Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8389
commit a6d92cb224a8f7b47f9b183ebc757baa71ddffa7 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Sat Feb 7 12:27:27 2015 +0200
AMD cimx/sb800: Fix PCI-to-PCI bridge 0:14.4 configuration [NOTFORMERGE]
Now that PCI subsystem properly configures PCI bridges that are marked disabled, fix devicetree entries for the boards that do not implement PCI slots or integrated PCI devices.
Change-Id: Icef85af051567a3da0ec429469fb3ecaccb83a48 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/mainboard/asrock/e350m1/devicetree.cb | 2 +- src/mainboard/gizmosphere/gizmo/devicetree.cb | 2 +- src/mainboard/pcengines/apu1/devicetree.cb | 2 +- src/southbridge/amd/cimx/sb800/late.c | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/src/mainboard/asrock/e350m1/devicetree.cb b/src/mainboard/asrock/e350m1/devicetree.cb index 0690664..7f44869 100644 --- a/src/mainboard/asrock/e350m1/devicetree.cb +++ b/src/mainboard/asrock/e350m1/devicetree.cb @@ -94,7 +94,7 @@ chip northbridge/amd/agesa/family14/root_complex device pnp 2e.f off end # GPIO_PP_OD end end #LPC - device pci 14.4 on end # PCIB 0x4384, NOTE: PCI interface pins shared with GPIO {GPIO 35:0} + device pci 14.4 off end # PCIB 0x4384 device pci 14.5 on end # USB 2 device pci 15.0 on end # PCIe PortA device pci 15.1 on end # PCIe PortB: NIC diff --git a/src/mainboard/gizmosphere/gizmo/devicetree.cb b/src/mainboard/gizmosphere/gizmo/devicetree.cb index 8cd4cd3..baa10b3 100644 --- a/src/mainboard/gizmosphere/gizmo/devicetree.cb +++ b/src/mainboard/gizmosphere/gizmo/devicetree.cb @@ -48,7 +48,7 @@ chip northbridge/amd/agesa/family14/root_complex device pci 14.1 on end # IDE 0x439c device pci 14.2 on end # HDA 0x4383 device pci 14.3 on end # LPC 0x439d - device pci 14.4 on end # PCIB 0x4384, NOTE: this device must always be enabled or removed + device pci 14.4 off end # PCIB 0x4384 device pci 14.5 off end # USB 2 device pci 15.0 on end # PCIe PortA # PCIe x1 to high speed edge connector device pci 15.1 on end # PCIe PortB # PCIe x1 to high speed edge connector diff --git a/src/mainboard/pcengines/apu1/devicetree.cb b/src/mainboard/pcengines/apu1/devicetree.cb index 4209ba6..3c0b795 100644 --- a/src/mainboard/pcengines/apu1/devicetree.cb +++ b/src/mainboard/pcengines/apu1/devicetree.cb @@ -74,7 +74,7 @@ chip northbridge/amd/agesa/family14/root_complex device pnp 2e.e off end end end #LPC - device pci 14.4 on end # PCIB 0x4384 + device pci 14.4 off end # PCIB 0x4384 device pci 14.5 off end # OHCI FS/LS USB #device pci 14.6 off end # Hudson-E1 GbE MAC: Broadcom BCM5785 (14E4:1699) device pci 15.0 on end # PCIe PortA diff --git a/src/southbridge/amd/cimx/sb800/late.c b/src/southbridge/amd/cimx/sb800/late.c index ccb33b9..510bf23 100644 --- a/src/southbridge/amd/cimx/sb800/late.c +++ b/src/southbridge/amd/cimx/sb800/late.c @@ -400,7 +400,7 @@ static void sb800_enable(device_t dev) * 'PCIDisable' set to 1 to disable P2P bridge and enable PCI interface pins * to function as GPIO {GPIO 35:0}. */ - if (!IS_ENABLED(CONFIG_BOARD_PCENGINES_APU1) && dev->enabled) + if (dev->enabled) RWMEM(ACPI_MMIO_BASE + PMIO_BASE + SB_PMIOA_REGEA, AccWidthUint8, ~BIT0, 0); else RWMEM(ACPI_MMIO_BASE + PMIO_BASE + SB_PMIOA_REGEA, AccWidthUint8, ~BIT0, BIT0);
