Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78802?usp=email )
Change subject: soc/intel/cmn/gfx: Join MBUS while FSP-S performs GFX init ......................................................................
This patch calls into the function to join the MBUS if the GFX PEIM module inside the FSP binary is taking care of graphics initialization based on the RUN_FSP_GOP config option. The FW skips joining the MBUS in case of a non-FSP solution and/or SOC_INTEL_GFX_MBUS_JOIN config is not enabled.
BUG=b:284799726 TEST=MBUS joining is only applicable for google/rex while using GFX PEIM.
Change-Id: I50d719a286722f5aafbad48ab4ca60500c836dd6 Signed-off-by: Subrata Banik subratabanik@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/78802 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nick Vaccaro nvaccaro@google.com --- M src/soc/intel/common/block/graphics/graphics.c 1 file changed, 32 insertions(+), 21 deletions(-)
Approvals: Nick Vaccaro: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/soc/intel/common/block/graphics/graphics.c b/src/soc/intel/common/block/graphics/graphics.c index e744ca7..9b780da 100644 --- a/src/soc/intel/common/block/graphics/graphics.c +++ b/src/soc/intel/common/block/graphics/graphics.c @@ -280,31 +280,42 @@ } }
+static void graphics_join_mbus(void) +{ + enum display_type type = get_external_display_status(); + uint32_t hashing_mode = 0; /* 2x2 */ + if (type == INTERNAL_DISPLAY_ONLY) { + hashing_mode = GFX_MBUS_HASHING_MODE; /* 1x4 */ + /* Only eDP pipes is joining the MBUS */ + graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_A), PIPE_A, GFX_MBUS_JOIN | hashing_mode); + } else if (type == DUAL_DISPLAY) { + /* All pipes are joining the MBUS */ + graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_A), PIPE_A, GFX_MBUS_JOIN | hashing_mode); + graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_B), PIPE_B, GFX_MBUS_JOIN | hashing_mode); + graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_C), PIPE_C, GFX_MBUS_JOIN | hashing_mode); +#if CONFIG(INTEL_GMA_VERSION_2) + graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_D), PIPE_D, GFX_MBUS_JOIN | hashing_mode); +#endif + } else { + /* No pipe joins the MBUS */ + graphics_gtt_rmw(GFX_MBUS_CTL, GFX_MBUS_JOIN_PIPE_SEL, + GFX_MBUS_JOIN | hashing_mode); + } +} + static void graphics_dev_final(struct device *dev) { pci_dev_request_bus_master(dev);
- if (CONFIG(SOC_INTEL_GFX_MBUS_JOIN)) { - enum display_type type = get_external_display_status(); - uint32_t hashing_mode = 0; /* 2x2 */ - if (type == INTERNAL_DISPLAY_ONLY) { - hashing_mode = GFX_MBUS_HASHING_MODE; /* 1x4 */ - /* Only eDP pipes is joining the MBUS */ - graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_A), PIPE_A, GFX_MBUS_JOIN | hashing_mode); - } else if (type == DUAL_DISPLAY) { - /* All pipes are joining the MBUS */ - graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_A), PIPE_A, GFX_MBUS_JOIN | hashing_mode); - graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_B), PIPE_B, GFX_MBUS_JOIN | hashing_mode); - graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_C), PIPE_C, GFX_MBUS_JOIN | hashing_mode); -#if CONFIG(INTEL_GMA_VERSION_2) - graphics_gtt_rmw(GFX_MBUS_SEL(PIPE_D), PIPE_D, GFX_MBUS_JOIN | hashing_mode); -#endif - } else { - /* No pipe joins the MBUS */ - graphics_gtt_rmw(GFX_MBUS_CTL, GFX_MBUS_JOIN_PIPE_SEL, - GFX_MBUS_JOIN | hashing_mode); - } - } + /* + * Call function to join the MBUS if GFX PEIM module inside FSP + * binary is taking care of graphics initialization based on + * RUN_FSP_GOP config option. + * + * Skip FW joining the MBUS in case of non-FSP solution. + */ + if (CONFIG(RUN_FSP_GOP) && CONFIG(SOC_INTEL_GFX_MBUS_JOIN) && display_init_required()) + graphics_join_mbus(); }
const struct device_operations graphics_ops = {
