Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18516
commit ad9cb86fcc584f336d6edc4cda830982acdf7072 Author: Arthur Heymans arthur@aheymans.xyz Date: Mon Feb 27 21:45:07 2017 +0100
nb/intel/x4x: Add support for second PEG slot
Is only present on the P45 subtype of chipset.
Change-Id: I6b138db6654c83c40b5ca4b65d6ccd51ad4277fa Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/northbridge/intel/x4x/northbridge.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/src/northbridge/intel/x4x/northbridge.c b/src/northbridge/intel/x4x/northbridge.c index 8f2068d..7cf778a 100644 --- a/src/northbridge/intel/x4x/northbridge.c +++ b/src/northbridge/intel/x4x/northbridge.c @@ -182,8 +182,12 @@ static void x4x_init(void *const chip_info) struct device *const d0f0 = dev_find_slot(0, 0);
/* Hide internal functions based on devicetree info. */ - for (dev = 3; dev > 0; --dev) { + for (dev = 6; dev > 0; --dev) { switch (dev) { + case 6: /* PEG1: only on P45 */ + fn = 0; + bit_base = 13; + break; case 3: /* ME */ fn = 3; bit_base = 6; @@ -192,10 +196,13 @@ static void x4x_init(void *const chip_info) fn = 1; bit_base = 3; break; - case 1: /* PEG */ + case 1: /* PEG0 */ fn = 0; bit_base = 1; break; + case 4: /* Should not happen */ + case 5: + continue; } for (; fn >= 0; --fn) { const struct device *const d =
