Attention is currently required from: Ana Carolina Cabral, Anand Vaikar, Fred Reitberger, Jason Glenesk, Matt DeVillier, Nick Kochlowski.
Hello Ana Carolina Cabral, Felix Held, Fred Reitberger, Jason Glenesk, Matt DeVillier, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85865?usp=email
Change subject: soc/amd/cezanne: add option to disable I2S master clock output of FCH ......................................................................
Add a devicetree option to disable the 48MHz clock output of the FCH when an I2S audio codec uses a separate oscillator for its 48 MHz master clock instead of the FCH clock output. This code was ported from the Picasso code base.
Change-Id: I0c1bee121f528d28d591dace260507b345dfec26 Signed-off-by: Anand Vaikar a.vaikar2021@gmail.com --- M src/soc/amd/cezanne/chip.h M src/soc/amd/cezanne/fch.c 2 files changed, 12 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/85865/5
