Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52588 )
Change subject: soc/intel/common: Add virtual wire mapping entries to GPIO communities ......................................................................
Some SoCs may define virtual wire entries for certain GPIOs. This patch allows SoC code to provide the mappings from GPIO pads to virtual wire indexes and bits when they are provided. Also a function `gpio_get_vw_info` is added to return this information.
Change-Id: I87adf0ca06cb5b7969bb2c258d6daebd44bb9748 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/52588 Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/common/block/gpio/gpio.c M src/soc/intel/common/block/include/intelblocks/gpio.h 2 files changed, 43 insertions(+), 0 deletions(-)
diff --git a/src/soc/intel/common/block/gpio/gpio.c b/src/soc/intel/common/block/gpio/gpio.c index 4398c9f..db76545 100644 --- a/src/soc/intel/common/block/gpio/gpio.c +++ b/src/soc/intel/common/block/gpio/gpio.c @@ -763,3 +763,27 @@
BOOT_STATE_INIT_ENTRY(BS_OS_RESUME, BS_ON_EXIT, snapshot_cleanup, NULL); BOOT_STATE_INIT_ENTRY(BS_PAYLOAD_LOAD, BS_ON_EXIT, snapshot_cleanup, NULL); + +bool gpio_get_vw_info(gpio_t pad, unsigned int *vw_index, unsigned int *vw_bit) +{ + const struct pad_community *comm; + unsigned int offset = 0; + size_t i; + + comm = gpio_get_community(pad); + for (i = 0; i < comm->num_vw_entries; i++) { + if (pad >= comm->vw_entries[i].first_pad && pad <= comm->vw_entries[i].last_pad) + break; + + offset += 1 + comm->vw_entries[i].last_pad - comm->vw_entries[i].first_pad; + } + + if (i == comm->num_vw_entries) + return false; + + offset += pad - comm->vw_entries[i].first_pad; + *vw_index = comm->vw_base + offset / 8; + *vw_bit = offset % 8; + + return true; +} diff --git a/src/soc/intel/common/block/include/intelblocks/gpio.h b/src/soc/intel/common/block/include/intelblocks/gpio.h index a7419dc..eab2573 100644 --- a/src/soc/intel/common/block/include/intelblocks/gpio.h +++ b/src/soc/intel/common/block/include/intelblocks/gpio.h @@ -96,6 +96,12 @@ int acpi_pad_base; };
+/* A range of consecutive virtual-wire entries in a community */ +struct vw_entries { + gpio_t first_pad; + gpio_t last_pad; +}; + /* This structure will be used to describe a community or each group within a * community when multiple groups exist inside a community */ @@ -123,6 +129,13 @@ size_t num_reset_vals; const struct pad_group *groups; size_t num_groups; + unsigned int vw_base; + /* + * Note: The entries must be in the same order here as the order in + * which they map to VW indexes (beginning with VW base) + */ + const struct vw_entries *vw_entries; + size_t num_vw_entries; };
/* @@ -237,5 +250,11 @@
size_t gpio_get_index_in_group(gpio_t pad);
+/* + * Returns true and stuffs out params for virtual-wire index and bit position + * for the given GPIO, otherwise false if there is no VW index for the pad. + */ +bool gpio_get_vw_info(gpio_t pad, unsigned int *vw_index, unsigned int *vw_bit); + #endif #endif /* _SOC_INTELBLOCKS_GPIO_H_ */
