Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/70042 )
Change subject: Revert "sb/intel/i82801gx: Use "sb/intel/common/tco.h" macros" ......................................................................
This reverts commit 9f0e21a4dae864809e9651403ab5bad48e784bee.
It should be allowed for i82801gx/early_init.c to have #include <southbridge/intel/common/pmutil.h>
But there is a conflict:
src/southbridge/intel/common/pmutil.h: #define TCO1_CNT 0x68 src/southbridge/intel/common/tco.h: #define TCO1_CNT 0x08
Followup works resolve the difficulties around the offset 0x60 used for TCO register bank, tree-wide.
Change-Id: I827558a0e0ef1c4d1f866756df51cd1b2abfc7a0 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/southbridge/intel/i82801gx/early_init.c M src/southbridge/intel/i82801gx/i82801gx.h M src/southbridge/intel/i82801gx/lpc.c 3 files changed, 33 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/70042/1
diff --git a/src/southbridge/intel/i82801gx/early_init.c b/src/southbridge/intel/i82801gx/early_init.c index dda5c00..deb3deb 100644 --- a/src/southbridge/intel/i82801gx/early_init.c +++ b/src/southbridge/intel/i82801gx/early_init.c @@ -6,7 +6,6 @@ #include <southbridge/intel/common/gpio.h> #include <southbridge/intel/common/pmbase.h> #include <southbridge/intel/common/rcba.h> -#include <southbridge/intel/common/tco.h>
#include "chip.h" #include "i82801gx.h" @@ -58,6 +57,8 @@ pci_write_config8(d31f0, GPIO_CNTL, GPIO_EN); }
+#define TCO_BASE 0x60 + #if ENV_RAMINIT void i82801gx_early_init(void) { @@ -71,9 +72,9 @@
printk(BIOS_DEBUG, "Disabling Watchdog reboot..."); RCBA32(GCS) = RCBA32(GCS) | (1 << 5); /* No reset */ - write_pmbase16(PMBASE_TCO_OFFSET + TCO1_CNT, TCO_TMR_HLT); - write_pmbase16(PMBASE_TCO_OFFSET + TCO1_STS, TCO1_TIMEOUT); - write_pmbase16(PMBASE_TCO_OFFSET + TCO2_STS, SECOND_TO_STS); + write_pmbase16(TCO_BASE + 0x8, (1 << 11)); /* halt timer */ + write_pmbase16(TCO_BASE + 0x4, (1 << 3)); /* clear timeout */ + write_pmbase16(TCO_BASE + 0x6, (1 << 1)); /* clear 2nd timeout */ printk(BIOS_DEBUG, " done.\n");
/* program secondary mlt XXX byte? */ diff --git a/src/southbridge/intel/i82801gx/i82801gx.h b/src/southbridge/intel/i82801gx/i82801gx.h index 0625db0..ee34f74 100644 --- a/src/southbridge/intel/i82801gx/i82801gx.h +++ b/src/southbridge/intel/i82801gx/i82801gx.h @@ -323,6 +323,7 @@ #define DEVACT_STS 0x44 #define SS_CNT 0x50 #define C3_RES 0x54 +#define TCO1_CNT 0x68
#endif /* __ACPI__ */ #endif /* SOUTHBRIDGE_INTEL_I82801GX_I82801GX_H */ diff --git a/src/southbridge/intel/i82801gx/lpc.c b/src/southbridge/intel/i82801gx/lpc.c index f8a2dac8..fd0a203 100644 --- a/src/southbridge/intel/i82801gx/lpc.c +++ b/src/southbridge/intel/i82801gx/lpc.c @@ -20,7 +20,6 @@ #include <southbridge/intel/common/hpet.h> #include <southbridge/intel/common/pmbase.h> #include <southbridge/intel/common/spi.h> -#include <southbridge/intel/common/tco.h>
#include "chip.h" #include "i82801gx.h" @@ -428,9 +427,9 @@ pci_or_config16(dev, GEN_PMCON_1, 1 << 4);
/* TCO_Lock */ - tco1_cnt = read_pmbase16(PMBASE_TCO_OFFSET + TCO1_CNT); + tco1_cnt = inw(DEFAULT_PMBASE + 0x60 + TCO1_CNT); tco1_cnt |= (1 << 12); /* TCO lock */ - write_pmbase16(PMBASE_TCO_OFFSET + TCO1_CNT, tco1_cnt); + outw(tco1_cnt, DEFAULT_PMBASE + 0x60 + TCO1_CNT);
/* Indicate finalize step with post code */ post_code(POST_OS_BOOT);
