Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/50936 )
Change subject: soc/intel: Backport SMRR locking support ......................................................................
Backport commit 0cded1f116 (soc/intel/tigerlake: Add SMRR Locking support) to other client platforms. The SMRR MSRs are core-scoped on Skylake and Ice Lake, at least. Older platforms do not support SMRR locking, but now there's seven copies of the same file in the tree. A follow-up will deduplicate smmrelocate.c files into common CPU code.
I cannot test Jasper Lake nor Elkhart Lake, but they should still work. As per documentation I do not have access to, Elkhart Lake seems to support SMRR locking. However, Jasper Lake documentation is unclear.
Tested on Purism Librem Mini v1 (WHL-U i7-8565U), still boots and SMRR MSRs have the same value on all cores/threads (i7-8565U supports HT).
Change-Id: Icbee0985b04418e83cbf41b81f00934f5a663e30 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/50936 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Michael Niewöhner foss@mniewoehner.de Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz Reviewed-by: Nico Huber nico.h@gmx.de --- M src/soc/intel/cannonlake/smmrelocate.c M src/soc/intel/elkhartlake/smmrelocate.c M src/soc/intel/icelake/smmrelocate.c M src/soc/intel/jasperlake/smmrelocate.c M src/soc/intel/skylake/smmrelocate.c 5 files changed, 85 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved Arthur Heymans: Looks good to me, approved Tim Wawrzynczak: Looks good to me, but someone else must approve Michael Niewöhner: Looks good to me, approved
diff --git a/src/soc/intel/cannonlake/smmrelocate.c b/src/soc/intel/cannonlake/smmrelocate.c index 0cc42e2..4df90fd 100644 --- a/src/soc/intel/cannonlake/smmrelocate.c +++ b/src/soc/intel/cannonlake/smmrelocate.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <console/console.h> +#include <cpu/intel/common/common.h> #include <cpu/intel/em64t101_save_state.h> #include <cpu/intel/smm_reloc.h> #include <cpu/x86/mp.h> @@ -137,8 +138,24 @@ /* Make appropriate changes to the save state map. */ update_save_state(cpu, curr_smbase, staggered_smbase, relo_params);
+ /* + * The SMRR MSRs are core-level registers, so if two threads that share + * a core try to both set the lock bit (in the same physical register), + * a #GP will be raised on the second write to that register (which is + * exactly what the lock is supposed to do), therefore secondary threads + * should exit here. + */ + if (intel_ht_sibling()) + return; + /* Write SMRR MSRs based on indicated support. */ mtrr_cap = rdmsr(MTRR_CAP_MSR); + + /* Set Lock bit if supported */ + if (mtrr_cap.lo & SMRR_LOCK_SUPPORTED) + relo_params->smrr_mask.lo |= SMRR_PHYS_MASK_LOCK; + + /* Write SMRRs if supported */ if (mtrr_cap.lo & SMRR_SUPPORTED) write_smrr(relo_params); } diff --git a/src/soc/intel/elkhartlake/smmrelocate.c b/src/soc/intel/elkhartlake/smmrelocate.c index 0cc42e2..4df90fd 100644 --- a/src/soc/intel/elkhartlake/smmrelocate.c +++ b/src/soc/intel/elkhartlake/smmrelocate.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+ /* + * The SMRR MSRs are core-level registers, so if two threads that share + * a core try to both set the lock bit (in the same physical register), + * a #GP will be raised on the second write to that register (which is + * exactly what the lock is supposed to do), therefore secondary threads + * should exit here. + */ + if (intel_ht_sibling()) + return; + /* Write SMRR MSRs based on indicated support. */ mtrr_cap = rdmsr(MTRR_CAP_MSR); + + /* Set Lock bit if supported */ + if (mtrr_cap.lo & SMRR_LOCK_SUPPORTED) + relo_params->smrr_mask.lo |= SMRR_PHYS_MASK_LOCK; + + /* Write SMRRs if supported */ if (mtrr_cap.lo & SMRR_SUPPORTED) write_smrr(relo_params); } diff --git a/src/soc/intel/icelake/smmrelocate.c b/src/soc/intel/icelake/smmrelocate.c index 0cc42e2..4df90fd 100644 --- a/src/soc/intel/icelake/smmrelocate.c +++ b/src/soc/intel/icelake/smmrelocate.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+ /* + * The SMRR MSRs are core-level registers, so if two threads that share + * a core try to both set the lock bit (in the same physical register), + * a #GP will be raised on the second write to that register (which is + * exactly what the lock is supposed to do), therefore secondary threads + * should exit here. + */ + if (intel_ht_sibling()) + return; + /* Write SMRR MSRs based on indicated support. */ mtrr_cap = rdmsr(MTRR_CAP_MSR); + + /* Set Lock bit if supported */ + if (mtrr_cap.lo & SMRR_LOCK_SUPPORTED) + relo_params->smrr_mask.lo |= SMRR_PHYS_MASK_LOCK; + + /* Write SMRRs if supported */ if (mtrr_cap.lo & SMRR_SUPPORTED) write_smrr(relo_params); } diff --git a/src/soc/intel/jasperlake/smmrelocate.c b/src/soc/intel/jasperlake/smmrelocate.c index 0cc42e2..4df90fd 100644 --- a/src/soc/intel/jasperlake/smmrelocate.c +++ b/src/soc/intel/jasperlake/smmrelocate.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+ /* + * The SMRR MSRs are core-level registers, so if two threads that share + * a core try to both set the lock bit (in the same physical register), + * a #GP will be raised on the second write to that register (which is + * exactly what the lock is supposed to do), therefore secondary threads + * should exit here. + */ + if (intel_ht_sibling()) + return; + /* Write SMRR MSRs based on indicated support. */ mtrr_cap = rdmsr(MTRR_CAP_MSR); + + /* Set Lock bit if supported */ + if (mtrr_cap.lo & SMRR_LOCK_SUPPORTED) + relo_params->smrr_mask.lo |= SMRR_PHYS_MASK_LOCK; + + /* Write SMRRs if supported */ if (mtrr_cap.lo & SMRR_SUPPORTED) write_smrr(relo_params); } diff --git a/src/soc/intel/skylake/smmrelocate.c b/src/soc/intel/skylake/smmrelocate.c index 0cc42e2..4df90fd 100644 --- a/src/soc/intel/skylake/smmrelocate.c +++ b/src/soc/intel/skylake/smmrelocate.c @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
