Nico Huber has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40230 )
Change subject: sb/intel/bd82x6x: Drop PCI resource reg override ......................................................................
Assignment of PCI resource registers is up to the allocator. Therefore, drop override of the PCI resource register.
Change-Id: I184a263c81aa8a434fcd153406b73058914cb2f9 Signed-off-by: Felix Singer felix.singer@secunet.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/40230 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph siro@das-labor.org --- M src/southbridge/intel/bd82x6x/sata.c 1 file changed, 1 insertion(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved
diff --git a/src/southbridge/intel/bd82x6x/sata.c b/src/southbridge/intel/bd82x6x/sata.c index 310d1a2..2693e2b 100644 --- a/src/southbridge/intel/bd82x6x/sata.c +++ b/src/southbridge/intel/bd82x6x/sata.c @@ -114,10 +114,7 @@ /* IDE */ printk(BIOS_DEBUG, "SATA: Controller in plain mode.\n");
- /* No AHCI: clear AHCI base */ - pci_write_config32(dev, 0x24, 0x00000000); - - /* And without AHCI BAR no memory decoding */ + /* Without AHCI BAR no memory decoding */ reg16 = pci_read_config16(dev, PCI_COMMAND); reg16 &= ~PCI_COMMAND_MEMORY; pci_write_config16(dev, PCI_COMMAND, reg16);
