Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14124
commit 6b2d7a2ca1a9e7976fa9d2ef5982ce6f96423171 Author: Jimmy Huang jimmy.huang@mediatek.com Date: Sat Mar 5 10:25:05 2016 +0800
mediatek/mt8173: Remove bl31 board parameters passing mechanism
As the DA9212 and MT6311 external buck can be controlled by hardware since rev-5 board, we don't need to pass any board specific parameter to ARM TF.
BRANCH=none BUG=none TEST=build pass
Change-Id: I43eebe25ab14d3dd84e8bb4286e2bb55c8c3c063 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 9c4dfe61c69042e464b384e2e0edbc55eda23a74 Original-Change-Id: I541357fee6afb1ff2d771bcb073f7c9a9db52f00 Original-Signed-off-by: Jimmy Huang jimmy.huang@mediatek.com Original-Reviewed-on: https://chromium-review.googlesource.com/332344 Original-Commit-Ready: Yidi Lin yidi.lin@mediatek.com Original-Tested-by: Yidi Lin yidi.lin@mediatek.com Original-Reviewed-by: Julius Werner jwerner@chromium.org --- src/soc/mediatek/mt8173/Makefile.inc | 3 +-- src/soc/mediatek/mt8173/bl31_plat_params.c | 11 +--------- .../mediatek/mt8173/include/soc/bl31_plat_params.h | 24 ---------------------- 3 files changed, 2 insertions(+), 36 deletions(-)
diff --git a/src/soc/mediatek/mt8173/Makefile.inc b/src/soc/mediatek/mt8173/Makefile.inc index 217cbc3..82d74e3 100644 --- a/src/soc/mediatek/mt8173/Makefile.inc +++ b/src/soc/mediatek/mt8173/Makefile.inc @@ -77,8 +77,7 @@ ramstage-y += usb.c
ramstage-$(CONFIG_ARM64_USE_ARM_TRUSTED_FIRMWARE) += bl31_plat_params.c
-BL31_MAKEARGS += PLAT=mt8173 MEDIATEK_MEM_CONFIG=SRAM_192K MEDIATEK_DA9212=1 \ - MEDIATEK_MT6311=1 +BL31_MAKEARGS += PLAT=mt8173
diff --git a/src/soc/mediatek/mt8173/bl31_plat_params.c b/src/soc/mediatek/mt8173/bl31_plat_params.c index 025c202..fc211ef 100644 --- a/src/soc/mediatek/mt8173/bl31_plat_params.c +++ b/src/soc/mediatek/mt8173/bl31_plat_params.c @@ -14,17 +14,8 @@ */ #include <arm_tf.h> #include <assert.h> -#include <soc/bl31_plat_params.h> - -static struct bl31_plat_param *plat_params; - -void register_bl31_param(struct bl31_plat_param *param) -{ - param->next = (void *)plat_params; - plat_params = param; -}
void *soc_get_bl31_plat_params(bl31_params_t *bl31_params) { - return (void *)plat_params; + return (void *)NULL; } diff --git a/src/soc/mediatek/mt8173/include/soc/bl31_plat_params.h b/src/soc/mediatek/mt8173/include/soc/bl31_plat_params.h deleted file mode 100644 index c1ea885..0000000 --- a/src/soc/mediatek/mt8173/include/soc/bl31_plat_params.h +++ /dev/null @@ -1,24 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright 2015 MediaTek Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ -#ifndef __BL31_PLAT_PARAMS_H__ -#define __BL31_PLAT_PARAMS_H__ - -#if IS_ENABLED(CONFIG_ARM64_USE_ARM_TRUSTED_FIRMWARE) -#include <arm-trusted-firmware/plat/mediatek/mt8173/include/plat_params.h> - -void register_bl31_param(struct bl31_plat_param *param); -#endif - -#endif /* __BL31_PLAT_PARAMS_H__ */
