated_ranks[1][0][0] - && info->populated_ranks[1][1][0])); + || (info->populated_ranks[0][0][0] && info->populated_ranks[0][1][0]) + || (info->populated_ranks[1][0][0] && info->populated_ranks[1][1][0]));
total_rank = 0;
@@ -1123,31 +1035,28 @@ MCHBAR16(0x58e + (channel << 10)) = rzq_reg58e | 0x82; MCHBAR16(0x590 + (channel << 10)) = 0x1282;
- for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - if (info->populated_ranks[channel][slot][rank]) { - jedec_read(info, channel, slot, rank, - total_rank, 0x28, - rtt_wr | (info-> - clock_speed_index - << 3) - | (auto_self_refresh << 6) | - (self_refresh_temperature << - 7)); - jedec_read(info, channel, slot, rank, - total_rank, 0x38, 0); - jedec_read(info, channel, slot, rank, - total_rank, 0x18, - rtt | MR1_ODS34OHM); - jedec_read(info, channel, slot, rank, - total_rank, 6, - (dll_on << 12) | - (write_recovery << 9) - | ((info->cas_latency - 4) << - 4) | MR0_BT_INTERLEAVED | - MR0_DLL_RESET_ON); - total_rank++; - } + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + if (info->populated_ranks[channel][slot][rank]) { + jedec_read(info, channel, slot, rank, total_rank, 0x28, + rtt_wr | (info->clock_speed_index << 3) | + (auto_self_refresh << 6) | (self_refresh_temperature << 7) + ); + + jedec_read(info, channel, slot, rank, total_rank, 0x38, 0); + + jedec_read(info, channel, slot, rank, total_rank, 0x18, + rtt | MR1_ODS34OHM + ); + + jedec_read(info, channel, slot, rank, total_rank, 6, + (dll_on << 12) | (write_recovery << 9) | + ((info->cas_latency - 4) << 4) | MR0_BT_INTERLEAVED | + MR0_DLL_RESET_ON + ); + + total_rank++; + }}} /* for each slot, rank, if populated */ } }
@@ -1159,15 +1068,12 @@
FOR_ALL_RANKS { if (info->populated_ranks[channel][slot][rank]) { - total_mb[channel] += - pre_jedec ? 256 : (256 << info-> - density[channel][slot] >> info-> - is_x16_module[channel][slot]); + total_mb[channel] += pre_jedec ? 256 : (256 << info->density[channel][slot] >> info->is_x16_module[channel][slot]); + MCHBAR8(0x208 + rank + 2 * slot + (channel << 10)) = - (pre_jedec ? (1 | ((1 + 1) << 1)) : - (info->is_x16_module[channel][slot] | - ((info->density[channel][slot] + 1) << 1))) | - 0x80; + (pre_jedec ? (1 | ((1 + 1) << 1)) + : (info->is_x16_module[channel][slot] | + ((info->density[channel][slot] + 1) << 1))) | 0x80; } MCHBAR16(0x200 + (channel << 10) + 4 * slot + 2 * rank) = total_mb[channel] >> 6; @@ -1175,13 +1081,14 @@
info->total_memory_mb = total_mb[0] + total_mb[1];
- info->interleaved_part_mb = - pre_jedec ? 0 : 2 * MIN(total_mb[0], total_mb[1]); - info->non_interleaved_part_mb = - total_mb[0] + total_mb[1] - info->interleaved_part_mb; + info->interleaved_part_mb = pre_jedec ? 0 : 2 * MIN(total_mb[0], total_mb[1]); + + info->non_interleaved_part_mb = total_mb[0] + total_mb[1] - info->interleaved_part_mb; + channel_0_non_interleaved = total_mb[0] - info->interleaved_part_mb / 2; - MCHBAR32(0x100) = channel_0_non_interleaved | - (info->non_interleaved_part_mb << 16); + + MCHBAR32(0x100) = channel_0_non_interleaved | (info->non_interleaved_part_mb << 16); + if (!pre_jedec) MCHBAR16(0x104) = info->interleaved_part_mb; } @@ -1200,103 +1107,98 @@ high_multiplier = 0; some_delay_ns = 200; some_delay_3_half_cycles = 4; - cas_latency_shift = info->silicon_revision == 0 - || info->silicon_revision == 1 ? 1 : 0; + cas_latency_shift = info->silicon_revision == 0 || info->silicon_revision == 1 ? 1 : 0; + if (info->revision < 8) { some_delay_ns = 600; cas_latency_shift = 0; } - { - int speed_bit; - speed_bit = - ((info->clock_speed_index > 1 - || (info->silicon_revision != 2 - && info->silicon_revision != 3))) ^ (info->revision >= - 0x10); - write_500(info, 0, speed_bit | ((!info->use_ecc) << 1), 0x60e, - 3, 1); - write_500(info, 1, speed_bit | ((!info->use_ecc) << 1), 0x60e, - 3, 1); - if (info->revision >= 0x10 && info->clock_speed_index <= 1 - && (info->silicon_revision == 2 - || info->silicon_revision == 3)) - rmw_1d0(0x116, 5, 2, 4, 1); - } - MCHBAR32(0x120) = (1 << (info->max_slots_used_in_channel + 28)) | - 0x188e7f9f;
- MCHBAR8(0x124) = info->board_lane_delay[4] + - ((frequency_01(info) + 999) / 1000); + int speed_bit = ((info->clock_speed_index > 1 || (info->silicon_revision != 2 && + info->silicon_revision != 3))) ^ (info->revision >= 16); + + write_500(info, 0, speed_bit | ((!info->use_ecc) << 1), 0x60e, 3, 1); + write_500(info, 1, speed_bit | ((!info->use_ecc) << 1), 0x60e, 3, 1); + + if (info->revision >= 16 && info->clock_speed_index <= 1 && + (info->silicon_revision == 2 || info->silicon_revision == 3)) { + rmw_1d0(0x116, 5, 2, 4, 1); + } + + MCHBAR32(0x120) = (1 << (info->max_slots_used_in_channel + 28)) | 0x188e7f9f; + MCHBAR8(0x124) = info->board_lane_delay[4] + ((frequency_01(info) + 999) / 1000); MCHBAR16(0x125) = 0x1360; - MCHBAR8(0x127) = 0x40; + MCHBAR8(0x127) = 0x40; if (info->fsb_frequency < frequency_11(info) / 2) { unsigned int some_delay_2_half_cycles; high_multiplier = 1; - some_delay_2_half_cycles = ps_to_halfcycles(info, - ((3 * - fsbcycle_ps(info)) - >> 1) + - (halfcycle_ps(info) - * - reg178_min[info-> - clock_speed_index] - >> 6) - + - 4 * - halfcycle_ps(info) - + 2230); - some_delay_3_half_cycles = - MIN((some_delay_2_half_cycles + - (frequency_11(info) * 2) * (28 - - some_delay_2_half_cycles) / - (frequency_11(info) * 2 - - 4 * (info->fsb_frequency))) >> 3, 7); + some_delay_2_half_cycles = ps_to_halfcycles(info, ( + (3 * fsbcycle_ps(info)) >> 1) + + + (halfcycle_ps(info) * reg178_min[info->clock_speed_index] >> 6) + + + 4 * halfcycle_ps(info) + 2230 + ); + + some_delay_3_half_cycles = MIN( + (some_delay_2_half_cycles + (frequency_11(info) * 2) + * + (28 - some_delay_2_half_cycles) / (frequency_11(info) * 2 + - + 4 * (info->fsb_frequency))) >> 3, + 7); } if (MCHBAR8(0x2ca9) & 1) some_delay_3_half_cycles = 3; + for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32_OR(0x220 + (channel << 10), 0x18001117); MCHBAR32(0x224 + (channel << 10)) = - (info->max_slots_used_in_channel - 1) | - ((info->cas_latency - 5 - info->clock_speed_index) - << 21) | ((info->max_slots_used_in_channel + - info->cas_latency - cas_latency_shift - 4) << 16) | + ((info->max_slots_used_in_channel - 1) | + ((info->cas_latency - 5 - info->clock_speed_index) << 21) | + ((info->max_slots_used_in_channel + + info->cas_latency - cas_latency_shift - 4) << 16) | ((info->cas_latency - cas_latency_shift - 4) << 26) | - ((info->cas_latency - info->clock_speed_index + - info->max_slots_used_in_channel - 6) << 8); - MCHBAR32(0x228 + (channel << 10)) = - info->max_slots_used_in_channel; - MCHBAR8(0x239 + (channel << 10)) = 32; - MCHBAR32(0x248 + (channel << 10)) = (high_multiplier << 24) | - (some_delay_3_half_cycles << 25) | 0x840000; + ((info->cas_latency - info->clock_speed_index + + info->max_slots_used_in_channel - 6) << 8) + ); + + MCHBAR32(0x228 + (channel << 10)) = info->max_slots_used_in_channel; + MCHBAR8(0x239 + (channel << 10)) = 32; + MCHBAR32(0x248 + (channel << 10)) = + (high_multiplier << 24) | (some_delay_3_half_cycles << 25) | 0x840000; + MCHBAR32(0x278 + (channel << 10)) = 0xc362042; MCHBAR32(0x27c + (channel << 10)) = 0x8b000062; MCHBAR32(0x24c + (channel << 10)) = - ((!!info->clock_speed_index) << 17) | - (((2 + info->clock_speed_index - + ((!!info->clock_speed_index) << 17) | (((2 + info->clock_speed_index - (!!info->clock_speed_index))) << 12) | 0x10200;
- MCHBAR8(0x267 + (channel << 10)) = 0x4; + MCHBAR8(0x267 + (channel << 10)) = 0x4; MCHBAR16(0x272 + (channel << 10)) = 0x155; - MCHBAR32_AND_OR(0x2bc + (channel << 10), 0xFF000000, 0x707070); + MCHBAR32_AND_OR(0x2bc + (channel << 10), 0xff000000, 0x707070);
- write_500(info, channel, - ((!info->populated_ranks[channel][1][1]) - | (!info->populated_ranks[channel][1][0] << 1) - | (!info->populated_ranks[channel][0][1] << 2) - | (!info->populated_ranks[channel][0][0] << 3)), - 0x4c9, 4, 1); + write_500(info, channel, ( + (!info->populated_ranks[channel][1][1]) | + (!info->populated_ranks[channel][1][0] << 1) | + (!info->populated_ranks[channel][0][1] << 2) | + (!info->populated_ranks[channel][0][0] << 3) + ), 0x4c9, 4, 1); }
MCHBAR8(0x2c4) = ((1 + (info->clock_speed_index != 0)) << 6) | 0xC; { u8 freq_divisor = 2; + if (info->fsb_frequency == frequency_11(info)) freq_divisor = 3; + else if (2 * info->fsb_frequency < 3 * (frequency_11(info) / 2)) freq_divisor = 1; + else freq_divisor = 2; + MCHBAR32(0x2c0) = (freq_divisor << 11) | 0x6009c400; }
@@ -1308,61 +1210,65 @@ } else { lane_3_delay = 12; } + cas_latency_derived = info->cas_latency - info->clock_speed_index + 2; + if (info->clock_speed_index > 1) cas_latency_derived++; + for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32(0x240 + (channel << 10)) = - ((info->clock_speed_index == 0) * 0x11000) | - 0x1002100 | ((2 + info->clock_speed_index) << 4) | - (info->cas_latency - 3); - write_500(info, channel, (info->clock_speed_index << 1) | 1, - 0x609, 6, 1); + ((info->clock_speed_index == 0) * 0x11000) | 0x1002100 | + ((2 + info->clock_speed_index) << 4) | (info->cas_latency - 3); + + write_500(info, channel, (info->clock_speed_index << 1) | 1, 0x609, 6, 1); write_500(info, channel, - info->clock_speed_index + 2 * info->cas_latency - 7, - 0x601, 6, 1); + info->clock_speed_index + 2 * info->cas_latency - 7, 0x601, 6, 1);
MCHBAR32(0x250 + (channel << 10)) = ((lane_3_delay + info->clock_speed_index + 9) << 6) | - (info->board_lane_delay[7] << 2) | + (info->board_lane_delay[7] << 2) | (info->board_lane_delay[4] << 16) | (info->board_lane_delay[1] << 25) | (info->board_lane_delay[1] << 29) | 1; - MCHBAR32(0x254 + (channel << 10)) = - (info->board_lane_delay[1] >> 3) | - ((info->board_lane_delay[8] + 4 * info->use_ecc) << 6) | - 0x80 | (info->board_lane_delay[6] << 1) | - (info->board_lane_delay[2] << 28) | + + MCHBAR32(0x254 + (channel << 10)) = (info->board_lane_delay[1] >> 3) | + ((info->board_lane_delay[8] + 4 * info->use_ecc) << 6) | 0x80 | + (info->board_lane_delay[6] << 1) | (info->board_lane_delay[2] << 28) | (cas_latency_derived << 16) | 0x4700000; + MCHBAR32(0x258 + (channel << 10)) = - ((info->board_lane_delay[5] + info->clock_speed_index + - 9) << 12) | ((info->clock_speed_index - - info->cas_latency + 12) << 8) | + ((info->board_lane_delay[5] + info->clock_speed_index + 9) << 12) | + ((info->clock_speed_index - info->cas_latency + 12) << 8) | (info->board_lane_delay[2] << 17) | (info->board_lane_delay[4] << 24) | 0x47; + MCHBAR32(0x25c + (channel << 10)) = (info->board_lane_delay[1] << 1) | (info->board_lane_delay[0] << 8) | 0x1da50000; + MCHBAR8(0x264 + (channel << 10)) = 0xff; - MCHBAR8(0x5f8 + (channel << 10)) = - (cas_latency_shift << 3) | info->use_ecc; + MCHBAR8(0x5f8 + (channel << 10)) = (cas_latency_shift << 3) | info->use_ecc; }
program_modules_memory_map(info, 1);
- MCHBAR16(0x610) = (MIN(ns_to_cycles(info, some_delay_ns) / 2, 127) << 9) - | (MCHBAR16(0x610) & 0x1C3) | 0x3C; + MCHBAR16(0x610) = (MIN(ns_to_cycles(info, some_delay_ns) / 2, 127) << 9) | + (MCHBAR16(0x610) & 0x1c3) | 0x3c; + MCHBAR16_OR(0x612, 0x100); - MCHBAR16_OR(0x214, 0x3E00); + MCHBAR16_OR(0x214, 0x3e00); + for (i = 0; i < 8; i++) { pci_write_config32(PCI_DEV (QUICKPATH_BUS, 0, 1), 0x80 + 4 * i, - (info->total_memory_mb - 64) | !i | 2); + (info->total_memory_mb - 64) | !i | 2); + pci_write_config32(PCI_DEV (QUICKPATH_BUS, 0, 1), 0xc0 + 4 * i, 0); } }
-#define DEFAULT_PCI_MMIO_SIZE 2048 -#define HOST_BRIDGE PCI_DEVFN(0, 0) +#define DEFAULT_PCI_MMIO_SIZE 2048 +#define HOST_BRIDGE PCI_DEVFN(0, 0)
static unsigned int get_mmio_size(void) { @@ -1380,38 +1286,37 @@ return cfg->pci_mmio_size; }
-#define BETTER_MEMORY_MAP 0 - static void program_total_memory_map(struct raminfo *info) { unsigned int TOM, TOLUD, TOUUD; unsigned int quickpath_reserved; - unsigned int REMAPbase; + unsigned int remapbase; unsigned int uma_base_igd; unsigned int uma_base_gtt; unsigned int mmio_size; - int memory_remap; unsigned int memory_map[8]; - int i; unsigned int current_limit; unsigned int tseg_base; - int uma_size_igd = 0, uma_size_gtt = 0; + int uma_size_igd = 0; + int uma_size_gtt = 0; + int memory_remap; + int i;
memset(memory_map, 0, sizeof(memory_map));
if (info->uma_enabled) { - u16 t = pci_read_config16(NORTHBRIDGE, D0F0_GGC); - gav(t); - const int uma_sizes_gtt[16] = - { 0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4, 42, 42, 42, 42 }; - /* Igd memory */ - const int uma_sizes_igd[16] = { - 0, 0, 0, 0, 0, 32, 48, 64, 128, 256, 96, 160, 224, 352, - 256, 512 - }; + u16 ggc_val = pci_read_config16(NORTHBRIDGE, D0F0_GGC); + gav(ggc_val);
- uma_size_igd = uma_sizes_igd[(t >> 4) & 0xF]; - uma_size_gtt = uma_sizes_gtt[(t >> 8) & 0xF]; + const int uma_sizes_gtt[16] = + {0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4, 42, 42, 42, 42}; + + /* IGD memory */ + const int uma_sizes_igd[16] = + {0, 0, 0, 0, 0, 32, 48, 64, 128, 256, 96, 160, 224, 352, 256, 512}; + + uma_size_igd = uma_sizes_igd[(ggc_val >> 4) & 0xF]; + uma_size_gtt = uma_sizes_gtt[(ggc_val >> 8) & 0xF]; }
mmio_size = get_mmio_size(); @@ -1419,17 +1324,23 @@ TOM = info->total_memory_mb; if (TOM == 4096) TOM = 4032; + TOUUD = ALIGN_DOWN(TOM - info->memory_reserved_for_heci_mb, 64); - TOLUD = ALIGN_DOWN(MIN(4096 - mmio_size + ALIGN_UP(uma_size_igd + uma_size_gtt, 64) - , TOUUD), 64); + TOLUD = ALIGN_DOWN(MIN( + 4096 - mmio_size + ALIGN_UP(uma_size_igd + uma_size_gtt, 64), TOUUD), + 64 + ); + memory_remap = 0; if (TOUUD - TOLUD > 64) { memory_remap = 1; - REMAPbase = MAX(4096, TOUUD); + remapbase = MAX(4096, TOUUD); TOUUD = TOUUD - TOLUD + 4096; } + if (TOUUD > 4096) memory_map[2] = TOUUD | 1; + quickpath_reserved = 0;
u32 t = pci_read_config32(PCI_DEV(QUICKPATH_BUS, 0, 1), 0x68); @@ -1440,6 +1351,7 @@ u32 shift = t >> 20; if (shift == 0) die("Quickpath value is 0\n"); + quickpath_reserved = (u32)1 << find_lowest_bit_set32(shift); }
@@ -1449,32 +1361,40 @@ uma_base_igd = TOLUD - uma_size_igd; uma_base_gtt = uma_base_igd - uma_size_gtt; tseg_base = ALIGN_DOWN(uma_base_gtt, 64) - (CONFIG_SMM_TSEG_SIZE >> 20); + if (!memory_remap) tseg_base -= quickpath_reserved; + tseg_base = ALIGN_DOWN(tseg_base, 8);
pci_write_config16(NORTHBRIDGE, D0F0_TOLUD, TOLUD << 4); pci_write_config16(NORTHBRIDGE, D0F0_TOM, TOM >> 6); + if (memory_remap) { - pci_write_config16(NORTHBRIDGE, D0F0_REMAPBASE, REMAPbase >> 6); + pci_write_config16(NORTHBRIDGE, D0F0_REMAPBASE, remapbase >> 6); pci_write_config16(NORTHBRIDGE, D0F0_REMAPLIMIT, (TOUUD - 64) >> 6); } + pci_write_config16(NORTHBRIDGE, D0F0_TOUUD, TOUUD);
if (info->uma_enabled) { pci_write_config32(NORTHBRIDGE, D0F0_IGD_BASE, uma_base_igd << 20); pci_write_config32(NORTHBRIDGE, D0F0_GTT_BASE, uma_base_gtt << 20); } + pci_write_config32(NORTHBRIDGE, TSEG, tseg_base << 20);
current_limit = 0; + memory_map[0] = ALIGN_DOWN(uma_base_gtt, 64) | 1; memory_map[1] = 4096; + for (i = 0; i < ARRAY_SIZE(memory_map); i++) { current_limit = MAX(current_limit, memory_map[i] & ~1); + pci_write_config32(PCI_DEV(QUICKPATH_BUS, 0, 1), 4 * i + 0x80, - (memory_map[i] & 1) | ALIGN_DOWN(current_limit - - 1, 64) | 2); + (memory_map[i] & 1) | ALIGN_DOWN(current_limit - 1, 64) | 2); + pci_write_config32(PCI_DEV(QUICKPATH_BUS, 0, 1), 4 * i + 0xc0, 0); } } @@ -1490,8 +1410,8 @@ ;
if (!info->heci_bar) - gav(info->heci_bar = - pci_read_config32(HECIDEV, HECIBAR) & 0xFFFFFFF8); + gav(info->heci_bar = pci_read_config32(HECIDEV, HECIBAR) & 0xFFFFFFF8); + if (!info->memory_reserved_for_heci_mb) { /* Wait for ME to be ready */ intel_early_me_init(); @@ -1499,26 +1419,30 @@ }
for (i = 0; i < 3; i++) - gav(capid0[i] = - pci_read_config32(NORTHBRIDGE, D0F0_CAPID0 | (i << 2))); + gav(capid0[i] = pci_read_config32(NORTHBRIDGE, D0F0_CAPID0 | (i << 2))); + gav(info->revision = pci_read_config8(NORTHBRIDGE, PCI_REVISION_ID)); + info->max_supported_clock_speed_index = (~capid0[1] & 7);
if ((capid0[1] >> 11) & 1) info->uma_enabled = 0; else - gav(info->uma_enabled = - pci_read_config8(NORTHBRIDGE, D0F0_DEVEN) & 8); - /* Unrecognised: [0000:fffd3d2d] 37f81.37f82 ! CPUID: eax: 00000001; ecx: 00000e00 => 00020655.00010800.029ae3ff.bfebfbff */ + gav(info->uma_enabled = pci_read_config8(NORTHBRIDGE, D0F0_DEVEN) & 8); + + /* + * Unrecognised: [0000:fffd3d2d] 37f81.37f82! + * CPUID: eax: 00000001; ecx: 00000e00 => 00020655.00010800.029ae3ff.bfebfbff + */ info->silicon_revision = 0;
if (capid0[2] & 2) { info->silicon_revision = 0; info->max_supported_clock_speed_index = 2; + for (channel = 0; channel < NUM_CHANNELS; channel++) if (info->populated_ranks[channel][0][0] - && (info->spd[channel][0][MODULE_TYPE] & 0xf) == - 3) { + && (info->spd[channel][0][MODULE_TYPE] & 0xf) == 3) { info->silicon_revision = 2; info->max_supported_clock_speed_index = 1; } @@ -1535,6 +1459,7 @@ info->silicon_revision = 2; break; } + switch (pci_read_config16(NORTHBRIDGE, PCI_DEVICE_ID)) { case 0x40: info->silicon_revision = 0; @@ -1549,23 +1474,22 @@ static void write_training_data(struct raminfo *info) { int tm, channel, slot, rank, lane; + if (info->revision < 8) return;
- for (tm = 0; tm < 4; tm++) - for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - for (lane = 0; lane < 9; lane++) - write_500(info, channel, - info-> - cached_training-> - lane_timings[tm] - [channel][slot][rank] - [lane], - get_timing_register_addr - (lane, tm, slot, - rank), 9, 0); + for (tm = 0; tm < 4; tm++) { + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + for (lane = 0; lane < 9; lane++) { + + write_500(info, channel, + info->cached_training->lane_timings[tm][channel][slot][rank][lane], + get_timing_register_addr(lane, tm, slot, rank), 9, 0); + }}}}} /* for each tm, channel, slot, rank, lane */ + + write_1d0(info->cached_training->reg_178, 0x178, 7, 1); write_1d0(info->cached_training->reg_10b, 0x10b, 6, 1); } @@ -1575,56 +1499,52 @@ int channel, slot, rank, lane, i; printk(RAM_SPEW, "Timings:\n"); FOR_POPULATED_RANKS { - printk(RAM_SPEW, "channel %d, slot %d, rank %d\n", channel, - slot, rank); + printk(RAM_SPEW, "channel %d, slot %d, rank %d\n", channel, slot, rank); + for (lane = 0; lane < 9; lane++) { printk(RAM_SPEW, "lane %d: ", lane); for (i = 0; i < 4; i++) { - printk(RAM_SPEW, "%x (%x) ", - read_500(info, channel, - get_timing_register_addr - (lane, i, slot, rank), - 9), - info->training. - lane_timings[i][channel][slot][rank] - [lane]); + printk(RAM_SPEW, "%x (%x) ", read_500(info, channel, + get_timing_register_addr(lane, i, slot, rank), 9), + info->training.lane_timings[i][channel][slot][rank][lane]); } printk(RAM_SPEW, "\n"); } } - printk(RAM_SPEW, "[178] = %x (%x)\n", read_1d0(0x178, 7), - info->training.reg_178); - printk(RAM_SPEW, "[10b] = %x (%x)\n", read_1d0(0x10b, 6), - info->training.reg_10b); + printk(RAM_SPEW, "[178] = %x (%x)\n", read_1d0(0x178, 7), info->training.reg_178); + printk(RAM_SPEW, "[10b] = %x (%x)\n", read_1d0(0x10b, 6), info->training.reg_10b); }
-/* Read timings and other registers that need to be restored verbatim and - put them to CBMEM. - */ +/* Read timings and other registers that need to be restored verbatim into CBMEM. */ static void save_timings(struct raminfo *info) { struct ram_training train; int channel, slot, rank, lane, i;
train = info->training; - FOR_POPULATED_RANKS for (lane = 0; lane < 9; lane++) - for (i = 0; i < 4; i++) - train.lane_timings[i][channel][slot][rank][lane] = - read_500(info, channel, - get_timing_register_addr(lane, i, slot, - rank), 9); + + FOR_POPULATED_RANKS { + for (lane = 0; lane < 9; lane++) { + for (i = 0; i < 4; i++) { + train.lane_timings[i][channel][slot][rank][lane] + = + read_500(info, channel, get_timing_register_addr(lane, i, slot, rank), 9); + }}} /* for each populated rank, lane, i */ + train.reg_178 = read_1d0(0x178, 7); train.reg_10b = read_1d0(0x10b, 6);
for (channel = 0; channel < NUM_CHANNELS; channel++) { - u32 reg32; - reg32 = MCHBAR32((channel << 10) + 0x274); + + u32 reg32 = MCHBAR32((channel << 10) + 0x274); + train.reg274265[channel][0] = reg32 >> 16; train.reg274265[channel][1] = reg32 & 0xffff; - train.reg274265[channel][2] = - MCHBAR16((channel << 10) + 0x265) >> 8; + train.reg274265[channel][2] = MCHBAR16((channel << 10) + 0x265) >> 8; } + train.reg2ca9_bit0 = MCHBAR8(0x2ca9) & 1; + train.reg_6dc = MCHBAR32(0x6dc); train.reg_6e8 = MCHBAR32(0x6e8);
@@ -1632,29 +1552,28 @@ printk(RAM_SPEW, "[6e8] = %x\n", train.reg_6e8);
/* Save the MRC S3 restore data to cbmem */ - mrc_cache_stash_data(MRC_TRAINING_DATA, MRC_CACHE_VERSION, - &train, sizeof(train)); + mrc_cache_stash_data(MRC_TRAINING_DATA, MRC_CACHE_VERSION, &train, sizeof(train)); }
static const struct ram_training *get_cached_training(void) { struct region_device rdev; - if (mrc_cache_get_current(MRC_TRAINING_DATA, MRC_CACHE_VERSION, - &rdev)) + if (mrc_cache_get_current(MRC_TRAINING_DATA, MRC_CACHE_VERSION, &rdev)) return 0; + return (void *)rdev_mmap_full(&rdev); }
-/* FIXME: add timeout. */ +/* FIXME: add timeout. */ static void wait_heci_ready(void) { while (!(read32(DEFAULT_HECIBAR + 0xc) & 8)) // = 0x8000000c ; - write32((DEFAULT_HECIBAR + 0x4), - (read32(DEFAULT_HECIBAR + 0x4) & ~0x10) | 0xc); + + write32((DEFAULT_HECIBAR + 0x4), (read32(DEFAULT_HECIBAR + 0x4) & ~0x10) | 0xc); }
-/* FIXME: add timeout. */ +/* FIXME: add timeout. */ static void wait_heci_cb_avail(int len) { union { @@ -1665,12 +1584,10 @@ while (!(read32(DEFAULT_HECIBAR + 0xc) & 8)) ;
- do + do { csr.raw = read32(DEFAULT_HECIBAR + 0x4); - while (len > - csr.csr.buffer_depth - (csr.csr.buffer_write_ptr - - csr.csr.buffer_read_ptr)) - ; + } while (len > csr.csr.buffer_depth - + (csr.csr.buffer_write_ptr - csr.csr.buffer_read_ptr)); }
static void send_heci_packet(struct mei_header *head, u32 *payload) @@ -1682,6 +1599,7 @@
/* FIXME: handle leftovers correctly. */ write32(DEFAULT_HECIBAR + 0, *(u32 *) head); + for (i = 0; i < len - 1; i++) write32(DEFAULT_HECIBAR + 0, payload[i]);
@@ -1689,8 +1607,7 @@ write32(DEFAULT_HECIBAR + 0x4, read32(DEFAULT_HECIBAR + 0x4) | 0x4); }
-static void -send_heci_message(u8 *msg, int len, u8 hostaddress, u8 clientaddress) +static void send_heci_message(u8 *msg, int len, u8 hostaddress, u8 clientaddress) { struct mei_header head; int maxlen; @@ -1705,6 +1622,7 @@ head.is_complete = 0; } else head.is_complete = 1; + head.length = cur; head.reserved = 0; head.client_address = clientaddress; @@ -1716,68 +1634,70 @@ }
/* FIXME: Add timeout. */ -static int -recv_heci_packet(struct raminfo *info, struct mei_header *head, u32 *packet, - u32 *packet_size) +static int recv_heci_packet(struct raminfo *info, struct mei_header *head, u32 *packet, u32 *packet_size) { union { struct mei_csr csr; u32 raw; } csr; + int i = 0;
write32(DEFAULT_HECIBAR + 0x4, read32(DEFAULT_HECIBAR + 0x4) | 2); + do { csr.raw = read32(DEFAULT_HECIBAR + 0xc); } - while (csr.csr.buffer_write_ptr == csr.csr.buffer_read_ptr) - ; + while (csr.csr.buffer_write_ptr == csr.csr.buffer_read_ptr); + *(u32 *) head = read32(DEFAULT_HECIBAR + 0x8); + if (!head->length) { - write32(DEFAULT_HECIBAR + 0x4, - read32(DEFAULT_HECIBAR + 0x4) | 2); + write32(DEFAULT_HECIBAR + 0x4, read32(DEFAULT_HECIBAR + 0x4) | 2); *packet_size = 0; return 0; } - if (head->length + 4 > 4 * csr.csr.buffer_depth - || head->length > *packet_size) { + if (head->length + 4 > 4 * csr.csr.buffer_depth || head->length > *packet_size) { *packet_size = 0; return -1; }
- do + do { csr.raw = read32(DEFAULT_HECIBAR + 0xc); - while (((head->length + 3) >> 2) > - (csr.csr.buffer_write_ptr - csr.csr.buffer_read_ptr)) - ; + } while (((head->length + 3) >> 2) > + (csr.csr.buffer_write_ptr - csr.csr.buffer_read_ptr));
for (i = 0; i < (head->length + 3) >> 2; i++) packet[i++] = read32(DEFAULT_HECIBAR + 0x8); + *packet_size = head->length; if (!csr.csr.ready) *packet_size = 0; + write32(DEFAULT_HECIBAR + 0x4, read32(DEFAULT_HECIBAR + 0x4) | 4); return 0; }
/* FIXME: Add timeout. */ -static int -recv_heci_message(struct raminfo *info, u32 *message, u32 *message_size) +static int recv_heci_message(struct raminfo *info, u32 *message, u32 *message_size) { struct mei_header head; int current_position;
current_position = 0; + while (1) { - u32 current_size; - current_size = *message_size - current_position; - if (recv_heci_packet - (info, &head, message + (current_position >> 2), - ¤t_size) == -1) + u32 current_size = *message_size - current_position; + + if (recv_heci_packet(info, &head, message + (current_position >> 2), + ¤t_size) == -1) break; + if (!current_size) break; + current_position += current_size; + if (head.is_complete) { *message_size = current_position; return 0; @@ -1786,6 +1706,7 @@ if (current_position >= *message_size) break; } + *message_size = 0; return -1; } @@ -1800,6 +1721,7 @@ u8 field2; u8 unk3[0x48 - 4 - 1]; } __packed reply; + struct uma_message { u8 group_id; u8 cmd; @@ -1810,14 +1732,15 @@ u32 memory_reserved_for_heci_mb; u16 c3; } __packed msg = { - 0, MKHI_SET_UMA, 0, 0, - 0x82, - info->heci_uma_addr, info->memory_reserved_for_heci_mb, 0}; + 0, MKHI_SET_UMA, 0, 0, 0x82, + info->heci_uma_addr, info->memory_reserved_for_heci_mb, 0 + }; + u32 reply_size;
send_heci_message((u8 *) & msg, sizeof(msg), 0, 7); - reply_size = sizeof(reply); + if (recv_heci_message(info, (u32 *) & reply, &reply_size) == -1) return;
@@ -1837,34 +1760,23 @@
info->heci_bar = pci_read_config32(HECIDEV, 0x10) & 0xFFFFFFF0; info->memory_reserved_for_heci_mb = reg44 & 0x3f; - info->heci_uma_addr = - ((u64) - ((((u64) pci_read_config16(NORTHBRIDGE, D0F0_TOM)) << 6) - - info->memory_reserved_for_heci_mb)) << 20; + info->heci_uma_addr = ((u64)((((u64) pci_read_config16(NORTHBRIDGE, D0F0_TOM)) << 6) - info->memory_reserved_for_heci_mb)) << 20;
pci_read_config32(NORTHBRIDGE, DMIBAR); if (info->memory_reserved_for_heci_mb) { - write32(DEFAULT_DMIBAR + 0x14, - read32(DEFAULT_DMIBAR + 0x14) & ~0x80); - write32(DEFAULT_RCBA + 0x14, - read32(DEFAULT_RCBA + 0x14) & ~0x80); - write32(DEFAULT_DMIBAR + 0x20, - read32(DEFAULT_DMIBAR + 0x20) & ~0x80); - write32(DEFAULT_RCBA + 0x20, - read32(DEFAULT_RCBA + 0x20) & ~0x80); - write32(DEFAULT_DMIBAR + 0x2c, - read32(DEFAULT_DMIBAR + 0x2c) & ~0x80); - write32(DEFAULT_RCBA + 0x30, - read32(DEFAULT_RCBA + 0x30) & ~0x80); - write32(DEFAULT_DMIBAR + 0x38, - read32(DEFAULT_DMIBAR + 0x38) & ~0x80); - write32(DEFAULT_RCBA + 0x40, - read32(DEFAULT_RCBA + 0x40) & ~0x80); + write32(DEFAULT_DMIBAR + 0x14, read32(DEFAULT_DMIBAR + 0x14) & ~0x80); + write32(DEFAULT_RCBA + 0x14, read32(DEFAULT_RCBA + 0x14) & ~0x80); + write32(DEFAULT_DMIBAR + 0x20, read32(DEFAULT_DMIBAR + 0x20) & ~0x80); + write32(DEFAULT_RCBA + 0x20, read32(DEFAULT_RCBA + 0x20) & ~0x80); + write32(DEFAULT_DMIBAR + 0x2c, read32(DEFAULT_DMIBAR + 0x2c) & ~0x80); + write32(DEFAULT_RCBA + 0x30, read32(DEFAULT_RCBA + 0x30) & ~0x80); + write32(DEFAULT_DMIBAR + 0x38, read32(DEFAULT_DMIBAR + 0x38) & ~0x80); + write32(DEFAULT_RCBA + 0x40, read32(DEFAULT_RCBA + 0x40) & ~0x80);
- write32(DEFAULT_RCBA + 0x40, 0x87000080); // OK + write32(DEFAULT_RCBA + 0x40, 0x87000080); // OK write32(DEFAULT_DMIBAR + 0x38, 0x87000080); // OK - while ((read16(DEFAULT_RCBA + 0x46) & 2) && - read16(DEFAULT_DMIBAR + 0x3e) & 2) + + while ((read16(DEFAULT_RCBA + 0x46) & 2) && read16(DEFAULT_DMIBAR + 0x3e) & 2) ; }
@@ -1879,11 +1791,11 @@
static int have_match_ranks(struct raminfo *info, int channel, int ranks) { - int ranks_in_channel; - ranks_in_channel = info->populated_ranks[channel][0][0] - + info->populated_ranks[channel][0][1] - + info->populated_ranks[channel][1][0] - + info->populated_ranks[channel][1][1]; + int ranks_in_channel = + info->populated_ranks[channel][0][0] + + info->populated_ranks[channel][0][1] + + info->populated_ranks[channel][1][0] + + info->populated_ranks[channel][1][1];
/* empty channel */ if (ranks_in_channel == 0) @@ -1891,45 +1803,50 @@
if (ranks_in_channel != ranks) return 0; + /* single slot */ if (info->populated_ranks[channel][0][0] != info->populated_ranks[channel][1][0]) return 1; + if (info->populated_ranks[channel][0][1] != info->populated_ranks[channel][1][1]) return 1; + if (info->is_x16_module[channel][0] != info->is_x16_module[channel][1]) return 0; + if (info->density[channel][0] != info->density[channel][1]) return 0; + return 1; }
static void read_4090(struct raminfo *info) { int i, channel, slot, rank, lane; - for (i = 0; i < 2; i++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - for (lane = 0; lane < 9; lane++) - info->training. - lane_timings[0][i][slot][rank][lane] - = 32;
- for (i = 1; i < 4; i++) - for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - for (lane = 0; lane < 9; lane++) { - info->training. - lane_timings[i][channel] - [slot][rank][lane] = - read_500(info, channel, - get_timing_register_addr - (lane, i, slot, - rank), 9) - + (i == 1) * 11; // !!!! - } + for (i = 0; i < 2; i++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + for (lane = 0; lane < 9; lane++) { + + info->training.lane_timings[0][i][slot][rank][lane] = 32; + }}}} /* for each i, slot, rank, lane */ + + for (i = 1; i < 4; i++) { + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + for (lane = 0; lane < 9; lane++) { + + info->training.lane_timings[i][channel][slot][rank][lane] + = + read_500(info, channel, get_timing_register_addr(lane, i, slot, rank), 9) + + + (i == 1) * 11; // !!!! + + }}}}} /* for each i, channel, slot, lane */
@@ -1939,9 +1856,12 @@ 0xaaaa, 0x6db6, 0x4924, 0xeeee, 0xcccc, 0x8888, 0x7bde, 0x739c, 0x6318, 0x4210, 0xefbe, 0xcf3c, 0x8e38, 0x0c30, 0x0820 }; + u32 ret; u32 comp4 = addr / 480; + addr %= 480; + u32 comp1 = addr & 0xf; u32 comp2 = (addr >> 4) & 1; u32 comp3 = addr >> 5; @@ -1950,6 +1870,7 @@ ret = 0x1010101 << (comp4 - 1); else ret = 0; + if (flip ^ (((invmask[comp3] >> comp1) ^ comp2) & 1)) ret = ~ret;
@@ -1967,21 +1888,23 @@ static void enable_cache(unsigned int base, unsigned int size) { msr_t msr; + msr.lo = base | MTRR_TYPE_WRPROT; msr.hi = 0; + wrmsr(MTRR_PHYS_BASE(3), msr); - msr.lo = ((~(ALIGN_DOWN(size + 4096, 4096) - 1) | MTRR_DEF_TYPE_EN) - & 0xffffffff); + + msr.lo = ((~(ALIGN_DOWN(size + 4096, 4096) - 1) | MTRR_DEF_TYPE_EN) & 0xffffffff); msr.hi = 0x0000000f; + wrmsr(MTRR_PHYS_MASK(3), msr); }
static void flush_cache(u32 start, u32 size) { - u32 end; u32 addr; + u32 end = start + (ALIGN_DOWN(size + 4096, 4096));
- end = start + (ALIGN_DOWN(size + 4096, 4096)); for (addr = start; addr < end; addr += 64) clflush(addr); } @@ -1994,17 +1917,20 @@ static void write_testing(struct raminfo *info, int totalrank, int flip) { int nwrites = 0; + /* in 8-byte units. */ u32 offset; - u8 *base; + u8 *base = (u8 *)(totalrank << 28);
- base = (u8 *)(totalrank << 28); for (offset = 0; offset < 9 * 480; offset += 2) { - write32(base + offset * 8, get_etalon2(flip, offset)); - write32(base + offset * 8 + 4, get_etalon2(flip, offset)); - write32(base + offset * 8 + 8, get_etalon2(flip, offset + 1)); + + write32(base + offset * 8, get_etalon2(flip, offset)); + write32(base + offset * 8 + 4, get_etalon2(flip, offset)); + write32(base + offset * 8 + 8, get_etalon2(flip, offset + 1)); write32(base + offset * 8 + 12, get_etalon2(flip, offset + 1)); + nwrites += 4; + if (nwrites >= 320) { clear_errors(); nwrites = 0; @@ -2014,9 +1940,8 @@
static u8 check_testing(struct raminfo *info, u8 total_rank, int flip) { - u8 failmask = 0; - int i; - int comp1, comp2, comp3; + int i, comp1, comp2, comp3; + u8 failmask = 0; u32 failxor[2] = { 0, 0 };
enable_cache((total_rank << 28), 1728 * 5 * 4); @@ -2058,12 +1983,10 @@
static u32 get_seed2(int a, int b) { - const u32 seed2[5] = { - 0x55555555, 0x33333333, 0x2e555a55, 0x55555555, - 0x5b6db6db, - }; - u32 r; - r = seed2[(a + (a >= 10)) / 5]; + const u32 seed2[5] = {0x55555555, 0x33333333, 0x2e555a55, 0x55555555, 0x5b6db6db}; + + u32 r = seed2[(a + (a >= 10)) / 5]; + return b ? ~r : r; }
@@ -2081,75 +2004,68 @@
static u32 get_etalon(int flip, u32 addr) { - u32 mask_byte = 0; - int comp1 = (addr >> 1) & 1; - int comp2 = (addr >> 3) & 0x1f; - int comp3 = (addr >> 8) & 0xf; + int comp1 = (addr >> 1) & 1; + int comp2 = (addr >> 3) & 0x1f; + int comp3 = (addr >> 8) & 0xf; int comp4 = (addr >> 12) & 0xf; int comp5 = (addr >> 16) & 0x1f; u32 mask_bit = ~(0x10001 << comp3); - u32 part1; - u32 part2; + u32 mask_byte = 0; + u32 part1, part2; int byte;
- part2 = - ((seed1[comp5] >> - make_shift(comp2, comp5, - (comp3 >> 3) | (comp1 << 2) | 2)) & 1) ^ flip; - part1 = - ((seed1[comp5] >> - make_shift(comp2, comp5, - (comp3 >> 3) | (comp1 << 2) | 0)) & 1) ^ flip; + part2 = ((seed1[comp5] >> + make_shift(comp2, comp5, (comp3 >> 3) | (comp1 << 2) | 2)) & 1) ^ flip; + + part1 = ((seed1[comp5] >> + make_shift(comp2, comp5, (comp3 >> 3) | (comp1 << 2) | 0)) & 1) ^ flip;
for (byte = 0; byte < 4; byte++) if ((get_seed2(comp5, comp4) >> - make_shift(comp2, comp5, (byte | (comp1 << 2)))) & 1) + make_shift(comp2, comp5, (byte | (comp1 << 2)))) & 1) mask_byte |= 0xff << (8 * byte);
- return (mask_bit & mask_byte) | (part1 << comp3) | (part2 << - (comp3 + 16)); + return (mask_bit & mask_byte) | (part1 << comp3) | (part2 << (comp3 + 16)); }
static void -write_testing_type2(struct raminfo *info, u8 totalrank, u8 region, u8 block, - char flip) +write_testing_type2(struct raminfo *info, u8 totalrank, u8 region, u8 block, char flip) { int i; for (i = 0; i < 2048; i++) - write32p((totalrank << 28) | (region << 25) | (block << 16) | - (i << 2), get_etalon(flip, (block << 16) | (i << 2))); + write32p((totalrank << 28) | (region << 25) | (block << 16) | (i << 2), + get_etalon(flip, (block << 16) | (i << 2))); }
static u8 -check_testing_type2(struct raminfo *info, u8 totalrank, u8 region, u8 block, - char flip) +check_testing_type2(struct raminfo *info, u8 totalrank, u8 region, u8 block, char flip) { u8 failmask = 0; u32 failxor[2]; - int i; - int comp1, comp2, comp3; + int i, comp1, comp2, comp3;
failxor[0] = 0; failxor[1] = 0;
enable_cache(totalrank << 28, 134217728); + for (comp3 = 0; comp3 < 2 && failmask != 0xff; comp3++) { for (comp1 = 0; comp1 < 16; comp1++) - for (comp2 = 0; comp2 < 64; comp2++) { - u32 addr = - (totalrank << 28) | (region << 25) | (block - << 16) - | (comp3 << 12) | (comp2 << 6) | (comp1 << - 2); - failxor[comp1 & 1] |= - read32p(addr) ^ get_etalon(flip, addr); - } + for (comp2 = 0; comp2 < 64; comp2++) { + u32 addr = (totalrank << 28) | (region << 25) | (block << 16) | + (comp3 << 12) | (comp2 << 6) | (comp1 << 2); + + failxor[comp1 & 1] |= read32p(addr) ^ get_etalon(flip, addr); + } + for (i = 0; i < 8; i++) if ((0xff << (8 * (i % 4))) & failxor[i / 4]) failmask |= 1 << i; } + disable_cache(); flush_cache((totalrank << 28) | (region << 25) | (block << 16), 16384); + return failmask; }
@@ -2173,18 +2089,18 @@ for (i = 0; i < 8; i++) if (in[i] != COMPLETE) return 0; + return 1; }
-static void -do_fsm(enum state *state, u16 *counter, - u8 fail_mask, int margin, int uplimit, - u8 *res_low, u8 *res_high, u8 val) +static void do_fsm(enum state *state, u16 *counter, u8 fail_mask, int margin, int uplimit, + u8 *res_low, u8 *res_high, u8 val) { int lane;
for (lane = 0; lane < 8; lane++) { int is_fail = (fail_mask >> lane) & 1; + switch (state[lane]) { case BEFORE_USABLE: if (!is_fail) { @@ -2195,6 +2111,7 @@ counter[lane] = 0; state[lane] = BEFORE_USABLE; break; + case AT_USABLE: if (!is_fail) { ++counter[lane]; @@ -2209,6 +2126,7 @@ counter[lane] = 0; state[lane] = BEFORE_USABLE; break; + case AT_MARGIN: if (is_fail) { state[lane] = COMPLETE; @@ -2222,6 +2140,7 @@ } } break; + case COMPLETE: break; } @@ -2229,9 +2148,8 @@ }
static void -train_ram_at_178(struct raminfo *info, u8 channel, int slot, int rank, - u8 total_rank, u8 reg_178, int first_run, int niter, - timing_bounds_t * timings) +train_ram_at_178(struct raminfo *info, u8 channel, int slot, int rank, u8 total_rank, + u8 reg_178, int first_run, int niter, timing_bounds_t *timings) { int lane; enum state state[8]; @@ -2247,17 +2165,17 @@
if (!first_run) { int is_all_ok = 1; - for (lane = 0; lane < 8; lane++) - if (timings[reg_178][channel][slot][rank][lane]. - smallest == - timings[reg_178][channel][slot][rank][lane]. - largest) { - timings[reg_178][channel][slot][rank][lane]. - smallest = 0; - timings[reg_178][channel][slot][rank][lane]. - largest = 0; + for (lane = 0; lane < 8; lane++) { + + if (timings[reg_178][channel][slot][rank][lane].smallest + == timings[reg_178][channel][slot][rank][lane].largest) { + + timings[reg_178][channel][slot][rank][lane].smallest = 0; + timings[reg_178][channel][slot][rank][lane].largest = 0; is_all_ok = 0; } + } + if (is_all_ok) { for (i = 0; i < 8; i++) state[i] = COMPLETE; @@ -2266,258 +2184,200 @@
for (reg1b3 = 0; reg1b3 < 0x30 && !validate_state(state); reg1b3++) { u8 failmask = 0; + write_1d0(reg1b3 ^ 32, 0x1b3, 6, 1); write_1d0(reg1b3 ^ 32, 0x1a3, 6, 1); + failmask = check_testing(info, total_rank, 0); + MCHBAR32_OR(0xfb0, 0x00030000); - do_fsm(state, count, failmask, 5, 47, lower_usable, - upper_usable, reg1b3); + + do_fsm(state, count, failmask, 5, 47, lower_usable, upper_usable, reg1b3); }
if (reg1b3) { write_1d0(0, 0x1b3, 6, 1); write_1d0(0, 0x1a3, 6, 1); + for (lane = 0; lane < 8; lane++) { - if (state[lane] == COMPLETE) { - timings[reg_178][channel][slot][rank][lane]. - smallest = - lower_usable[lane] + - (info->training. - lane_timings[0][channel][slot][rank][lane] - & 0x3F) - 32; - timings[reg_178][channel][slot][rank][lane]. - largest = - upper_usable[lane] + - (info->training. - lane_timings[0][channel][slot][rank][lane] - & 0x3F) - 32; - } - } + if (state[lane] == COMPLETE) { + + timings[reg_178][channel][slot][rank][lane].smallest + = + lower_usable[lane] + + + (info->training.lane_timings[0][channel][slot][rank][lane] & 0x3F) + - + 32; + + timings[reg_178][channel][slot][rank][lane].largest + = + upper_usable[lane] + + + (info->training.lane_timings[0][channel][slot][rank][lane] & 0x3F) + - + 32; + + }} /* for each lane, if complete */ }
if (!first_run) { - for (lane = 0; lane < 8; lane++) - if (state[lane] == COMPLETE) { - write_500(info, channel, - timings[reg_178][channel][slot][rank] - [lane].smallest, - get_timing_register_addr(lane, 0, - slot, rank), - 9, 1); - write_500(info, channel, - timings[reg_178][channel][slot][rank] - [lane].smallest + - info->training. - lane_timings[1][channel][slot][rank] - [lane] - - - info->training. - lane_timings[0][channel][slot][rank] - [lane], get_timing_register_addr(lane, - 1, - slot, - rank), - 9, 1); - num_successfully_checked[lane] = 0; - } else - num_successfully_checked[lane] = -1; + + for (lane = 0; lane < 8; lane++) { + if (state[lane] == COMPLETE) { + write_500(info, channel, + timings[reg_178][channel][slot][rank][lane].smallest, + get_timing_register_addr(lane, 0, slot, rank), 9, 1); + + write_500(info, channel, + timings[reg_178][channel][slot][rank][lane].smallest + + info->training.lane_timings[1][channel][slot][rank][lane] - + info->training.lane_timings[0][channel][slot][rank][lane], + get_timing_register_addr(lane, 1, slot, rank), 9, 1); + + num_successfully_checked[lane] = 0; + + } else { + num_successfully_checked[lane] = -1; + }} /* for each lane, depending whether it's complete */
do { u8 failmask = 0; for (i = 0; i < niter; i++) { if (failmask == 0xFF) break; - failmask |= - check_testing_type2(info, total_rank, 2, i, - 0); - failmask |= - check_testing_type2(info, total_rank, 3, i, - 1); + + failmask |= check_testing_type2(info, total_rank, 2, i, 0); + failmask |= check_testing_type2(info, total_rank, 3, i, 1); } + MCHBAR32_OR(0xfb0, 0x00030000); - for (lane = 0; lane < 8; lane++) + + /* FIXME: Visually, this is hideously atrocious. */ + for (lane = 0; lane < 8; lane++) { if (num_successfully_checked[lane] != 0xffff) { if ((1 << lane) & failmask) { - if (timings[reg_178][channel] - [slot][rank][lane]. - largest <= - timings[reg_178][channel] - [slot][rank][lane].smallest) - num_successfully_checked - [lane] = -1; - else { - num_successfully_checked - [lane] = 0; - timings[reg_178] - [channel][slot] - [rank][lane]. - smallest++; - write_500(info, channel, - timings - [reg_178] - [channel] - [slot][rank] - [lane]. - smallest, - get_timing_register_addr - (lane, 0, - slot, rank), - 9, 1); - write_500(info, channel, - timings - [reg_178] - [channel] - [slot][rank] - [lane]. - smallest + - info-> - training. - lane_timings - [1][channel] - [slot][rank] - [lane] - - - info-> - training. - lane_timings - [0][channel] - [slot][rank] - [lane], - get_timing_register_addr - (lane, 1, - slot, rank), - 9, 1); - } - } else - num_successfully_checked[lane] - ++; - } - } - while (!check_bounded(num_successfully_checked, 2)) - ;
- for (lane = 0; lane < 8; lane++) - if (state[lane] == COMPLETE) { - write_500(info, channel, - timings[reg_178][channel][slot][rank] - [lane].largest, - get_timing_register_addr(lane, 0, - slot, rank), - 9, 1); - write_500(info, channel, - timings[reg_178][channel][slot][rank] - [lane].largest + - info->training. - lane_timings[1][channel][slot][rank] - [lane] - - - info->training. - lane_timings[0][channel][slot][rank] - [lane], get_timing_register_addr(lane, - 1, - slot, - rank), - 9, 1); - num_successfully_checked[lane] = 0; - } else - num_successfully_checked[lane] = -1; + if (timings[reg_178][channel][slot][rank] + [lane].largest <= timings[reg_178] + [channel][slot][rank][lane].smallest) { + + num_successfully_checked[lane] = -1; + + } else { + num_successfully_checked[lane] = 0; + + timings[reg_178][channel][slot][rank] + [lane].smallest++; + + write_500(info, channel, timings + [reg_178][channel][slot][rank] + [lane].smallest, + get_timing_register_addr + (lane, 0, slot, rank), 9, 1); + + write_500(info, channel, timings + [reg_178][channel][slot][rank] + [lane].smallest + info-> + training.lane_timings[1] + [channel][slot][rank][lane] - + info->training.lane_timings[0] + [channel][slot][rank][lane], + get_timing_register_addr + (lane, 1, slot, rank), 9, 1); + } + + } else { + num_successfully_checked[lane]++; + } + } + } + } while (!check_bounded(num_successfully_checked, 2)); + + for (lane = 0; lane < 8; lane++) { + if (state[lane] == COMPLETE) { + write_500(info, channel, + timings[reg_178][channel][slot][rank][lane].largest, + get_timing_register_addr(lane, 0, slot, rank), 9, 1); + + write_500(info, channel, + timings[reg_178][channel][slot][rank][lane].largest + + info->training.lane_timings[1][channel][slot][rank][lane] - + info->training.lane_timings[0][channel][slot][rank][lane], + get_timing_register_addr(lane, 1, slot, rank), 9, 1); + + num_successfully_checked[lane] = 0; + + } else { + num_successfully_checked[lane] = -1; + }} /* for each lane, depending whether it's complete */
do { int failmask = 0; for (i = 0; i < niter; i++) { - if (failmask == 0xFF) + if (failmask == 0xff) break; - failmask |= - check_testing_type2(info, total_rank, 2, i, - 0); - failmask |= - check_testing_type2(info, total_rank, 3, i, - 1); + + failmask |= check_testing_type2(info, total_rank, 2, i, 0); + failmask |= check_testing_type2(info, total_rank, 3, i, 1); }
MCHBAR32_OR(0xfb0, 0x00030000); + + /* FIXME: Visually, this is hideously atrocious. */ for (lane = 0; lane < 8; lane++) { if (num_successfully_checked[lane] != 0xffff) { if ((1 << lane) & failmask) { - if (timings[reg_178][channel] - [slot][rank][lane]. - largest <= - timings[reg_178][channel] - [slot][rank][lane]. - smallest) { - num_successfully_checked - [lane] = -1; + + if (timings[reg_178][channel][slot][rank] + [lane].largest <= timings[reg_178] + [channel][slot][rank][lane].smallest) { + + num_successfully_checked[lane] = -1; + } else { - num_successfully_checked - [lane] = 0; - timings[reg_178] - [channel][slot] - [rank][lane]. - largest--; - write_500(info, channel, - timings - [reg_178] - [channel] - [slot][rank] - [lane]. - largest, - get_timing_register_addr - (lane, 0, - slot, rank), - 9, 1); - write_500(info, channel, - timings - [reg_178] - [channel] - [slot][rank] - [lane]. - largest + - info-> - training. - lane_timings - [1][channel] - [slot][rank] - [lane] - - - info-> - training. - lane_timings - [0][channel] - [slot][rank] - [lane], - get_timing_register_addr - (lane, 1, - slot, rank), - 9, 1); + num_successfully_checked[lane] = 0; + + timings[reg_178][channel][slot][rank] + [lane].largest--; + + write_500(info, channel, timings + [reg_178][channel][slot][rank] + [lane].largest, + get_timing_register_addr + (lane, 0, slot, rank), 9, 1); + + write_500(info, channel, timings + [reg_178][channel][slot][rank] + [lane].largest + info-> + training.lane_timings[1] + [channel][slot][rank][lane] - + info->training.lane_timings[0] + [channel][slot][rank][lane], + get_timing_register_addr + (lane, 1, slot, rank), 9, 1); } - } else - num_successfully_checked[lane] - ++; + + } else { + num_successfully_checked[lane]++; + } } } - } - while (!check_bounded(num_successfully_checked, 3)) - ; + } while (!check_bounded(num_successfully_checked, 3));
for (lane = 0; lane < 8; lane++) { - write_500(info, channel, - info->training. + write_500(info, channel, info->training. lane_timings[0][channel][slot][rank][lane], - get_timing_register_addr(lane, 0, slot, rank), - 9, 1); - write_500(info, channel, - info->training. + get_timing_register_addr(lane, 0, slot, rank), 9, 1); + + write_500(info, channel, info->training. lane_timings[1][channel][slot][rank][lane], - get_timing_register_addr(lane, 1, slot, rank), - 9, 1); - if (timings[reg_178][channel][slot][rank][lane]. - largest <= - timings[reg_178][channel][slot][rank][lane]. - smallest) { - timings[reg_178][channel][slot][rank][lane]. - largest = 0; - timings[reg_178][channel][slot][rank][lane]. - smallest = 0; + get_timing_register_addr(lane, 1, slot, rank), 9, 1); + + if (timings[reg_178][channel][slot][rank][lane].largest + <= timings[reg_178][channel][slot][rank][lane].smallest) { + timings[reg_178][channel][slot][rank][lane].largest = 0; + timings[reg_178][channel][slot][rank][lane].smallest = 0; } } } @@ -2535,10 +2395,9 @@ write_1d0(val, 0x10b, 6, 1);
FOR_POPULATED_RANKS_BACKWARDS for (lane = 0; lane < 9; lane++) { - u16 reg_500; - reg_500 = read_500(info, channel, - get_timing_register_addr(lane, 0, slot, - rank), 9); + u16 reg_500 = read_500(info, channel, + get_timing_register_addr(lane, 0, slot, rank), 9); + if (val == 1) { if (lut16[info->clock_speed_index] <= reg_500) reg_500 -= lut16[info->clock_speed_index]; @@ -2548,7 +2407,7 @@ reg_500 += lut16[info->clock_speed_index]; } write_500(info, channel, reg_500, - get_timing_register_addr(lane, 0, slot, rank), 9, 1); + get_timing_register_addr(lane, 0, slot, rank), 9, 1); } }
@@ -2556,12 +2415,13 @@ { int channel; for (channel = 0; channel < NUM_CHANNELS; channel++) { - u8 t; - t = MCHBAR8((channel << 10) + 0x5f8); + + u8 t = MCHBAR8((channel << 10) + 0x5f8); if (onoff) t |= 1; else t &= ~1; + MCHBAR8((channel << 10) + 0x5f8) = t; } } @@ -2577,22 +2437,18 @@ }
static void -write_500_timings_type(struct raminfo *info, int channel, int slot, int rank, - int type) +write_500_timings_type(struct raminfo *info, int channel, int slot, int rank, int type) { int lane;
for (lane = 0; lane < 8; lane++) write_500(info, channel, - info->training. - lane_timings[type][channel][slot][rank][lane], - get_timing_register_addr(lane, type, slot, rank), 9, - 0); + info->training.lane_timings[type][channel][slot][rank][lane], + get_timing_register_addr(lane, type, slot, rank), 9, 0); }
static void -try_timing_offsets(struct raminfo *info, int channel, - int slot, int rank, int totalrank) +try_timing_offsets(struct raminfo *info, int channel, int slot, int rank, int totalrank) { u16 count[8]; enum state state[8]; @@ -2609,9 +2465,8 @@
for (lane = 0; lane < 8; lane++) write_500(info, channel, - info->training. - lane_timings[2][channel][slot][rank][lane] + 32, - get_timing_register_addr(lane, 3, slot, rank), 9, 1); + info->training.lane_timings[2][channel][slot][rank][lane] + 32, + get_timing_register_addr(lane, 3, slot, rank), 9, 1);
for (timing_offset = 0; !validate_state(state) && timing_offset < 64; timing_offset++) { @@ -2623,8 +2478,8 @@ write_testing(info, totalrank, flip); failmask |= check_testing(info, totalrank, flip); } - do_fsm(state, count, failmask, 10, 63, lower_usable, - upper_usable, timing_offset); + do_fsm(state, count, failmask, 10, 63, lower_usable, upper_usable, + timing_offset); } write_1d0(0, 0x1bb, 6, 1); dump_timings(info); @@ -2645,24 +2500,25 @@ } } write_500(info, channel, - info->training. - lane_timings[2][channel][slot][rank][lane] + - (upper_usable[lane] + lower_usable[lane]) / 2 - bias, - get_timing_register_addr(lane, 3, slot, rank), 9, 1); + info->training.lane_timings[2][channel][slot][rank][lane] + + (upper_usable[lane] + lower_usable[lane]) / 2 - bias, + get_timing_register_addr(lane, 3, slot, rank), 9, 1); + info->training.timing2_bounds[channel][slot][rank][lane][0] = - info->training.lane_timings[2][channel][slot][rank][lane] + - lower_usable[lane]; + info->training.lane_timings[2][channel][slot][rank][lane] + + lower_usable[lane]; + info->training.timing2_bounds[channel][slot][rank][lane][1] = - info->training.lane_timings[2][channel][slot][rank][lane] + - upper_usable[lane]; + info->training.lane_timings[2][channel][slot][rank][lane] + + upper_usable[lane]; + info->training.timing2_offset[channel][slot][rank][lane] = - info->training.lane_timings[2][channel][slot][rank][lane]; + info->training.lane_timings[2][channel][slot][rank][lane]; } }
-static u8 -choose_training(struct raminfo *info, int channel, int slot, int rank, - int lane, timing_bounds_t * timings, u8 center_178) +static u8 choose_training(struct raminfo *info, int channel, int slot, int rank, int lane, + timing_bounds_t * timings, u8 center_178) { u16 central_weight; u16 side_weight; @@ -2678,16 +2534,15 @@ if (info->silicon_revision == 1 && channel == 1) { central_weight = 5; side_weight = 20; - if ((info-> - populated_ranks_mask[1] ^ (info-> - populated_ranks_mask[1] >> 2)) & - 1) + if ((info->populated_ranks_mask[1] ^ (info->populated_ranks_mask[1] >> 2)) & 1) span = 18; } + if ((info->populated_ranks_mask[0] & 5) == 5) { central_weight = 20; side_weight = 20; } + if (info->clock_speed_index >= 2 && (info->populated_ranks_mask[0] & 5) == 5 && slot == 1) { if (info->silicon_revision == 1) { @@ -2711,18 +2566,20 @@ central_weight = 20; } } - for (reg_178 = center_178 - span; reg_178 <= center_178 + span; - reg_178 += span) { + for (reg_178 = center_178 - span; reg_178 <= center_178 + span; reg_178 += span) { u8 smallest; u8 largest; largest = timings[reg_178][channel][slot][rank][lane].largest; smallest = timings[reg_178][channel][slot][rank][lane].smallest; + if (largest - smallest + 1 >= 5) { + unsigned int weight; if (reg_178 == center_178) weight = central_weight; else weight = side_weight; + sum += weight * (largest + smallest); count += weight; } @@ -2730,21 +2587,23 @@ dump_timings(info); if (count == 0) die("Couldn't discover DRAM timings (2)\n"); + result = sum / (2 * count); - lower_margin = - result - timings[center_178][channel][slot][rank][lane].smallest; - upper_margin = - timings[center_178][channel][slot][rank][lane].largest - result; + lower_margin = result - timings[center_178][channel][slot][rank][lane].smallest; + upper_margin = timings[center_178][channel][slot][rank][lane].largest - result; + if (upper_margin < 10 && lower_margin > 10) result -= MIN(lower_margin - 10, 10 - upper_margin); + if (upper_margin > 10 && lower_margin < 10) result += MIN(upper_margin - 10, 10 - lower_margin); + return result; }
#define STANDARD_MIN_MARGIN 5
-static u8 choose_reg178(struct raminfo *info, timing_bounds_t * timings) +static u8 choose_reg178(struct raminfo *info, timing_bounds_t *timings) { u16 margin[64]; int lane, rank, slot, channel; @@ -2754,12 +2613,12 @@ for (reg178 = reg178_min[info->clock_speed_index]; reg178 < reg178_max[info->clock_speed_index]; reg178 += reg178_step[info->clock_speed_index]) { + margin[reg178] = -1; FOR_POPULATED_RANKS_BACKWARDS for (lane = 0; lane < 8; lane++) { - int curmargin = - timings[reg178][channel][slot][rank][lane].largest - - timings[reg178][channel][slot][rank][lane]. - smallest + 1; + int curmargin = timings[reg178][channel][slot][rank][lane].largest - + timings[reg178][channel][slot][rank][lane].smallest + 1; + if (curmargin < margin[reg178]) margin[reg178] = curmargin; } @@ -2778,23 +2637,21 @@
for (threshold = 30; threshold >= 5; threshold--) { int usable_length = 0; - int smallest_fount = 0; + int smallest_found = 0; for (reg178 = reg178_min[info->clock_speed_index]; reg178 < reg178_max[info->clock_speed_index]; reg178 += reg178_step[info->clock_speed_index]) if (margin[reg178] >= threshold) { - usable_length += - reg178_step[info->clock_speed_index]; - info->training.reg178_largest = - reg178 - - 2 * reg178_step[info->clock_speed_index];
- if (!smallest_fount) { - smallest_fount = 1; + usable_length += reg178_step[info->clock_speed_index]; + + info->training.reg178_largest = + reg178 - 2 * reg178_step[info->clock_speed_index]; + + if (!smallest_found) { + smallest_found = 1; info->training.reg178_smallest = - reg178 + - reg178_step[info-> - clock_speed_index]; + reg178 + reg178_step[info->clock_speed_index]; } } if (usable_length >= 0x21) @@ -2806,36 +2663,31 @@
static int check_cached_sanity(struct raminfo *info) { - int lane; - int slot, rank; - int channel; + int channel, slot, rank, lane;
if (!info->cached_training) return 0;
- for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - for (lane = 0; lane < 8 + info->use_ecc; lane++) { - u16 cached_value, estimation_value; - cached_value = - info->cached_training-> - lane_timings[1][channel][slot][rank] - [lane]; - if (cached_value >= 0x18 - && cached_value <= 0x1E7) { - estimation_value = - info->training. - lane_timings[1][channel] - [slot][rank][lane]; - if (estimation_value < - cached_value - 24) - return 0; - if (estimation_value > - cached_value + 24) - return 0; - } - } + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + for (lane = 0; lane < 8 + info->use_ecc; lane++) { + u16 cached_value, estimation_value; + + cached_value = info->cached_training->lane_timings[1] + [channel][slot][rank][lane]; + + if (cached_value >= 0x18 && cached_value <= 0x1e7) { + estimation_value = + info->training.lane_timings[1][channel][slot][rank][lane]; + + if (estimation_value < cached_value - 24) + return 0; + + if (estimation_value > cached_value + 24) + return 0; + } + }}}} /* For each channel, slot, rank, lane */ return 1; }
@@ -2851,15 +2703,15 @@ if (!check_cached_sanity(info)) return 0;
- info->training.reg178_center = info->cached_training->reg178_center; + info->training.reg178_center = info->cached_training->reg178_center; info->training.reg178_smallest = info->cached_training->reg178_smallest; - info->training.reg178_largest = info->cached_training->reg178_largest; - memcpy(&info->training.timing_bounds, - &info->cached_training->timing_bounds, - sizeof(info->training.timing_bounds)); - memcpy(&info->training.timing_offset, - &info->cached_training->timing_offset, - sizeof(info->training.timing_offset)); + info->training.reg178_largest = info->cached_training->reg178_largest; + + memcpy(&info->training.timing_bounds, &info->cached_training->timing_bounds, + sizeof(info->training.timing_bounds)); + + memcpy(&info->training.timing_offset, &info->cached_training->timing_offset, + sizeof(info->training.timing_offset));
write_1d0(2, 0x142, 3, 1); saved_243[0] = MCHBAR8(0x243); @@ -2868,13 +2720,15 @@ MCHBAR8(0x643) = saved_243[1] | 2; set_ecc(0); pci_write_config16(NORTHBRIDGE, 0xc8, 3); + if (read_1d0(0x10b, 6) & 1) set_10b(info, 0); + for (tm = 0; tm < 2; tm++) { int totalrank;
- set_178(tm ? info->cached_training->reg178_largest : info-> - cached_training->reg178_smallest); + set_178(tm ? info->cached_training->reg178_largest + : info->cached_training->reg178_smallest);
totalrank = 0; /* Check timing ranges. With i == 0 we check smallest one and with @@ -2885,76 +2739,51 @@ FOR_POPULATED_RANKS_BACKWARDS { for (i = 0; i < 2; i++) { for (lane = 0; lane < 8; lane++) { - write_500(info, channel, - info->cached_training-> - timing2_bounds[channel][slot] - [rank][lane][i], - get_timing_register_addr(lane, - 3, - slot, - rank), - 9, 1); + write_500(info, channel, info->cached_training-> + timing2_bounds[channel][slot][rank][lane][i], + get_timing_register_addr(lane, 3, slot, rank), + 9, 1);
if (!i) - write_500(info, channel, - info-> - cached_training-> - timing2_offset - [channel][slot][rank] - [lane], - get_timing_register_addr - (lane, 2, slot, rank), - 9, 1); - write_500(info, channel, - i ? info->cached_training-> - timing_bounds[tm][channel] - [slot][rank][lane]. - largest : info-> - cached_training-> - timing_bounds[tm][channel] - [slot][rank][lane].smallest, - get_timing_register_addr(lane, - 0, - slot, - rank), - 9, 1); - write_500(info, channel, - info->cached_training-> - timing_offset[channel][slot] - [rank][lane] + - (i ? info->cached_training-> - timing_bounds[tm][channel] - [slot][rank][lane]. - largest : info-> - cached_training-> - timing_bounds[tm][channel] - [slot][rank][lane]. - smallest) - 64, - get_timing_register_addr(lane, - 1, - slot, - rank), - 9, 1); + write_500(info, channel, info->cached_training-> + timing2_offset[channel][slot][rank] + [lane], get_timing_register_addr(lane, + 2, slot, rank), 9, 1); + + write_500(info, channel, i ? info->cached_training-> + timing_bounds[tm][channel][slot][rank][lane]. + largest : info->cached_training->timing_bounds + [tm][channel][slot][rank][lane].smallest, + get_timing_register_addr(lane, 0, slot, rank), + 9, 1); + + write_500(info, channel, info->cached_training-> + timing_offset[channel][slot][rank][lane] + + (i ? info->cached_training->timing_bounds[tm] + [channel][slot][rank][lane].largest + : info->cached_training->timing_bounds[tm] + [channel][slot][rank][lane].smallest + ) - 64, + get_timing_register_addr(lane, 1, slot, rank), + 9, 1); } for (j = 0; j < 2; j++) { - u8 failmask; - u8 expected_failmask; + u8 failmask, expected_failmask; char reg1b3;
reg1b3 = (j == 1) + 4; - reg1b3 = - j == i ? reg1b3 : (-reg1b3) & 0x3f; + reg1b3 = (j == i) ? reg1b3 : (-reg1b3) & 0x3f; + write_1d0(reg1b3, 0x1bb, 6, 1); write_1d0(reg1b3, 0x1b3, 6, 1); write_1d0(reg1b3, 0x1a3, 6, 1);
flip = !flip; write_testing(info, totalrank, flip); - failmask = - check_testing(info, totalrank, - flip); - expected_failmask = - j == 0 ? 0x00 : 0xff; + + failmask = check_testing(info, totalrank, flip); + expected_failmask = j == 0 ? 0x00 : 0xff; + if (failmask != expected_failmask) goto fail; } @@ -2964,8 +2793,10 @@ }
set_178(info->cached_training->reg178_center); + if (info->use_ecc) set_ecc(1); + write_training_data(info); write_1d0(0, 322, 3, 1); info->training = *info->cached_training; @@ -3010,6 +2841,7 @@ saved_243[1] = MCHBAR8(0x643); MCHBAR8(0x243) = saved_243[0] | 2; MCHBAR8(0x643) = saved_243[1] | 2; + switch (info->clock_speed_index) { case 0: niter = 5; @@ -3021,6 +2853,7 @@ niter = 19; break; } + set_ecc(0);
FOR_POPULATED_RANKS_BACKWARDS { @@ -3037,138 +2870,125 @@ totalrank++; }
- if (reg178_min[info->clock_speed_index] < - reg178_max[info->clock_speed_index]) - memset(timings[reg178_min[info->clock_speed_index]], 0, - sizeof(timings[0]) * - (reg178_max[info->clock_speed_index] - - reg178_min[info->clock_speed_index])); - for (reg_178 = reg178_min[info->clock_speed_index]; - reg_178 < reg178_max[info->clock_speed_index]; + if (reg178_min[info->clock_speed_index] < reg178_max[info->clock_speed_index]) { + memset(timings[reg178_min[info->clock_speed_index]], 0, sizeof(timings[0]) * + (reg178_max[info->clock_speed_index] - + reg178_min[info->clock_speed_index])); + } + + for (reg_178 = reg178_min[info->clock_speed_index]; + reg_178 < reg178_max[info->clock_speed_index]; reg_178 += reg178_step[info->clock_speed_index]) { + totalrank = 0; set_178(reg_178); - for (channel = NUM_CHANNELS - 1; channel >= 0; channel--) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) { - memset(&timings[reg_178][channel][slot] - [rank][0].smallest, 0, 16); - if (info-> - populated_ranks[channel][slot] - [rank]) { - train_ram_at_178(info, channel, - slot, rank, - totalrank, - reg_178, 1, - niter, - timings); - totalrank++; - } - } + + for (channel = NUM_CHANNELS - 1; channel >= 0; channel--) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + + memset(&timings[reg_178][channel][slot][rank][0].smallest, 0, 16); + + if (info->populated_ranks[channel][slot][rank]) { + + train_ram_at_178(info, channel, slot, rank, totalrank, + reg_178, 1, niter, timings); + + totalrank++; + } + }}} /* for each channel, slot, rank */ }
reg178_center = choose_reg178(info, timings);
FOR_POPULATED_RANKS_BACKWARDS for (lane = 0; lane < 8; lane++) { - info->training.timing_bounds[0][channel][slot][rank][lane]. - smallest = - timings[info->training. - reg178_smallest][channel][slot][rank][lane]. - smallest; - info->training.timing_bounds[0][channel][slot][rank][lane]. - largest = - timings[info->training. - reg178_smallest][channel][slot][rank][lane].largest; - info->training.timing_bounds[1][channel][slot][rank][lane]. - smallest = - timings[info->training. - reg178_largest][channel][slot][rank][lane].smallest; - info->training.timing_bounds[1][channel][slot][rank][lane]. - largest = - timings[info->training. - reg178_largest][channel][slot][rank][lane].largest; + + info->training.timing_bounds[0][channel][slot][rank][lane].smallest = timings + [info->training.reg178_smallest][channel][slot][rank][lane].smallest; + + info->training.timing_bounds[0][channel][slot][rank][lane].largest = timings + [info->training.reg178_smallest][channel][slot][rank][lane].largest; + + info->training.timing_bounds[1][channel][slot][rank][lane].smallest = timings + [info->training.reg178_largest][channel][slot][rank][lane].smallest; + + info->training.timing_bounds[1][channel][slot][rank][lane].largest = timings + [info->training.reg178_largest][channel][slot][rank][lane].largest; + info->training.timing_offset[channel][slot][rank][lane] = - info->training.lane_timings[1][channel][slot][rank][lane] - - - info->training.lane_timings[0][channel][slot][rank][lane] + - 64; + info->training.lane_timings[1][channel][slot][rank][lane] - + info->training.lane_timings[0][channel][slot][rank][lane] + 64; }
if (info->silicon_revision == 1 - && (info-> - populated_ranks_mask[1] ^ (info-> - populated_ranks_mask[1] >> 2)) & 1) { + && (info->populated_ranks_mask[1] ^ (info->populated_ranks_mask[1] >> 2)) & 1) { + int ranks_after_channel1;
totalrank = 0; - for (reg_178 = reg178_center - 18; + for (reg_178 = reg178_center - 18; reg_178 <= reg178_center + 18; reg_178 += 18) { + totalrank = 0; set_178(reg_178); - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) { - if (info-> - populated_ranks[1][slot][rank]) { - train_ram_at_178(info, 1, slot, - rank, - totalrank, - reg_178, 0, - niter, - timings); - totalrank++; - } + + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + + if (info->populated_ranks[1][slot][rank]) { + train_ram_at_178(info, 1, slot, rank, totalrank, + reg_178, 0, niter, timings); + totalrank++; } + }} /* for each slot, rank */ } ranks_after_channel1 = totalrank;
- for (reg_178 = reg178_center - 12; + for (reg_178 = reg178_center - 12; reg_178 <= reg178_center + 12; reg_178 += 12) { + totalrank = ranks_after_channel1; set_178(reg_178); - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - if (info-> - populated_ranks[0][slot][rank]) { - train_ram_at_178(info, 0, slot, - rank, - totalrank, - reg_178, 0, - niter, - timings); - totalrank++; - } + + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + + if (info->populated_ranks[0][slot][rank]) { + train_ram_at_178(info, 0, slot, rank, totalrank, + reg_178, 0, niter, timings); + totalrank++; + } + }} /* for each slot, rank */
} } else { - for (reg_178 = reg178_center - 12; + for (reg_178 = reg178_center - 12; reg_178 <= reg178_center + 12; reg_178 += 12) { + totalrank = 0; set_178(reg_178); + FOR_POPULATED_RANKS_BACKWARDS { - train_ram_at_178(info, channel, slot, rank, - totalrank, reg_178, 0, niter, - timings); + train_ram_at_178(info, channel, slot, rank, totalrank, + reg_178, 0, niter, timings); totalrank++; } } } - set_178(reg178_center); - FOR_POPULATED_RANKS_BACKWARDS for (lane = 0; lane < 8; lane++) { - u16 tm0;
- tm0 = - choose_training(info, channel, slot, rank, lane, timings, - reg178_center); - write_500(info, channel, tm0, - get_timing_register_addr(lane, 0, slot, rank), 9, 1); + FOR_POPULATED_RANKS_BACKWARDS for (lane = 0; lane < 8; lane++) { + + u16 tm0; + tm0 = choose_training(info, channel, slot, rank, lane, timings, reg178_center); + + write_500(info, channel, tm0, get_timing_register_addr(lane, 0, slot, rank), + 9, 1); + write_500(info, channel, - tm0 + - info->training. - lane_timings[1][channel][slot][rank][lane] - - info->training. - lane_timings[0][channel][slot][rank][lane], - get_timing_register_addr(lane, 1, slot, rank), 9, 1); + tm0 + info->training.lane_timings[1][channel][slot][rank][lane] + - info->training.lane_timings[0][channel][slot][rank][lane], + get_timing_register_addr(lane, 1, slot, rank), 9, 1); }
totalrank = 0; @@ -3194,9 +3014,11 @@
if (!try_cached_training(info)) do_ram_training(info); + if ((info->silicon_revision == 2 || info->silicon_revision == 3) - && info->clock_speed_index < 2) + && info->clock_speed_index < 2) set_10b(info, 1); + MCHBAR16(0xfc4) = saved_fc4; }
@@ -3208,7 +3030,7 @@ a = b; b = t; } - /* invariant a < b. */ + /* invariant a < b. */ while (a) { t = b % a; b = a; @@ -3242,27 +3064,25 @@ int freq_max_reduced; };
-static void -compute_frequence_ratios(struct raminfo *info, u16 freq1, u16 freq2, - int num_cycles_2, int num_cycles_1, int round_it, - int add_freqs, struct stru1 *result) +static void compute_frequence_ratios(struct raminfo *info, u16 freq1, u16 freq2, + int num_cycles_2, int num_cycles_1, int round_it, + int add_freqs, struct stru1 *result) { - int g; - int common_time_unit_ps; - int freq1_reduced, freq2_reduced; - int freq_min_reduced; - int freq_max_reduced; - int freq3, freq4; + int g, common_time_unit_ps, freq1_reduced, freq2_reduced, freq3, freq4; + int freq_min_reduced, freq_max_reduced;
g = gcd(freq1, freq2); + freq1_reduced = freq1 / g; freq2_reduced = freq2 / g; + freq_min_reduced = MIN(freq1_reduced, freq2_reduced); freq_max_reduced = MAX(freq1_reduced, freq2_reduced);
common_time_unit_ps = div_roundup(900000, lcm(freq1, freq2)); freq3 = div_roundup(num_cycles_2, common_time_unit_ps) - 1; freq4 = div_roundup(num_cycles_1, common_time_unit_ps) - 1; + if (add_freqs) { freq3 += freq2_reduced; freq4 += freq1_reduced; @@ -3276,47 +3096,51 @@ result->divisor_f3_to_f1 = 0; } else { if (freq2_reduced < freq1_reduced) { - result->freq3_to_2_remainder = - result->freq3_to_2_remaindera = - freq3 % freq1_reduced - freq1_reduced + 1; - result->freq4_to_max_remainder = - -(freq4 % freq1_reduced); + + result->freq3_to_2_remainder = result->freq3_to_2_remaindera = + freq3 % freq1_reduced - freq1_reduced + 1; + + result->freq4_to_max_remainder = -(freq4 % freq1_reduced); + result->divisor_f3_to_f1 = freq3 / freq1_reduced; + result->divisor_f4_to_f2 = - (freq4 - - (freq1_reduced - freq2_reduced)) / freq2_reduced; + (freq4 - (freq1_reduced - freq2_reduced)) / freq2_reduced; + result->freq4_to_2_remainder = - -(char)((freq1_reduced - freq2_reduced) + - ((u8) freq4 - - (freq1_reduced - - freq2_reduced)) % (u8) freq2_reduced); + -(char)((freq1_reduced - freq2_reduced) + ((u8) freq4 - + (freq1_reduced - freq2_reduced)) % (u8) freq2_reduced); + } else { if (freq2_reduced > freq1_reduced) { + result->freq4_to_max_remainder = - (freq4 % freq2_reduced) - freq2_reduced + 1; + (freq4 % freq2_reduced) - freq2_reduced + 1; + result->freq4_to_2_remainder = - freq4 % freq_max_reduced - - freq_max_reduced + 1; + freq4 % freq_max_reduced - freq_max_reduced + 1; + } else { - result->freq4_to_max_remainder = - -(freq4 % freq2_reduced); + result->freq4_to_max_remainder = -(freq4 % freq2_reduced); + result->freq4_to_2_remainder = - -(char)(freq4 % freq_max_reduced); + -(char)(freq4 % freq_max_reduced); } result->divisor_f4_to_f2 = freq4 / freq2_reduced; + result->divisor_f3_to_f1 = - (freq3 - - (freq2_reduced - freq1_reduced)) / freq1_reduced; + (freq3 - (freq2_reduced - freq1_reduced)) / freq1_reduced; + result->freq3_to_2_remainder = -(freq3 % freq2_reduced); + result->freq3_to_2_remaindera = - -(char)((freq_max_reduced - freq_min_reduced) + - (freq3 - - (freq_max_reduced - - freq_min_reduced)) % freq1_reduced); + -(char)((freq_max_reduced - freq_min_reduced) + (freq3 - + (freq_max_reduced - freq_min_reduced)) % freq1_reduced); } } result->divisor_f3_to_fmax = freq3 / freq_max_reduced; result->divisor_f4_to_fmax = freq4 / freq_max_reduced; + if (round_it) { if (freq2_reduced > freq1_reduced) { if (freq3 % freq_max_reduced) @@ -3327,48 +3151,41 @@ result->divisor_f4_to_fmax++; } } - result->freqs_reversed = (freq2_reduced < freq1_reduced); - result->freq_diff_reduced = freq_max_reduced - freq_min_reduced; - result->freq_min_reduced = freq_min_reduced; + + result->freqs_reversed = (freq2_reduced < freq1_reduced); + result->freq_diff_reduced = freq_max_reduced - freq_min_reduced; + result->freq_min_reduced = freq_min_reduced; result->common_time_unit_ps = common_time_unit_ps; - result->freq_max_reduced = freq_max_reduced; + result->freq_max_reduced = freq_max_reduced; }
-static void -set_2d5x_reg(struct raminfo *info, u16 reg, u16 freq1, u16 freq2, - int num_cycles_2, int num_cycles_1, int num_cycles_3, - int num_cycles_4, int reverse) +static void set_2d5x_reg(struct raminfo *info, u16 reg, u16 freq1, u16 freq2, int num_cycles_2, + int num_cycles_1, int num_cycles_3, int num_cycles_4, int reverse) { struct stru1 vv; char multiplier;
- compute_frequence_ratios(info, freq1, freq2, num_cycles_2, num_cycles_1, - 0, 1, &vv); + compute_frequence_ratios(info, freq1, freq2, num_cycles_2, num_cycles_1, 0, 1, &vv);
- multiplier = - div_roundup(MAX - (div_roundup(num_cycles_2, vv.common_time_unit_ps) + - div_roundup(num_cycles_3, vv.common_time_unit_ps), - div_roundup(num_cycles_1, - vv.common_time_unit_ps) + - div_roundup(num_cycles_4, vv.common_time_unit_ps)) - + vv.freq_min_reduced - 1, vv.freq_max_reduced) - 1; + multiplier = div_roundup( + MAX( + div_roundup(num_cycles_2, vv.common_time_unit_ps) + + div_roundup(num_cycles_3, vv.common_time_unit_ps), + div_roundup(num_cycles_1, vv.common_time_unit_ps) + + div_roundup(num_cycles_4, vv.common_time_unit_ps) + ) + vv.freq_min_reduced - 1, vv.freq_max_reduced) - 1;
- u32 y = - (u8) ((vv.freq_max_reduced - vv.freq_min_reduced) + - vv.freq_max_reduced * multiplier) - | (vv. - freqs_reversed << 8) | ((u8) (vv.freq_min_reduced * - multiplier) << 16) | ((u8) (vv. - freq_min_reduced - * - multiplier) - << 24); - u32 x = - vv.freq3_to_2_remaindera | (vv.freq4_to_2_remainder << 8) | (vv. - divisor_f3_to_f1 - << 16) - | (vv.divisor_f4_to_f2 << 20) | (vv.freq_min_reduced << 24); + u32 y = (u8) ((vv.freq_max_reduced - vv.freq_min_reduced) + + vv.freq_max_reduced * multiplier)| (vv.freqs_reversed << 8) | + ((u8) (vv.freq_min_reduced * multiplier) << 16) | + ((u8) (vv.freq_min_reduced * multiplier) << 24); + + u32 x = vv.freq3_to_2_remaindera | + (vv.freq4_to_2_remainder << 8) | + (vv.divisor_f3_to_f1 << 16) | + (vv.divisor_f4_to_f2 << 20) | + (vv.freq_min_reduced << 24); + if (reverse) { MCHBAR32(reg) = y; MCHBAR32(reg + 4) = x; @@ -3378,135 +3195,118 @@ } }
-static void -set_6d_reg(struct raminfo *info, u16 reg, u16 freq1, u16 freq2, - int num_cycles_1, int num_cycles_2, int num_cycles_3, - int num_cycles_4) +static void set_6d_reg(struct raminfo *info, u16 reg, u16 freq1, u16 freq2, int num_cycles_1, + int num_cycles_2, int num_cycles_3, int num_cycles_4) { - struct stru1 ratios1; - struct stru1 ratios2; + struct stru1 vv1; + struct stru1 vv2;
- compute_frequence_ratios(info, freq1, freq2, num_cycles_1, num_cycles_2, - 0, 1, &ratios2); - compute_frequence_ratios(info, freq1, freq2, num_cycles_3, num_cycles_4, - 0, 1, &ratios1); + compute_frequence_ratios(info, freq1, freq2, num_cycles_1, num_cycles_2, 0, 1, &vv2); + compute_frequence_ratios(info, freq1, freq2, num_cycles_3, num_cycles_4, 0, 1, &vv1); + printk(RAM_SPEW, "[%x] <= %x\n", reg, - ratios1.freq4_to_max_remainder | (ratios2. - freq4_to_max_remainder - << 8) - | (ratios1.divisor_f4_to_fmax << 16) | (ratios2. - divisor_f4_to_fmax - << 20)); - MCHBAR32(reg) = ratios1.freq4_to_max_remainder | - (ratios2.freq4_to_max_remainder << 8) | - (ratios1.divisor_f4_to_fmax << 16) | - (ratios2.divisor_f4_to_fmax << 20); + vv1.freq4_to_max_remainder | (vv2.freq4_to_max_remainder << 8) | + (vv1.divisor_f4_to_fmax << 16) | (vv2.divisor_f4_to_fmax << 20)); + + MCHBAR32(reg) = vv1.freq4_to_max_remainder | (vv2.freq4_to_max_remainder << 8) | + (vv1.divisor_f4_to_fmax << 16) | (vv2.divisor_f4_to_fmax << 20); }
-static void -set_2dx8_reg(struct raminfo *info, u16 reg, u8 mode, u16 freq1, u16 freq2, - int num_cycles_2, int num_cycles_1, int round_it, int add_freqs) +static void set_2dx8_reg(struct raminfo *info, u16 reg, u8 mode, u16 freq1, u16 freq2, + int num_cycles_2, int num_cycles_1, int round_it, int add_freqs) { - struct stru1 ratios; + struct stru1 vv;
- compute_frequence_ratios(info, freq1, freq2, num_cycles_2, num_cycles_1, - round_it, add_freqs, &ratios); + compute_frequence_ratios(info, freq1, freq2, num_cycles_2, num_cycles_1, round_it, + add_freqs, &vv); + switch (mode) { case 0: - MCHBAR32(reg + 4) = ratios.freq_diff_reduced | - (ratios.freqs_reversed << 8); - MCHBAR32(reg) = ratios.freq3_to_2_remainder | - (ratios.freq4_to_max_remainder << 8) | - (ratios.divisor_f3_to_fmax << 16) | - (ratios.divisor_f4_to_fmax << 20) | - (ratios.freq_min_reduced << 24); + MCHBAR32(reg + 4) = vv.freq_diff_reduced | (vv.freqs_reversed << 8); + + MCHBAR32(reg) = vv.freq3_to_2_remainder | (vv.freq4_to_max_remainder << 8) | + (vv.divisor_f3_to_fmax << 16) | (vv.divisor_f4_to_fmax << 20) | + (vv.freq_min_reduced << 24); break;
case 1: - MCHBAR32(reg) = ratios.freq3_to_2_remainder | - (ratios.divisor_f3_to_fmax << 16); + MCHBAR32(reg) = vv.freq3_to_2_remainder | (vv.divisor_f3_to_fmax << 16); break;
case 2: - MCHBAR32(reg) = ratios.freq3_to_2_remainder | - (ratios.freq4_to_max_remainder << 8) | - (ratios.divisor_f3_to_fmax << 16) | - (ratios.divisor_f4_to_fmax << 20); + MCHBAR32(reg) = vv.freq3_to_2_remainder | (vv.freq4_to_max_remainder << 8) | + (vv.divisor_f3_to_fmax << 16) | (vv.divisor_f4_to_fmax << 20); break;
case 4: - MCHBAR32(reg) = (ratios.divisor_f3_to_fmax << 4) | - (ratios.divisor_f4_to_fmax << 8) | - (ratios.freqs_reversed << 12) | - (ratios.freq_min_reduced << 16) | - (ratios.freq_diff_reduced << 24); + MCHBAR32(reg) = (vv.divisor_f3_to_fmax << 4) | (vv.divisor_f4_to_fmax << 8) | + (vv.freqs_reversed << 12) | (vv.freq_min_reduced << 16) | + (vv.freq_diff_reduced << 24); break; } }
static void set_2dxx_series(struct raminfo *info, int s3resume) { - set_2dx8_reg(info, 0x2d00, 0, 0x78, frequency_11(info) / 2, 1359, 1005, - 0, 1); + set_2dx8_reg(info, 0x2d00, 0, 0x78, frequency_11(info) / 2, 1359, 1005, 0, 1); + set_2dx8_reg(info, 0x2d08, 0, 0x78, 0x78, 3273, 5033, 1, 1); - set_2dx8_reg(info, 0x2d10, 0, 0x78, info->fsb_frequency, 1475, 1131, 0, + + set_2dx8_reg(info, 0x2d10, 0, 0x78, info->fsb_frequency, 1475, 1131, 0, 1); + + set_2dx8_reg(info, 0x2d18, 0, 2 * info->fsb_frequency, frequency_11(info), 1231, 1524, + 0, 1); + set_2dx8_reg(info, 0x2d20, 0, 2 * info->fsb_frequency, frequency_11(info) / 2, 1278, + 2008, 0, 1); + set_2dx8_reg(info, 0x2d28, 0, info->fsb_frequency, frequency_11(info), 1167, 1539, 0, 1); - set_2dx8_reg(info, 0x2d18, 0, 2 * info->fsb_frequency, - frequency_11(info), 1231, 1524, 0, 1); - set_2dx8_reg(info, 0x2d20, 0, 2 * info->fsb_frequency, - frequency_11(info) / 2, 1278, 2008, 0, 1); - set_2dx8_reg(info, 0x2d28, 0, info->fsb_frequency, frequency_11(info), - 1167, 1539, 0, 1); - set_2dx8_reg(info, 0x2d30, 0, info->fsb_frequency, - frequency_11(info) / 2, 1403, 1318, 0, 1); - set_2dx8_reg(info, 0x2d38, 0, info->fsb_frequency, 0x78, 3460, 5363, 1, - 1); - set_2dx8_reg(info, 0x2d40, 0, info->fsb_frequency, 0x3c, 2792, 5178, 1, - 1); - set_2dx8_reg(info, 0x2d48, 0, 2 * info->fsb_frequency, 0x78, 2738, 4610, - 1, 1); - set_2dx8_reg(info, 0x2d50, 0, info->fsb_frequency, 0x78, 2819, 5932, 1, - 1); - set_2dx8_reg(info, 0x6d4, 1, info->fsb_frequency, - frequency_11(info) / 2, 4000, 0, 0, 0); - set_2dx8_reg(info, 0x6d8, 2, info->fsb_frequency, - frequency_11(info) / 2, 4000, 4000, 0, 0); + set_2dx8_reg(info, 0x2d30, 0, info->fsb_frequency, frequency_11(info) / 2, 1403, 1318, + 0, 1); + set_2dx8_reg(info, 0x2d38, 0, info->fsb_frequency, 0x78, 3460, 5363, 1, 1); + + set_2dx8_reg(info, 0x2d40, 0, info->fsb_frequency, 0x3c, 2792, 5178, 1, 1); + + set_2dx8_reg(info, 0x2d48, 0, 2 * info->fsb_frequency, 0x78, 2738, 4610, 1, 1); + + set_2dx8_reg(info, 0x2d50, 0, info->fsb_frequency, 0x78, 2819, 5932, 1, 1); + + set_2dx8_reg(info, 0x6d4, 1, info->fsb_frequency, frequency_11(info) / 2, 4000, 0, 0, + 0); + set_2dx8_reg(info, 0x6d8, 2, info->fsb_frequency, frequency_11(info) / 2, 4000, 4000, + 0, 0);
if (s3resume) { - printk(RAM_SPEW, "[6dc] <= %x\n", - info->cached_training->reg_6dc); + printk(RAM_SPEW, "[6dc] <= %x\n", info->cached_training->reg_6dc); MCHBAR32(0x6dc) = info->cached_training->reg_6dc; - } else + } else { set_6d_reg(info, 0x6dc, 2 * info->fsb_frequency, frequency_11(info), 0, - info->delay46_ps[0], 0, - info->delay54_ps[0]); - set_2dx8_reg(info, 0x6e0, 1, 2 * info->fsb_frequency, - frequency_11(info), 2500, 0, 0, 0); - set_2dx8_reg(info, 0x6e4, 1, 2 * info->fsb_frequency, - frequency_11(info) / 2, 3500, 0, 0, 0); + info->delay46_ps[0], 0, info->delay54_ps[0]); + } + + set_2dx8_reg(info, 0x6e0, 1, 2 * info->fsb_frequency, frequency_11(info), 2500, 0, 0, + 0); + set_2dx8_reg(info, 0x6e4, 1, 2 * info->fsb_frequency, frequency_11(info) / 2, 3500, 0, + 0, 0); + if (s3resume) { - printk(RAM_SPEW, "[6e8] <= %x\n", - info->cached_training->reg_6e8); + printk(RAM_SPEW, "[6e8] <= %x\n", info->cached_training->reg_6e8); MCHBAR32(0x6e8) = info->cached_training->reg_6e8; - } else + } else { set_6d_reg(info, 0x6e8, 2 * info->fsb_frequency, frequency_11(info), 0, - info->delay46_ps[1], 0, - info->delay54_ps[1]); + info->delay46_ps[1], 0, info->delay54_ps[1]); + } + set_2d5x_reg(info, 0x2d58, 0x78, 0x78, 864, 1195, 762, 786, 0); - set_2d5x_reg(info, 0x2d60, 0x195, info->fsb_frequency, 1352, 725, 455, - 470, 0); + set_2d5x_reg(info, 0x2d60, 0x195, info->fsb_frequency, 1352, 725, 455, 470, 0); set_2d5x_reg(info, 0x2d68, 0x195, 0x3c, 2707, 5632, 3277, 2207, 0); - set_2d5x_reg(info, 0x2d70, 0x195, frequency_11(info) / 2, 1276, 758, - 454, 459, 0); + set_2d5x_reg(info, 0x2d70, 0x195, frequency_11(info) / 2, 1276, 758, 454, 459, 0); set_2d5x_reg(info, 0x2d78, 0x195, 0x78, 1021, 799, 510, 513, 0); - set_2d5x_reg(info, 0x2d80, info->fsb_frequency, 0xe1, 0, 2862, 2579, - 2588, 0); - set_2d5x_reg(info, 0x2d88, info->fsb_frequency, 0xe1, 0, 2690, 2405, - 2405, 0); + set_2d5x_reg(info, 0x2d80, info->fsb_frequency, 0xe1, 0, 2862, 2579, 2588, 0); + set_2d5x_reg(info, 0x2d88, info->fsb_frequency, 0xe1, 0, 2690, 2405, 2405, 0); set_2d5x_reg(info, 0x2da0, 0x78, 0xe1, 0, 2560, 2264, 2251, 0); - set_2d5x_reg(info, 0x2da8, 0x195, frequency_11(info), 1060, 775, 484, - 480, 0); + set_2d5x_reg(info, 0x2da8, 0x195, frequency_11(info), 1060, 775, 484, 480, 0); set_2d5x_reg(info, 0x2db0, 0x195, 0x78, 4183, 6023, 2217, 2048, 0); + MCHBAR32(0x2dbc) = ((frequency_11(info) / 2) - 1) | 0xe00000; MCHBAR32(0x2db8) = ((info->fsb_frequency - 1) << 16) | 0x77; } @@ -3522,14 +3322,16 @@ if (info->revision < 8) return 256;
- for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - if (info->populated_ranks[channel][slot][rank]) - for (lane = 0; lane < 8 + info->use_ecc; lane++) - ret = MAX(ret, read_500(info, channel, - get_timing_register_addr - (lane, 0, slot, - rank), 9)); + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + if (info->populated_ranks[channel][slot][rank]) { + for (lane = 0; lane < 8 + info->use_ecc; lane++) { + + ret = MAX(ret, read_500(info, channel, + get_timing_register_addr(lane, 0, slot, rank), 9)); + + }}}} /* for each slot, rank, if populated, for each lane */ + return ret; }
@@ -3543,49 +3345,58 @@
delay_a_ps = 4 * halfcycle_ps(info) + 6 * fsbcycle_ps(info); info->training.reg2ca9_bit0 = 0; + for (channel = 0; channel < NUM_CHANNELS; channel++) { - cycletime_ps = - 900000 / lcm(2 * info->fsb_frequency, frequency_11(info)); - delay_d_ps = - (halfcycle_ps(info) * get_max_timing(info, channel) >> 6) - - info->some_delay_3_ps_rounded + 200; - if (! - ((info->silicon_revision == 0 - || info->silicon_revision == 1) - && (info->revision >= 8))) + + cycletime_ps = 900000 / lcm(2 * info->fsb_frequency, frequency_11(info)); + + delay_d_ps = (halfcycle_ps(info) * get_max_timing(info, channel) >> 6) - + info->some_delay_3_ps_rounded + 200; + + if (!((info->silicon_revision == 0 || info->silicon_revision == 1) + && (info->revision >= 8))) { delay_d_ps += halfcycle_ps(info) * 2; - delay_d_ps += - halfcycle_ps(info) * (!info->revision_flag_1 + - info->some_delay_2_halfcycles_ceil + - 2 * info->some_delay_1_cycle_floor + - info->clock_speed_index + - 2 * info->cas_latency - 7 + 11); + } + + delay_d_ps += halfcycle_ps(info) * (!info->revision_flag_1 + + info->some_delay_2_halfcycles_ceil + 2 * + info->some_delay_1_cycle_floor + info->clock_speed_index + 2 * + info->cas_latency - 7 + 11); + delay_d_ps += info->revision >= 8 ? 2758 : 4428;
MCHBAR32_AND_OR(0x140, 0xfaffffff, 0x2000000); + MCHBAR32_AND_OR(0x138, 0xfaffffff, 0x2000000); + if ((MCHBAR8(0x144) & 0x1f) > 0x13) delay_d_ps += 650; + delay_c_ps = delay_d_ps + 1800; - if (delay_c_ps <= delay_a_ps) + + if (delay_c_ps <= delay_a_ps) { delay_e_ps = 0; - else - delay_e_ps = - cycletime_ps * div_roundup(delay_c_ps - delay_a_ps, - cycletime_ps); + } else { + delay_e_ps = cycletime_ps * + div_roundup(delay_c_ps - delay_a_ps, cycletime_ps); + }
delay_e_over_cycle_ps = delay_e_ps % (2 * halfcycle_ps(info)); + delay_e_cycles = delay_e_ps / (2 * halfcycle_ps(info)); - delay_f_cycles = - div_roundup(2500 - delay_e_over_cycle_ps, - 2 * halfcycle_ps(info)); + + delay_f_cycles = div_roundup(2500 - delay_e_over_cycle_ps, + 2 * halfcycle_ps(info)); + if (delay_f_cycles > delay_e_cycles) { + info->delay46_ps[channel] = delay_e_ps; delay_e_cycles = 0; + } else { info->delay46_ps[channel] = - delay_e_over_cycle_ps + - 2 * halfcycle_ps(info) * delay_f_cycles; + delay_e_over_cycle_ps + 2 * halfcycle_ps(info) * delay_f_cycles; + delay_e_cycles -= delay_f_cycles; }
@@ -3593,34 +3404,43 @@ info->delay46_ps[channel] = 2500; info->training.reg2ca9_bit0 = 1; } + delay_b_ps = halfcycle_ps(info) + delay_c_ps; - if (delay_b_ps <= delay_a_ps) + + if (delay_b_ps <= delay_a_ps) { delay_b_ps = 0; - else + } else { delay_b_ps -= delay_a_ps; + } + info->delay54_ps[channel] = - cycletime_ps * div_roundup(delay_b_ps, - cycletime_ps) - - 2 * halfcycle_ps(info) * delay_e_cycles; + cycletime_ps * div_roundup(delay_b_ps, cycletime_ps) - 2 * + halfcycle_ps(info) * delay_e_cycles; + if (info->delay54_ps[channel] < 2500) info->delay54_ps[channel] = 2500; + info->training.reg274265[channel][0] = delay_e_cycles; - if (delay_d_ps + 7 * halfcycle_ps(info) <= - 24 * halfcycle_ps(info)) + + if (delay_d_ps + 7 * halfcycle_ps(info) <= 24 * halfcycle_ps(info)) { + info->training.reg274265[channel][1] = 0; - else - info->training.reg274265[channel][1] = - div_roundup(delay_d_ps + 7 * halfcycle_ps(info), - 4 * halfcycle_ps(info)) - 6; + + } else { + info->training.reg274265[channel][1] = div_roundup(delay_d_ps + 7 * + halfcycle_ps(info), 4 * halfcycle_ps(info)) - 6; + } + MCHBAR32((channel << 10) + 0x274) = - info->training.reg274265[channel][1] | + info->training.reg274265[channel][1] | (info->training.reg274265[channel][0] << 16); - info->training.reg274265[channel][2] = - div_roundup(delay_c_ps + 3 * fsbcycle_ps(info), - 4 * halfcycle_ps(info)) + 1; - MCHBAR16((channel << 10) + 0x265) = - info->training.reg274265[channel][2] << 8; + + info->training.reg274265[channel][2] = div_roundup(delay_c_ps + 3 * + fsbcycle_ps(info), 4 * halfcycle_ps(info)) + 1; + + MCHBAR16((channel << 10) + 0x265) = info->training.reg274265[channel][2] << 8; } + if (info->training.reg2ca9_bit0) MCHBAR8_OR(0x2ca9, 1); else @@ -3634,10 +3454,12 @@ for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32((channel << 10) + 0x274) = (info->cached_training->reg274265[channel][0] << 16) | - info->cached_training->reg274265[channel][1]; + info->cached_training->reg274265[channel][1]; + MCHBAR16((channel << 10) + 0x265) = info->cached_training->reg274265[channel][2] << 8; } + if (info->cached_training->reg2ca9_bit0) MCHBAR8_OR(0x2ca9, 1); else @@ -3647,24 +3469,27 @@ static void dmi_setup(void) { gav(read8(DEFAULT_DMIBAR + 0x254)); + write8(DEFAULT_DMIBAR + 0x254, 0x1); write16(DEFAULT_DMIBAR + 0x1b8, 0x18f2); + MCHBAR16_AND_OR(0x48, 0, 0x2);
write32(DEFAULT_DMIBAR + 0xd68, read32(DEFAULT_DMIBAR + 0xd68) | 0x08000000);
outl((gav(inl(DEFAULT_GPIOBASE | 0x38)) & ~0x140000) | 0x400000, - DEFAULT_GPIOBASE | 0x38); + DEFAULT_GPIOBASE | 0x38); + gav(inb(DEFAULT_GPIOBASE | 0xe)); // = 0xfdcaff6e }
void chipset_init(const int s3resume) { - u8 x2ca8; + u8 x2ca8, gfxsize; u16 ggc; - u8 gfxsize;
x2ca8 = MCHBAR8(0x2ca8); + if ((x2ca8 & 1) || (x2ca8 == 8 && !s3resume)) { printk(BIOS_DEBUG, "soft reset detected, rebooting properly\n"); MCHBAR8(0x2ca8) = 0; @@ -3680,7 +3505,7 @@ dmi_setup();
MCHBAR16(0x1170) = 0xa880; - MCHBAR8(0x11c1) = 0x1; + MCHBAR8(0x11c1) = 0x1; MCHBAR16(0x1170) = 0xb880; MCHBAR8_AND_OR(0x1210, 0, 0x84);
@@ -3693,26 +3518,30 @@
pci_write_config16(NORTHBRIDGE, D0F0_GGC, ggc | 2);
- u16 deven; - deven = pci_read_config16(NORTHBRIDGE, D0F0_DEVEN); // = 0x3 + u16 deven = pci_read_config16(NORTHBRIDGE, D0F0_DEVEN); // = 0x3
if (deven & 8) { MCHBAR8(0x2c30) = 0x20; + pci_read_config8(NORTHBRIDGE, 0x8); // = 0x18 + MCHBAR16_OR(0x2c30, 0x200); MCHBAR16(0x2c32) = 0x434; MCHBAR32_AND_OR(0x2c44, 0, 0x1053687); + pci_read_config8(GMA, 0x62); // = 0x2 pci_write_config8(GMA, 0x62, 0x2); - read8(DEFAULT_RCBA + 0x2318); + + read8(DEFAULT_RCBA + 0x2318); write8(DEFAULT_RCBA + 0x2318, 0x47); - read8(DEFAULT_RCBA + 0x2320); + read8(DEFAULT_RCBA + 0x2320); write8(DEFAULT_RCBA + 0x2320, 0xfc); }
MCHBAR32_AND_OR(0x30, 0, 0x40);
pci_write_config16(NORTHBRIDGE, D0F0_GGC, ggc); + gav(read32(DEFAULT_RCBA + 0x3428)); write32(DEFAULT_RCBA + 0x3428, 0x1d); } @@ -3767,38 +3596,28 @@ info.use_ecc = 1; for (channel = 0; channel < NUM_CHANNELS; channel++) for (slot = 0; slot < NUM_SLOTS; slot++) { - int v; - int try; - int addr; - const u8 useful_addresses[] = { - DEVICE_TYPE, - MODULE_TYPE, - DENSITY, - RANKS_AND_DQ, - MEMORY_BUS_WIDTH, - TIMEBASE_DIVIDEND, - TIMEBASE_DIVISOR, - CYCLETIME, - CAS_LATENCIES_LSB, - CAS_LATENCIES_MSB, + + int v, try, addr; + + const u8 spd_bytes[] = { + DEVICE_TYPE, MODULE_TYPE, DENSITY, RANKS_AND_DQ, + MEMORY_BUS_WIDTH, TIMEBASE_DIVIDEND, TIMEBASE_DIVISOR, + CYCLETIME, CAS_LATENCIES_LSB, CAS_LATENCIES_MSB, CAS_LATENCY_TIME, - 0x11, 0x12, 0x13, 0x14, 0x15, - 0x16, 0x17, 0x18, 0x19, 0x1a, 0x1b, - 0x1c, 0x1d, + 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, + 0x1a, 0x1b, 0x1c, 0x1d, THERMAL_AND_REFRESH, 0x20, - REFERENCE_RAW_CARD_USED, - RANK1_ADDRESS_MAPPING, - 0x75, 0x76, 0x77, 0x78, - 0x79, 0x7a, 0x7b, 0x7c, 0x7d, 0x7e, - 0x7f, 0x80, 0x81, 0x82, 0x83, 0x84, - 0x85, 0x86, 0x87, 0x88, - 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, - 0x8f, 0x90, 0x91, 0x92, 0x93, 0x94, - 0x95 + REFERENCE_RAW_CARD_USED, RANK1_ADDRESS_MAPPING, + 0x75, 0x76, 0x77, 0x78, 0x79, 0x7a, 0x7b, 0x7c, 0x7d, + 0x7e, 0x7f, 0x80, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, + 0x87, 0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, 0x8f, + 0x90, 0x91, 0x92, 0x93, 0x94, 0x95 }; + if (!spd_addrmap[2 * channel + slot]) continue; + for (try = 0; try < 5; try++) { v = smbus_read_byte(spd_addrmap[2 * channel + slot], DEVICE_TYPE); @@ -3807,40 +3626,38 @@ } if (v < 0) continue; - for (addr = 0; - addr < - sizeof(useful_addresses) / - sizeof(useful_addresses[0]); addr++) - gav(info. - spd[channel][0][useful_addresses - [addr]] = - smbus_read_byte(spd_addrmap[2 * channel + slot], - useful_addresses - [addr])); + + for (addr = 0; addr < ARRAY_SIZE(spd_bytes); addr++) { + gav(info.spd[channel][0][spd_bytes[addr]] = + smbus_read_byte(spd_addrmap[2 * channel + slot], + spd_bytes[addr])); + } + if (info.spd[channel][0][DEVICE_TYPE] != 11) die("Only DDR3 is supported");
v = info.spd[channel][0][RANKS_AND_DQ]; + info.populated_ranks[channel][0][0] = 1; - info.populated_ranks[channel][0][1] = - ((v >> 3) & 7); + info.populated_ranks[channel][0][1] = ((v >> 3) & 7); + if (((v >> 3) & 7) > 1) die("At most 2 ranks are supported"); + if ((v & 7) == 0 || (v & 7) > 2) die("Only x8 and x16 modules are supported"); - if ((info. - spd[channel][slot][MODULE_TYPE] & 0xF) != 2 - && (info. - spd[channel][slot][MODULE_TYPE] & 0xF) - != 3) + + if ((info.spd[channel][slot][MODULE_TYPE] & 0xf) != 2 + && (info.spd[channel][slot][MODULE_TYPE] & 0xf) != 3) { + die("Registered memory is not supported"); + } + info.is_x16_module[channel][0] = (v & 7) - 1; info.density[channel][slot] = - info.spd[channel][slot][DENSITY] & 0xF; - if (! - (info. - spd[channel][slot][MEMORY_BUS_WIDTH] & - 0x18)) + info.spd[channel][slot][DENSITY] & 0xF; + + if (!(info.spd[channel][slot][MEMORY_BUS_WIDTH] & 0x18)) info.use_ecc = 0; }
@@ -3848,11 +3665,12 @@
for (channel = 0; channel < NUM_CHANNELS; channel++) { int v = 0; - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - v |= info. - populated_ranks[channel][slot][rank] - << (2 * slot + rank); + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + v |= info.populated_ranks[channel][slot][rank] << + (2 * slot + rank); + } + } info.populated_ranks_mask[channel] = v; }
@@ -3861,7 +3679,7 @@ gav(pci_read_config32(NORTHBRIDGE, D0F0_CAPID0 + 4)); }
- /* after SPD */ + /* After SPD */ timestamp_add_now(102);
MCHBAR8_AND(0x2ca8, 0xfc); @@ -3876,25 +3694,18 @@ if (!s3resume) { u8 reg8 = pci_read_config8(SOUTHBRIDGE, GEN_PMCON_2); if (x2ca8 == 0 && (reg8 & 0x80)) { - /* Don't enable S4-assertion stretch. Makes trouble on roda/rk9. - reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa4); - pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa4, reg8 | 0x08); - */
/* Clear bit7. */ + pci_write_config8(SOUTHBRIDGE, GEN_PMCON_2, (reg8 & ~(1 << 7)));
- pci_write_config8(SOUTHBRIDGE, GEN_PMCON_2, - (reg8 & ~(1 << 7))); - - printk(BIOS_INFO, - "Interrupted RAM init, reset required.\n"); + printk(BIOS_INFO, "Interrupted RAM init, reset required.\n"); system_reset(); } }
if (!s3resume && x2ca8 == 0) - pci_write_config8(SOUTHBRIDGE, GEN_PMCON_2, - pci_read_config8(SOUTHBRIDGE, GEN_PMCON_2) | 0x80); + pci_write_config8(SOUTHBRIDGE, GEN_PMCON_2, pci_read_config8 + (SOUTHBRIDGE, GEN_PMCON_2) | 0x80);
compute_derived_timings(&info);
@@ -4007,21 +3818,24 @@ if (x2ca8 == 0) { int j; if (s3resume && info.cached_training) { + restore_274265(&info); printk(RAM_SPEW, "reg2ca9_bit0 = %x\n", info.cached_training->reg2ca9_bit0); + for (i = 0; i < 2; i++) for (j = 0; j < 3; j++) - printk(RAM_SPEW, "reg274265[%d][%d] = %x\n", - i, j, info.cached_training->reg274265[i][j]); + printk(RAM_SPEW, "reg274265[%d][%d] = %x\n", i, j, + info.cached_training->reg274265[i][j]); } else { set_274265(&info); printk(RAM_SPEW, "reg2ca9_bit0 = %x\n", info.training.reg2ca9_bit0); + for (i = 0; i < 2; i++) for (j = 0; j < 3; j++) - printk(RAM_SPEW, "reg274265[%d][%d] = %x\n", - i, j, info.training.reg274265[i][j]); + printk(RAM_SPEW, "reg274265[%d][%d] = %x\n", i, j, + info.training.reg274265[i][j]); }
set_2dxx_series(&info, s3resume); @@ -4238,13 +4052,15 @@ if (x2ca8 == 0) { MCHBAR8_AND(0x2ca8, ~3); MCHBAR8(0x2ca8) = MCHBAR8(0x2ca8) + 4; // "+" or "|"? + /* This issues a CPU reset without resetting the platform */ printk(BIOS_DEBUG, "Issuing a CPU reset\n"); - /* Write back the S3 state to PM1_CNT to let the reset CPU - know it also needs to take the s3 path. */ + + /* Write back the S3 state to PM1_CNT to let the reset CPU know it also needs + * to take the S3 path. */ if (s3resume) - write_pmbase32(PM1_CNT, read_pmbase32(PM1_CNT) - | (SLP_TYP_S3 << 10)); + write_pmbase32(PM1_CNT, read_pmbase32(PM1_CNT) | (SLP_TYP_S3 << 10)); + MCHBAR32_OR(0x1af0, 0x10); halt(); } @@ -4256,22 +4072,28 @@ MCHBAR16(0x2c10); // !!!! MCHBAR16(0x2c00); // !!!! MCHBAR16(0x2c00) = 0x8c0; + udelay(1000); + write_1d0(0, 0x33d, 0, 0); write_500(&info, 0, 0, 0xb61, 0, 0); write_500(&info, 1, 0, 0xb61, 0, 0); MCHBAR32(0x1a30) = 0x0; MCHBAR32(0x1a34) = 0x0; - MCHBAR16(0x614) = 0xb5b | (info.populated_ranks[1][0][0] * 0x404) | - (info.populated_ranks[0][0][0] * 0xa0); + + MCHBAR16(0x614) = 0xb5b | (info.populated_ranks[1][0][0] * 0x404) + | (info.populated_ranks[0][0][0] * 0xa0); + MCHBAR16(0x616) = 0x26a; MCHBAR32(0x134) = 0x856000; MCHBAR32(0x160) = 0x5ffffff; MCHBAR32_AND_OR(0x114, 0, 0xc2024440); // !!!! MCHBAR32_AND_OR(0x118, 0, 0x4); // !!!! + for (channel = 0; channel < NUM_CHANNELS; channel++) - MCHBAR32(0x260 + (channel << 10)) = 0x30809ff | - ((info.populated_ranks_mask[channel] & 3) << 20); + MCHBAR32(0x260 + (channel << 10)) = + 0x30809ff | ((info.populated_ranks_mask[channel] & 3) << 20); + for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR16(0x31c + (channel << 10)) = 0x101; MCHBAR16(0x360 + (channel << 10)) = 0x909; @@ -4296,10 +4118,9 @@
rmw_1d0(0x21c, 0x38, 0, 6, 1);
- write_1d0(((!info.populated_ranks[1][0][0]) << 1) | ((!info. - populated_ranks[0] - [0][0]) << 0), - 0x1d1, 3, 1); + write_1d0(((!info.populated_ranks[1][0][0]) << 1) | + ((!info.populated_ranks[0][0][0]) << 0), 0x1d1, 3, 1); + for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR16(0x38e + (channel << 10)) = 0x5f5f; MCHBAR16(0x3d2 + (channel << 10)) = 0x5f5f; @@ -4311,16 +4132,16 @@
MCHBAR8_OR(0x5ff, 0x80);
- write_1d0(0x2, 0x1d5, 2, 1); + write_1d0(0x02, 0x1d5, 2, 1); write_1d0(0x20, 0x166, 7, 1); - write_1d0(0x0, 0xeb, 3, 1); - write_1d0(0x0, 0xf3, 6, 1); + write_1d0(0x00, 0x0eb, 3, 1); + write_1d0(0x00, 0x0f3, 6, 1);
for (channel = 0; channel < NUM_CHANNELS; channel++) for (lane = 0; lane < 9; lane++) { + u16 addr = 0x125 + get_lane_offset(0, 0, lane); - u8 a; - a = read_500(&info, channel, addr, 6); // = 0x20040080 //!!!! + u8 a = read_500(&info, channel, addr, 6); // = 0x20040080 //!!!! write_500(&info, channel, a, addr, 6, 1); }
@@ -4328,31 +4149,28 @@
if (s3resume) { if (info.cached_training == NULL) { + u32 reg32; - printk(BIOS_ERR, - "Couldn't find training data. Rebooting\n"); + printk(BIOS_ERR, "Couldn't find training data. Rebooting\n"); reg32 = inl(DEFAULT_PMBASE + 0x04); outl(reg32 & ~(7 << 10), DEFAULT_PMBASE + 0x04); full_reset(); } int tm; info.training = *info.cached_training; - for (tm = 0; tm < 4; tm++) - for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - for (lane = 0; lane < 9; lane++) - write_500(&info, - channel, - info.training. - lane_timings - [tm][channel] - [slot][rank] - [lane], - get_timing_register_addr - (lane, tm, - slot, rank), - 9, 0); + + for (tm = 0; tm < 4; tm++) { + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + for (lane = 0; lane < 9; lane++) { + + write_500(&info, channel, + info.training.lane_timings[tm][channel][slot][rank][lane], + get_timing_register_addr(lane, tm, slot, rank), 9, 0); + + }}}}} /* for each tm, channel, slot, rank, lane */ + write_1d0(info.cached_training->reg_178, 0x178, 7, 1); write_1d0(info.cached_training->reg_10b, 0x10b, 6, 1); } @@ -4371,6 +4189,7 @@ MCHBAR32_AND(0x130, 0xfffffffd); // | 2 when ? while (MCHBAR32(0x130) & 1) ; + gav(read_1d0(0x14b, 7)); // = 0x81023100 write_1d0(0x30, 0x14b, 7, 1); read_1d0(0xd6, 6); // = 0xfa008080 // !!!! @@ -4379,8 +4198,7 @@ write_1d0(7, 0x328, 6, 1);
for (channel = 0; channel < NUM_CHANNELS; channel++) - set_4cf(&info, channel, - info.populated_ranks[channel][0][0] ? 8 : 0); + set_4cf(&info, channel, info.populated_ranks[channel][0][0] ? 8 : 0);
read_1d0(0x116, 4); // = 0x4040432 // !!!! write_1d0(2, 0x116, 4, 1); @@ -4393,49 +4211,46 @@ MCHBAR32_AND(0x140, ~0x07000000); MCHBAR32_AND(0x138, ~0x07000000); MCHBAR32(0x130) = 0x31111301; + /* Wait until REG130b0 is 1. */ while (MCHBAR32(0x130) & 1) ;
- { - u32 t; - u8 val_a1; - val_a1 = read_1d0(0xa1, 6); // = 0x1cf4040 // !!!! - t = read_1d0(0x2f3, 6); // = 0x10a4040 // !!!! - rmw_1d0(0x320, 0x07, - (t & 4) | ((t & 8) >> 2) | ((t & 0x10) >> 4), 6, 1); - rmw_1d0(0x14b, 0x78, - ((((val_a1 >> 2) & 4) | (val_a1 & 8)) >> 2) | (val_a1 & - 4), 7, - 1); - rmw_1d0(0xce, 0x38, - ((((val_a1 >> 2) & 4) | (val_a1 & 8)) >> 2) | (val_a1 & - 4), 6, - 1); - } + + u32 t; + u8 val_a1 = read_1d0(0xa1, 6); // = 0x1cf4040 // !!!! + t = read_1d0(0x2f3, 6); // = 0x10a4040 // !!!! + + rmw_1d0(0x320, 0x07, (t & 4) | ((t & 8) >> 2) | ((t & 0x10) >> 4), 6, 1); + rmw_1d0(0x14b, 0x78, ((((val_a1 >> 2) & 4) | (val_a1 & 8)) >> 2) | (val_a1 & 4), 7, 1); + rmw_1d0(0x0ce, 0x38, ((((val_a1 >> 2) & 4) | (val_a1 & 8)) >> 2) | (val_a1 & 4), 6, 1); +
for (channel = 0; channel < NUM_CHANNELS; channel++) - set_4cf(&info, channel, - info.populated_ranks[channel][0][0] ? 9 : 1); + set_4cf(&info, channel, info.populated_ranks[channel][0][0] ? 9 : 1);
rmw_1d0(0x116, 0xe, 1, 4, 1); // = 0x4040432 // !!!! MCHBAR32(0x144); // !!!! + write_1d0(2, 0xae, 6, 1); write_1d0(2, 0x300, 6, 1); write_1d0(2, 0x121, 3, 1); + read_1d0(0xd6, 6); // = 0xfa00c0c7 // !!!! write_1d0(4, 0xd6, 6, 1); read_1d0(0x328, 6); // = 0xfa00c0c7 // !!!! write_1d0(4, 0x328, 6, 1);
for (channel = 0; channel < NUM_CHANNELS; channel++) - set_4cf(&info, channel, - info.populated_ranks[channel][0][0] ? 9 : 0); + set_4cf(&info, channel, info.populated_ranks[channel][0][0] ? 9 : 0);
- MCHBAR32(0x130) = 0x11111301 | (info.populated_ranks[1][0][0] << 30) | - (info.populated_ranks[0][0][0] << 29); + MCHBAR32(0x130) = 0x11111301 + | (info.populated_ranks[1][0][0] << 30) + | (info.populated_ranks[0][0][0] << 29); + while (MCHBAR8(0x130) & 1) ; + read_1d0(0xa1, 6); // = 0x1cf4054 // !!!! read_1d0(0x2f3, 6); // = 0x10a4054 // !!!! read_1d0(0x21c, 6); // = 0xafa00c0 // !!!! @@ -4444,23 +4259,24 @@ write_1d0(0x35, 0x14b, 7, 1);
for (channel = 0; channel < NUM_CHANNELS; channel++) - set_4cf(&info, channel, - info.populated_ranks[channel][0][0] ? 0xb : 0x2); + set_4cf(&info, channel, info.populated_ranks[channel][0][0] ? 0xb : 0x2);
set_334(1);
MCHBAR8(0x1e8) = 0x4;
for (channel = 0; channel < NUM_CHANNELS; channel++) { - write_500(&info, channel, - 0x3 & ~(info.populated_ranks_mask[channel]), 0x6b7, 2, - 1); + + write_500(&info, channel, 0x3 & ~(info.populated_ranks_mask[channel]), 0x6b7, + 2, 1); write_500(&info, channel, 0x3, 0x69b, 2, 1); } + MCHBAR32_AND_OR(0x2d0, 0xff2c01ff, 0x200000); MCHBAR16(0x6c0) = 0x14a0; MCHBAR32_AND_OR(0x6d0, 0xff0080ff, 0x8000); MCHBAR16(0x232) = 0x8; + /* 0x40004 or 0 depending on ? */ MCHBAR32_AND_OR(0x234, 0xfffbfffb, 0x40004); MCHBAR32_AND_OR(0x34, 0xfffffffd, 5); @@ -4472,11 +4288,15 @@ MCHBAR8(0x271) = 0x2; MCHBAR8(0x671) = 0x2; MCHBAR8(0x1e8) = 0x4; - for (channel = 0; channel < NUM_CHANNELS; channel++) + + for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32(0x294 + (channel << 10)) = (info.populated_ranks_mask[channel] & 3) << 16; + } + MCHBAR32_AND_OR(0x134, 0xfc01ffff, 0x10000); MCHBAR32_AND_OR(0x134, 0xfc85ffff, 0x850000); + for (channel = 0; channel < NUM_CHANNELS; channel++) MCHBAR32_AND_OR(0x260 + (channel << 10), ~0xf00000, 0x8000000 | ((info.populated_ranks_mask[channel] & 3) << 20)); @@ -4485,14 +4305,15 @@ jedec_init(&info);
int totalrank = 0; - for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - if (info.populated_ranks[channel][slot][rank]) { - jedec_read(&info, channel, slot, rank, - totalrank, 0xa, 0x400); - totalrank++; - } + + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + if (info.populated_ranks[channel][slot][rank]) { + jedec_read(&info, channel, slot, rank, totalrank, 0xa, 0x400); + totalrank++; + } + }}} /* for each channel, slot, rank */
MCHBAR8(0x12c) = 0x9f;
@@ -4503,39 +4324,42 @@ for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32(0x294 + (channel << 10)) = (info.populated_ranks_mask[channel] & 3) << 16; + MCHBAR16(0x298 + (channel << 10)) = - info.populated_ranks[channel][0][0] | + info.populated_ranks[channel][0][0] | (info.populated_ranks[channel][0][1] << 5); + MCHBAR32(0x29c + (channel << 10)) = 0x77a; } MCHBAR32_AND_OR(0x2c0, 0, 0x6009cc00); // !!!!
- { - u8 a, b; - a = MCHBAR8(0x243); - b = MCHBAR8(0x643); - MCHBAR8(0x243) = a | 2; - MCHBAR8(0x643) = b | 2; - } + + u8 a, b; + a = MCHBAR8(0x243); + b = MCHBAR8(0x643); + MCHBAR8(0x243) = a | 2; + MCHBAR8(0x643) = b | 2; +
write_1d0(7, 0x19b, 3, 1); write_1d0(7, 0x1c0, 3, 1); write_1d0(4, 0x1c6, 4, 1); write_1d0(4, 0x1cc, 4, 1); + read_1d0(0x151, 4); // = 0x408c6d74 // !!!! write_1d0(4, 0x151, 4, 1); + MCHBAR32(0x584) = 0xfffff; MCHBAR32(0x984) = 0xfffff;
- for (channel = 0; channel < NUM_CHANNELS; channel++) - for (slot = 0; slot < NUM_SLOTS; slot++) - for (rank = 0; rank < NUM_RANKS; rank++) - if (info. - populated_ranks[channel][slot] - [rank]) - config_rank(&info, s3resume, - channel, slot, - rank); + for (channel = 0; channel < NUM_CHANNELS; channel++) { + for (slot = 0; slot < NUM_SLOTS; slot++) { + for (rank = 0; rank < NUM_RANKS; rank++) { + + if (info.populated_ranks[channel][slot][rank]) { + config_rank(&info, s3resume, channel, slot, rank); + } + }}} /* for each channel, slot, rank */
MCHBAR8(0x243) = 0x1; MCHBAR8(0x643) = 0x1; @@ -4552,9 +4376,11 @@ for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32(0x294 + (channel << 10)) = (info.populated_ranks_mask[channel] & 3) << 16; + MCHBAR16(0x298 + (channel << 10)) = - info.populated_ranks[channel][0][0] | + info.populated_ranks[channel][0][0] | (info.populated_ranks[channel][0][1] << 5); + MCHBAR32(0x29c + (channel << 10)) = 0x77a; } MCHBAR32_AND_OR(0x2c0, 0, 0x6009cc00); // !!!! @@ -4579,10 +4405,13 @@
if (info.non_interleaved_part_mb != 0 && info.interleaved_part_mb != 0) MCHBAR8(0x111) = 0x20 | (0 << 2) | (1 << 6) | (0 << 7); + else if (have_match_ranks(&info, 0, 4) && have_match_ranks(&info, 1, 4)) MCHBAR8(0x111) = 0x20 | (3 << 2) | (0 << 6) | (1 << 7); + else if (have_match_ranks(&info, 0, 2) && have_match_ranks(&info, 1, 2)) MCHBAR8(0x111) = 0x20 | (3 << 2) | (0 << 6) | (0 << 7); + else MCHBAR8(0x111) = 0x20 | (3 << 2) | (1 << 6) | (0 << 7);
@@ -4622,38 +4451,35 @@ } #endif
- { - u32 eax; - - eax = info.fsb_frequency / 9; - MCHBAR32_AND_OR(0xfcc, 0xfffc0000, - (eax * 0x280) | (eax * 0x5000) | eax | 0x40000); - MCHBAR32(0x20) = 0x33001; - } + u32 eax = info.fsb_frequency / 9; + MCHBAR32_AND_OR(0xfcc, 0xfffc0000, (eax * 0x280) | (eax * 0x5000) | eax | 0x40000); + MCHBAR32(0x20) = 0x33001;
for (channel = 0; channel < NUM_CHANNELS; channel++) { MCHBAR32_AND(0x220 + (channel << 10), ~0x7770); + if (info.max_slots_used_in_channel == 1) - MCHBAR16_OR(0x237 + (channel << 10), 0x0201); + MCHBAR16_OR( 0x237 + (channel << 10), 0x0201); else MCHBAR16_AND(0x237 + (channel << 10), ~0x0201);
MCHBAR8_OR(0x241 + (channel << 10), 1);
- if (info.clock_speed_index <= 1 && (info.silicon_revision == 2 - || info.silicon_revision == 3)) + if (info.clock_speed_index <= 1 + && (info.silicon_revision == 2 || info.silicon_revision == 3)) { MCHBAR32_OR(0x248 + (channel << 10), 0x00102000); - else + } else { MCHBAR32_AND(0x248 + (channel << 10), ~0x00102000); + } }
MCHBAR32_OR(0x115, 0x1000000);
{ - u8 al; - al = 0xd; + u8 al = 0xd; if (!(info.silicon_revision == 0 || info.silicon_revision == 1)) al += 2; + al |= ((1 << (info.max_slots_used_in_channel - 1)) - 1) << 4; MCHBAR32(0x210) = (al << 16) | 0x20; } @@ -4664,6 +4490,7 @@ MCHBAR32(0x290 + (channel << 10)) = 0x282091c | ((info.max_slots_used_in_channel - 1) << 0x16); } + u32 reg1c; pci_read_config32(NORTHBRIDGE, 0x40); // = DEFAULT_EPBAR | 0x001 // OK reg1c = read32p(DEFAULT_EPBAR | 0x01c); // = 0x8001 // OK @@ -4689,9 +4516,9 @@ MCHBAR8(0x121c) = 0x3; MCHBAR16(0xc14) = 0x0; MCHBAR16(0xc20) = 0x0; - MCHBAR32(0x1c) = 0x0; + MCHBAR32(0x01c) = 0x0;
- /* revision dependent here. */ + /* revision dependent here. */
MCHBAR16_OR(0x1230, 0x1f07);
@@ -4702,13 +4529,12 @@ MCHBAR8_OR(0x1214, 1);
u8 bl, ebpb; - u16 reg_1020;
- reg_1020 = MCHBAR32(0x1020); // = 0x6c733c // OK - MCHBAR8(0x1070) = 0x1; + u16 reg_1020 = MCHBAR32(0x1020); // = 0x6c733c // OK
+ MCHBAR8(0x1070) = 0x1; MCHBAR32(0x1000) = 0x100; - MCHBAR8(0x1007) = 0x0; + MCHBAR8(0x1007) = 0x0;
if (reg_1020 != 0) { MCHBAR16(0x1018) = 0x0; @@ -4722,12 +4548,11 @@ rdmsr(0x1a2);
MCHBAR32(0x1014) = 0xffffffff; - MCHBAR32(0x1010) = ((((ebpb + 0x7d) << 7) / bl) & 0xff) * (!!reg_1020);
MCHBAR8(0x101c) = 0xb8; - MCHBAR8(0x123e) = (MCHBAR8(0x123e) & 0xf) | 0x60; + if (reg_1020 != 0) { MCHBAR32_AND_OR(0x123c, ~0x00900000, 0x600000); MCHBAR8(0x101c) = 0xb8; @@ -4750,20 +4575,25 @@ u16 ecx; for (ecx = 0xffff; ecx && (MCHBAR16(0x1170) & 0x1000); ecx--) ; + MCHBAR16_AND(0x1190, ~0x4000); }
pci_write_config8(SOUTHBRIDGE, GEN_PMCON_2, pci_read_config8(SOUTHBRIDGE, GEN_PMCON_2) & ~0x80); + udelay(10000); + MCHBAR16(0x2ca8) = 0x8;
udelay(1000); + dump_timings(&info); cbmem_wasnot_inited = cbmem_recovery(s3resume);
if (!s3resume) save_timings(&info); + if (s3resume && cbmem_wasnot_inited) { u32 reg32; printk(BIOS_ERR, "Failed S3 resume.\n");
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Change subject: nb/intel/nehalem: Try to clean up code ......................................................................
Patch Set 1:
(85 comments)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 609: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 655: for (tm_reg = 0; tm_reg < 4; tm_reg++) suspect code indent for conditional statements (32, 32)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 689: }} /* for each slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 693: for (i = 0; i < 3; i++) suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 884: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (24, 24)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 898: b = u16_fe0eb8 [0][info->clock_speed_index]; space prohibited before open square bracket '['
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 903: b = u16_fe0eb8 [1][info->clock_speed_index]; space prohibited before open square bracket '['
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 920: }} /* for each slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1038: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1039: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1059: }}} /* for each slot, rank, if populated */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1071: total_mb[channel] += pre_jedec ? 256 : (256 << info->density[channel][slot] >> info->is_x16_module[channel][slot]); line over 96 characters
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1312: {0, 1, 0, 2, 0, 0, 0, 0, 0, 2, 3, 4, 42, 42, 42, 42}; that open brace { should be on the previous line
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1316: {0, 0, 0, 0, 0, 32, 48, 64, 128, 256, 96, 160, 224, 352, 256, 512}; that open brace { should be on the previous line
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1481: for (tm = 0; tm < 4; tm++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1482: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1483: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1484: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1490: }}}}} /* for each tm, channel, slot, rank, lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1509: info->training.lane_timings[i][channel][slot][rank][lane]); line over 96 characters
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1527: for (lane = 0; lane < 9; lane++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1532: }}} /* for each populated rank, lane, i */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1637: static int recv_heci_packet(struct raminfo *info, struct mei_header *head, u32 *packet, u32 *packet_size) line over 96 characters
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1651: while (csr.csr.buffer_write_ptr == csr.csr.buffer_read_ptr); trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1651: while (csr.csr.buffer_write_ptr == csr.csr.buffer_read_ptr); while should follow close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1763: info->heci_uma_addr = ((u64)((((u64) pci_read_config16(NORTHBRIDGE, D0F0_TOM)) << 6) - info->memory_reserved_for_heci_mb)) << 20; line over 96 characters
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1829: for (i = 0; i < 2; i++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1830: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1831: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1832: for (lane = 0; lane < 9; lane++) { braces {} are not necessary for single statement blocks
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1835: }}}} /* for each i, slot, rank, lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1837: for (i = 1; i < 4; i++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1838: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1839: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1840: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 1849: }}}}} /* for each i, channel, slot, lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2053: for (comp1 = 0; comp1 < 16; comp1++) suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2202: for (lane = 0; lane < 8; lane++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2221: }} /* for each lane, if complete */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2226: for (lane = 0; lane < 8; lane++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2242: }} /* for each lane, depending whether it's complete */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2261: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2267: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2282: training.lane_timings[1] Avoid multiple line dereference - prefer 'info->training.lane_timings[1]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2297: for (lane = 0; lane < 8; lane++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2313: }} /* for each lane, depending whether it's complete */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2332: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2353: training.lane_timings[1] Avoid multiple line dereference - prefer 'info->training.lane_timings[1]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2521: timing_bounds_t * timings, u8 center_178) "foo * bar" should be "foo *bar"
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2671: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2672: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2673: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2690: }}}} /* For each channel, slot, rank, lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2743: timing2_bounds[channel][slot][rank][lane][i], Avoid multiple line dereference - prefer 'info->cached_training->timing2_bounds[channel][slot][rank][lane][i]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2749: timing2_offset[channel][slot][rank] Avoid multiple line dereference - prefer 'info->cached_training->timing2_offset[channel][slot][rank]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2754: timing_bounds[tm][channel][slot][rank][lane]. Avoid multiple line dereference - prefer 'info->cached_training->timing_bounds[tm][channel][slot][rank][lane]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2755: largest : info->cached_training->timing_bounds Avoid multiple line dereference - prefer 'timing_bounds[tm][channel][slot][rank][lane].largest'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2761: timing_offset[channel][slot][rank][lane] + Avoid multiple line dereference - prefer 'info->cached_training->timing_offset[channel][slot][rank][lane]'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2886: for (channel = NUM_CHANNELS - 1; channel >= 0; channel--) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2887: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2899: }}} /* for each channel, slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2935: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (24, 24)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2943: }} /* for each slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2953: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (24, 24)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 2961: }} /* for each slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3179: vv.freq_max_reduced * multiplier)| (vv.freqs_reversed << 8) | need consistent spacing around '|' (ctx:VxW)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3325: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3326: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3327: if (info->populated_ranks[channel][slot][rank]) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3333: }}}} /* for each slot, rank, if populated, for each lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3410: if (delay_b_ps <= delay_a_ps) { braces {} are not necessary for any arm of this statement
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 3633: spd_bytes[addr])); code indent should use tabs where possible
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4162: for (tm = 0; tm < 4; tm++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4163: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4164: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4165: for (rank = 0; rank < NUM_RANKS; rank++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4172: }}}}} /* for each tm, channel, slot, rank, lane */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4309: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4310: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (8, 8)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4316: }}} /* for each channel, slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4355: for (channel = 0; channel < NUM_CHANNELS; channel++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4356: for (slot = 0; slot < NUM_SLOTS; slot++) { suspect code indent for conditional statements (16, 16)
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4359: if (info.populated_ranks[channel][slot][rank]) { braces {} are not necessary for single statement blocks
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4362: }}} /* for each channel, slot, rank */ space required after that close brace '}'
https://review.coreboot.org/c/coreboot/+/38359/1/src/northbridge/intel/nehal... PS1, Line 4462: MCHBAR16_OR( 0x237 + (channel << 10), 0x0201); space prohibited after that open parenthesis '('
Hello Patrick Rudolph, build bot (Jenkins),
Looks like raminit.c desperately needs a serious refactor.
Using BUILD_TIMELESS=1, this does not change packardbell/ms2290 builds.
Change-Id: I4d2501317faf3e4a7cf8a0ccb471d334232bfeae Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/nehalem/acpi.c M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/finalize.c M src/northbridge/intel/nehalem/gma.c M src/northbridge/intel/nehalem/nehalem.h M src/northbridge/intel/nehalem/northbridge.c M src/northbridge/intel/nehalem/raminit.c M src/northbridge/intel/nehalem/raminit.h 8 files changed, 1,861 insertions(+), 2,007 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/2
Patch Set 2:
(48 comments)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 53: #define FOR_ALL_RANKS \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 54: for (channel = 0; channel < NUM_CHANNELS; channel++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 54: for (channel = 0; channel < NUM_CHANNELS; channel++) \ suspect code indent for conditional statements (2, 4)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 55: for (slot = 0; slot < NUM_SLOTS; slot++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 55: for (slot = 0; slot < NUM_SLOTS; slot++) \ suspect code indent for conditional statements (4, 6)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 56: for (rank = 0; rank < NUM_RANKS; rank++) please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 58: #define FOR_ALL_RANKS_BACKWARDS \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 59: for (channel = NUM_CHANNELS - 1; channel >= 0; channel--) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 59: for (channel = NUM_CHANNELS - 1; channel >= 0; channel--) \ suspect code indent for conditional statements (2, 4)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 60: for (slot = 0; slot < NUM_SLOTS; slot++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 60: for (slot = 0; slot < NUM_SLOTS; slot++) \ suspect code indent for conditional statements (4, 6)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 63: #define FOR_CHAN_RANKS \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 64: for (slot = 0; slot < NUM_SLOTS; slot++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 64: for (slot = 0; slot < NUM_SLOTS; slot++) \ suspect code indent for conditional statements (2, 4)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 65: for (rank = 0; rank < NUM_RANKS; rank++) please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 67: #define FOR_POPULATED_RANKS \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 68: for (channel = 0; channel < NUM_CHANNELS; channel++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 68: for (channel = 0; channel < NUM_CHANNELS; channel++) \ suspect code indent for conditional statements (2, 4)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 69: for (slot = 0; slot < NUM_SLOTS; slot++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 69: for (slot = 0; slot < NUM_SLOTS; slot++) \ suspect code indent for conditional statements (4, 6)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 70: for (rank = 0; rank < NUM_RANKS; rank++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 71: if (info->populated_ranks[channel][slot][rank]) code indent should use tabs where possible
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 71: if (info->populated_ranks[channel][slot][rank]) please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 73: #define FOR_POPULATED_CHAN_RANKS \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 74: for (slot = 0; slot < NUM_SLOTS; slot++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 74: for (slot = 0; slot < NUM_SLOTS; slot++) \ suspect code indent for conditional statements (2, 4)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 75: for (rank = 0; rank < NUM_RANKS; rank++) \ please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 75: for (rank = 0; rank < NUM_RANKS; rank++) \ suspect code indent for conditional statements (4, 6)
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 76: if (info->populated_ranks[channel][slot][rank]) please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 82: if (info->populated_ranks[channel][slot][rank]) code indent should use tabs where possible
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 82: if (info->populated_ranks[channel][slot][rank]) please, no spaces at the start of a line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 416: training.lane_timings[2][channel][slot][rank][lane] + 0x20; Avoid multiple line dereference - prefer 'info->training.lane_timings[2][channel][slot][rank][lane]'
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 735: avg4044[channel] + u8_FFFD17E0[channel][extended_silicon_revision] Avoid multiple line dereference - prefer 'info->avg4044[channel]'
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 1521: for (tm = 0; tm < 4; tm++) FOR_ALL_RANKS for (lane = 0; lane < 9; lane++) { trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 1564: FOR_POPULATED_RANKS for (lane = 0; lane < 9; lane++) for (i = 0; i < 4; i++) { trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 1871: for (i = 0; i < 2; i++) FOR_CHAN_RANKS for (lane = 0; lane < 9; lane++) { trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 1877: for (i = 1; i < 4; i++) FOR_ALL_RANKS for (lane = 0; lane < 9; lane++) { trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 2303: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 2309: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 2383: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 2722: FOR_ALL_RANKS for (lane = 0; lane < 8 + info->use_ecc; lane++) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 3372: FOR_POPULATED_CHAN_RANKS for (lane = 0; lane < 8 + info->use_ecc; lane++) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 3836: pci_read_config32(PCI_DEV (0xff, 0, 0), 0xd0); // !!!! space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 3837: pci_write_config32(PCI_DEV (0xff, 0, 0), 0xd0, 0x00000180); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 4113: pci_write_config32(PCI_DEV (0xff, 0, 0), 0x60, 0x00020220); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 4208: for (tm = 0; tm < 4; tm++) FOR_ALL_RANKS for (lane = 0; lane < 9; lane++) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 4208: for (tm = 0; tm < 4; tm++) FOR_ALL_RANKS for (lane = 0; lane < 9; lane++) { trailing statements should be on next line
https://review.coreboot.org/c/coreboot/+/38359/2/src/northbridge/intel/nehal... PS2, Line 4395: if (info.populated_ranks[channel][slot][rank]) { braces {} are not necessary for single statement blocks
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Patch Set 2:
Did you use a tool to do this?
Feel free to have a look at CB:36083 and CB:36084 ;)
Hello Patrick Rudolph, Felix Held, build bot (Jenkins),
Change-Id: I4d2501317faf3e4a7cf8a0ccb471d334232bfeae Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/nehalem/acpi.c M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/finalize.c M src/northbridge/intel/nehalem/gma.c M src/northbridge/intel/nehalem/nehalem.h M src/northbridge/intel/nehalem/northbridge.c M src/northbridge/intel/nehalem/raminit.c M src/northbridge/intel/nehalem/raminit.h 8 files changed, 2,047 insertions(+), 2,172 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/3
Patch Set 3:
(25 comments)
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 61: #define FOR_CHAN_RANKS FOR_EACH_SLOT FOR_EACH_RANK Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 62: #define FOR_CHAN_LANES(ecc) FOR_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 64: #define FOR_ALL_RANKS FOR_EACH_CHANNEL_UP FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 65: #define FOR_ALL_RANKS_BACKWARDS FOR_EACH_CHANNEL_DN FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 67: #define FOR_ALL_SLOTS FOR_EACH_CHANNEL_UP FOR_EACH_SLOT Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 69: #define FOR_ALL_LANES(ecc) FOR_ALL_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 71: #define IF_POPULATED if (info->populated_ranks[channel][slot][rank]) Macros starting with if should be enclosed by a do - while loop to avoid possible if/else logic defects
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 73: #define FOR_POPULATED_RANKS FOR_ALL_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 74: #define FOR_POPULATED_CHAN_RANKS FOR_CHAN_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 75: #define FOR_POPULATED_RANKS_BACKWARDS FOR_ALL_RANKS_BACKWARDS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 77: #define FOR_POPULATED_RANKS_LANES(ecc) FOR_POPULATED_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2319: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2325: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2399: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2465: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2688: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 2974: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 3050: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 3396: FOR_POPULATED_CHAN_RANKS FOR_EACH_LANE(info->use_ecc) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 3854: pci_read_config32(PCI_DEV (0xff, 0, 0), 0xd0); // !!!! space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 3855: pci_write_config32(PCI_DEV (0xff, 0, 0), 0xd0, 0x00000180); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 4131: pci_write_config32(PCI_DEV (0xff, 0, 0), 0x60, 0x00020220); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 4205: FOR_EACH_CHANNEL_UP FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 4227: FOR_ALL_RANKS FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/3/src/northbridge/intel/nehal... PS3, Line 4416: if (info.populated_ranks[channel][slot][rank]) { braces {} are not necessary for single statement blocks
Change-Id: I4d2501317faf3e4a7cf8a0ccb471d334232bfeae Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/nehalem/acpi.c M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/finalize.c M src/northbridge/intel/nehalem/gma.c M src/northbridge/intel/nehalem/nehalem.h M src/northbridge/intel/nehalem/northbridge.c M src/northbridge/intel/nehalem/raminit.c M src/northbridge/intel/nehalem/raminit.h M src/northbridge/intel/nehalem/raminit_tables.c M src/northbridge/intel/nehalem/raminit_tables.h 10 files changed, 2,224 insertions(+), 2,303 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/4
Patch Set 4:
(25 comments)
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 72: #define FOR_CHAN_RANKS FOR_EACH_SLOT FOR_EACH_RANK Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 73: #define FOR_CHAN_LANES(ecc) FOR_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 74: #define FOR_ALL_RANKS FOR_EACH_CHANNEL_UP FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 75: #define FOR_ALL_RANKS_BACKWARDS FOR_EACH_CHANNEL_DN FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 76: #define FOR_ALL_SLOTS FOR_EACH_CHANNEL_UP FOR_EACH_SLOT Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 77: #define FOR_ALL_LANES(ecc) FOR_ALL_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 79: #define IF_POPULATED if (info->populated_ranks[channel][slot][rank]) Macros starting with if should be enclosed by a do - while loop to avoid possible if/else logic defects
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 80: #define FOR_POPULATED_RANKS FOR_ALL_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 81: #define FOR_POPULATED_CHAN_RANKS FOR_CHAN_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 82: #define FOR_POPULATED_RANKS_BACKWARDS FOR_ALL_RANKS_BACKWARDS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 83: #define FOR_POPULATED_RANKS_LANES(ecc) FOR_POPULATED_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2333: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2339: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2414: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2480: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2701: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 2988: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 3064: FOR_POPULATED_RANKS_BACKWARDS FOR_EACH_LANE(0) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 3410: FOR_POPULATED_CHAN_RANKS FOR_EACH_LANE(info->use_ecc) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 3868: pci_read_config32(PCI_DEV (0xff, 0, 0), 0xd0); // !!!! space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 3869: pci_write_config32(PCI_DEV (0xff, 0, 0), 0xd0, 0x00000180); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 4149: pci_write_config32(PCI_DEV (0xff, 0, 0), 0x60, 0x00020220); space prohibited between function name and open parenthesis '('
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 4223: FOR_EACH_CHANNEL_UP FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 4245: FOR_ALL_RANKS FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
https://review.coreboot.org/c/coreboot/+/38359/4/src/northbridge/intel/nehal... PS4, Line 4434: if (info.populated_ranks[channel][slot][rank]) { braces {} are not necessary for single statement blocks
Change-Id: I4d2501317faf3e4a7cf8a0ccb471d334232bfeae Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/nehalem/acpi.c M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/finalize.c M src/northbridge/intel/nehalem/gma.c M src/northbridge/intel/nehalem/nehalem.h M src/northbridge/intel/nehalem/northbridge.c M src/northbridge/intel/nehalem/raminit.c M src/northbridge/intel/nehalem/raminit.h M src/northbridge/intel/nehalem/raminit_tables.c M src/northbridge/intel/nehalem/raminit_tables.h 10 files changed, 2,220 insertions(+), 2,308 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/5
Patch Set 5:
(17 comments)
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 73: #define FOR_CHAN_RANKS FOR_EACH_SLOT FOR_EACH_RANK Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 74: #define FOR_CHAN_LANES(ecc) FOR_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 75: #define FOR_ALL_RANKS FOR_EACH_CHANNEL_UP FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 76: #define FOR_ALL_RANKS_DOWN FOR_EACH_CHANNEL_DN FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 77: #define FOR_ALL_SLOTS FOR_EACH_CHANNEL_UP FOR_EACH_SLOT Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 78: #define FOR_ALL_LANES(ecc) FOR_ALL_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 80: #define IF_POPULATED if (info->populated_ranks[channel][slot][rank]) Macros starting with if should be enclosed by a do - while loop to avoid possible if/else logic defects
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 81: #define FOR_POPULATED_RANKS FOR_ALL_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 82: #define FOR_POPULATED_RANKS_DOWN FOR_ALL_RANKS_DOWN IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 83: #define FOR_POPULATED_CHAN_RANKS FOR_CHAN_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 85: #define FOR_POPULATED_LANES(ecc) FOR_POPULATED_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 86: #define FOR_POPULATED_LANES_DOWN(ecc) FOR_POPULATED_RANKS_DOWN FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 87: #define FOR_POPULATED_CHAN_LANES(ecc) FOR_POPULATED_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 2336: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 2342: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 2415: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/5/src/northbridge/intel/nehal... PS5, Line 4237: FOR_ALL_RANKS FOR_EACH_LANE(1) { open brace '{' following function definitions go on the next line
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Patch Set 5:
Okay, I think this is ready.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/38359/6
Patch Set 6:
(16 comments)
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... File src/northbridge/intel/nehalem/raminit.c:
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 73: #define FOR_CHAN_RANKS FOR_EACH_SLOT FOR_EACH_RANK Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 74: #define FOR_CHAN_LANES(ecc) FOR_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 75: #define FOR_ALL_RANKS FOR_EACH_CHANNEL_UP FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 76: #define FOR_ALL_RANKS_DOWN FOR_EACH_CHANNEL_DN FOR_CHAN_RANKS Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 77: #define FOR_ALL_SLOTS FOR_EACH_CHANNEL_UP FOR_EACH_SLOT Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 78: #define FOR_ALL_LANES(ecc) FOR_ALL_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 80: #define IF_POPULATED if (info->populated_ranks[channel][slot][rank]) Macros starting with if should be enclosed by a do - while loop to avoid possible if/else logic defects
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 81: #define FOR_POPULATED_RANKS FOR_ALL_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 82: #define FOR_POPULATED_RANKS_DOWN FOR_ALL_RANKS_DOWN IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 83: #define FOR_POPULATED_CHAN_RANKS FOR_CHAN_RANKS IF_POPULATED Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 85: #define FOR_POPULATED_LANES(ecc) FOR_POPULATED_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 86: #define FOR_POPULATED_LANES_DOWN(ecc) FOR_POPULATED_RANKS_DOWN FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 87: #define FOR_POPULATED_CHAN_LANES(ecc) FOR_POPULATED_CHAN_RANKS FOR_EACH_LANE(ecc) Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 2336: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 2342: } else { Too many leading tabs - consider code refactoring
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 2415: if (timings[reg_178][channel][slot][rank] Too many leading tabs - consider code refactoring
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Patch Set 6:
(2 comments)
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 3879: /* Don't enable S4-assertion stretch. Makes trouble on roda/rk9. : reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa4); : pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa4, reg8 | 0x08); : */ is it intentional that this comment gets dropped?
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 71: #define FOR_EACH_LANE(ecc) FOR_RANGE_UP(lane, LANES + (ecc)) i dislike the semantics of this macro; imho it would be much clearer to define it as #define FOR_EACH_LANE(lanes) FOR_RANGE_UP(lane, (lanes)) and use FOR_EACH_LANE(LANES) or FOR_EACH_LANE(LANES_ECC) in the code. or have a FOR_EACH_LANE and a separate FOR_EACH_LANE_ECC. At least for me the FOR_EACH_LANE(0) or FOR_EACH_LANE(1) isn't very obvious without looking at the macro definition
Patch Set 6:
(3 comments)
https://review.coreboot.org/c/coreboot/+/38359/6//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38359/6//COMMIT_MSG@9 PS6, Line 9: raminit.c That file makes gerrit slow down to a halt on my laptop. There was an open comment there:
An option is to make 0 and 1 carry their meaning: #define EXCEPT_ECC 0 #define INCLUDING_ECC 1
That way, the resulting macros read rather naturally. If that sounds too cursed, the names can be applied to the FOR_EACH_LANE(x) macros instead.
Yes. roda/rk9 is not a nehalem platform, the comment was copied off some other platform.
i dislike the semantics of this macro; imho it would be much clearer to define it as […]
Agreed, opened a comment in the commit message instead. It's too laggy in here.
Maccraft123 has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Patch Set 6:
Thank you :D
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/38359/6/src/northbridge/intel/nehal... PS6, Line 312: FOR_RANGE_UP(i, 32) { I’d prefer the for loops.
Patch Set 6:
Disclaimer: The rant should not be taken personally.
Patch Set 2:
No, I did this by hand. At most, I used search-and-replace.
<rant>
Seriously? Do people read this file so often this matters? What about the long multidimensional array indexing that almost always needs to be split? And nothing wrong about the code that is indented almost outside of the 96-character limit???
Using these macros makes the loops consistent with the other for-loop macros. Most of the for-loops in the code are looping around a range, either up or down, and many of these are looping over channels, slots, ranks or lanes. In many cases, these loops are nested, which results in unbearably indented code.
Moreover, as I stated in the other comments, this file makes my browser slow down to a crawl. I had to write this on a standalone text editor.
I will mark this as resolved; if you consider it is not, please open a comment elsewhere.
</rant>
Angel Pons has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/38359 )
Abandoned
