Attention is currently required from: Nico Huber, Maximilian Brune, Arthur Heymans.
Hello build bot (Jenkins), Nico Huber, Julius Werner, Angel Pons,
https://review.coreboot.org/c/coreboot/+/68160
Change subject: util/cbfstool: Add a new mechanism to provide a memory map ......................................................................
This replaces the mechanism with --ext-win-base --ext-win-size with a more generic mechanism where cbfstool can be provided with an arbitrary memory map.
This will be useful for AMD platforms with flash sizes larger than 16M where only the lower 16M half gets memory mapped below 4G. Also on Intel system the IFD allows for a memory map where the "top of flash" != "below 4G". This is for instance the case by default on Intel APL.
TEST: google/brya build for chromeos which used --ext-win-base remains the same after this change with BUILD_TIMELESS=1.
Change-Id: I38ab4c369704497f711e14ecda3ff3a8cdc0d089 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/common/block/fast_spi/Makefile.inc M util/cbfstool/cbfstool.c 2 files changed, 147 insertions(+), 77 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/60/68160/7
