Attention is currently required from: Patrick Rudolph. Hello Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/55631
Change subject: soc/intel/common/cse: Add support for sending CSE End-of-Post message ......................................................................
The CSE expects the boot firmware to send it an End-of-Post message before loading the OS. This is a security feature, and is done to ensure that the CSE will no longer perform certain sensitive commands that are not intended to be exposed to the OS.
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: I6f667905f759cc2337daca4cc6e09694e68ab7e8 --- M src/soc/intel/common/block/cse/Kconfig M src/soc/intel/common/block/cse/cse.c M src/soc/intel/common/block/include/intelblocks/cse.h 3 files changed, 112 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/55631/2
