Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/70065 )
6 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: soc/intel/cmn/block/{pcie/rtd3,usb4}: Use helper functions for _DSD ......................................................................
BUG=b:259716145 TEST=Verified SSDT on google/rex.
Signed-off-by: Kapil Porwal kapilporwal@google.com Change-Id: Ib57dea9b16e4590ca2d75ac1512fdaf773ec50f6 Reviewed-on: https://review.coreboot.org/c/coreboot/+/70065 Reviewed-by: Tarun Tuli taruntuli@google.com Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/pcie/rtd3/device/chip.c M src/soc/intel/common/block/pcie/rtd3/rtd3.c M src/soc/intel/common/block/usb4/pcie.c 3 files changed, 27 insertions(+), 58 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Eric Lai: Looks good to me, approved Tarun Tuli: Looks good to me, approved
diff --git a/src/drivers/pcie/rtd3/device/chip.c b/src/drivers/pcie/rtd3/device/chip.c index 349dffd..88b85f1 100644 --- a/src/drivers/pcie/rtd3/device/chip.c +++ b/src/drivers/pcie/rtd3/device/chip.c @@ -12,15 +12,6 @@ #include "chip.h"
/* - * This UUID and the resulting ACPI Device Property is defined by the - * Power Management for Storage Hardware Devices: - * - * https://docs.microsoft.com/en-us/windows-hardware/design/component-guideline... - */ -#define PCIE_RTD3_STORAGE_UUID "5025030F-842F-4AB4-A561-99A5189762D0" -#define PCIE_RTD3_STORAGE_PROPERTY "StorageD3Enable" - -/* * Writes the ACPI power resources for a PCI device so it can enter D3Cold. * * If the device is a storage class, then the StorageD3Enable _DSD will @@ -81,7 +72,6 @@ */ static void pcie_rtd3_device_acpi_fill_ssdt(const struct device *dev) { - struct acpi_dp *dsd, *pkg; const struct drivers_pcie_rtd3_device_config *config = config_of(dev); /* Copy the GPIOs to avoid discards 'const' qualifier error */ struct acpi_gpio reset_gpio = config->reset_gpio; @@ -114,11 +104,7 @@
/* Storage devices won't enter D3 without this property */ if ((dev->class >> 16) == PCI_BASE_CLASS_STORAGE) { - dsd = acpi_dp_new_table("_DSD"); - pkg = acpi_dp_new_table(PCIE_RTD3_STORAGE_UUID); - acpi_dp_add_integer(pkg, PCIE_RTD3_STORAGE_PROPERTY, 1); - acpi_dp_add_package(dsd, pkg); - acpi_dp_write(dsd); + acpi_device_add_storage_d3_enable(NULL);
printk(BIOS_INFO, "%s.%s: Added StorageD3Enable property\n", scope, name); } diff --git a/src/soc/intel/common/block/pcie/rtd3/rtd3.c b/src/soc/intel/common/block/pcie/rtd3/rtd3.c index 2c60eff..f9b587d 100644 --- a/src/soc/intel/common/block/pcie/rtd3/rtd3.c +++ b/src/soc/intel/common/block/pcie/rtd3/rtd3.c @@ -13,25 +13,6 @@ #include <soc/iomap.h> #include "chip.h"
-/* - * The "ExternalFacingPort" and "HotPlugSupportInD3" properties are defined at - * https://docs.microsoft.com/en-us/windows-hardware/drivers/pci/dsd-for-pcie-r... - */ -#define PCIE_EXTERNAL_PORT_UUID "EFCC06CC-73AC-4BC3-BFF0-76143807C389" -#define PCIE_EXTERNAL_PORT_PROPERTY "ExternalFacingPort" - -#define PCIE_HOTPLUG_IN_D3_UUID "6211E2C0-58A3-4AF3-90E1-927A4E0C55A4" -#define PCIE_HOTPLUG_IN_D3_PROPERTY "HotPlugSupportInD3" - -/* - * This UUID and the resulting ACPI Device Property is defined by the - * Power Management for Storage Hardware Devices: - * - * https://docs.microsoft.com/en-us/windows-hardware/design/component-guideline... - */ -#define PCIE_RTD3_STORAGE_UUID "5025030F-842F-4AB4-A561-99A5189762D0" -#define PCIE_RTD3_STORAGE_PROPERTY "StorageD3Enable" - /* PCIe Root Port registers for link status and L23 control. */ #define PCH_PCIE_CFG_LSTS 0x52 /* Link Status Register */ #define PCH_PCIE_CFG_SPR 0xe0 /* Scratchpad */ @@ -367,7 +348,7 @@ FIELDLIST_NAMESTR(ACPI_REG_PCI_L23_RDY_DETECT, 1), }; int pcie_rp; - struct acpi_dp *dsd, *pkg; + struct acpi_dp *dsd;
if (!is_dev_enabled(parent)) { printk(BIOS_ERR, "%s: root port not enabled\n", __func__); @@ -474,16 +455,11 @@
/* Indicate to the OS that device supports hotplug in D3. */ dsd = acpi_dp_new_table("_DSD"); - pkg = acpi_dp_new_table(PCIE_HOTPLUG_IN_D3_UUID); - acpi_dp_add_integer(pkg, PCIE_HOTPLUG_IN_D3_PROPERTY, 1); - acpi_dp_add_package(dsd, pkg); + acpi_device_add_hotplug_support_in_d3(dsd);
/* Indicate to the OS if the device provides an External facing port. */ - if (config->add_acpi_external_facing_port) { - pkg = acpi_dp_new_table(PCIE_EXTERNAL_PORT_UUID); - acpi_dp_add_integer(pkg, PCIE_EXTERNAL_PORT_PROPERTY, 1); - acpi_dp_add_package(dsd, pkg); - } + if (config->add_acpi_external_facing_port) + acpi_device_add_external_facing_port(dsd);
/* Indicate to the OS if the device has DMA property. */ if (config->add_acpi_dma_property) @@ -502,11 +478,7 @@ acpigen_write_STA(ACPI_STATUS_DEVICE_ALL_ON); acpigen_write_name_integer("_S0W", ACPI_DEVICE_SLEEP_D3_COLD);
acpigen_pop_len(); /* Device */
diff --git a/src/soc/intel/common/block/usb4/pcie.c b/src/soc/intel/common/block/usb4/pcie.c index 85292e2..0139647 100644 --- a/src/soc/intel/common/block/usb4/pcie.c +++ b/src/soc/intel/common/block/usb4/pcie.c @@ -9,15 +9,12 @@
#include "chip.h"
-#define PCI_HOTPLUG_IN_D3_UUID "6211E2C0-58A3-4AF3-90E1-927A4E0C55A4" -#define PCI_EXTERNAL_PORT_UUID "EFCC06CC-73AC-4BC3-BFF0-76143807C389" - #if CONFIG(HAVE_ACPI_TABLES) static void usb4_pcie_acpi_fill_ssdt(const struct device *dev) { const struct soc_intel_common_block_usb4_config *config; const struct device *parent; - struct acpi_dp *dsd, *pkg; + struct acpi_dp *dsd; const char *usb4_path; int port_id;
@@ -56,15 +53,11 @@ acpi_dp_add_integer(dsd, "usb4-port-number", port_id);
/* Indicate that device supports hotplug in D3. */ - pkg = acpi_dp_new_table(PCI_HOTPLUG_IN_D3_UUID); - acpi_dp_add_integer(pkg, "HotPlugSupportInD3", 1); - acpi_dp_add_package(dsd, pkg); + acpi_device_add_hotplug_support_in_d3(dsd);
/* Indicate that port is external. */ - pkg = acpi_dp_new_table(PCI_EXTERNAL_PORT_UUID); - acpi_dp_add_integer(pkg, "ExternalFacingPort", 1); + acpi_device_add_external_facing_port(dsd);
- acpi_dp_add_package(dsd, pkg); acpi_dp_write(dsd);
acpigen_pop_len(); /* Scope */
