Attention is currently required from: Intel coreboot Reviewers, Julius Werner, Karthik Ramasubramanian.
Hello Intel coreboot Reviewers, Julius Werner, Karthik Ramasubramanian, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/86336?usp=email
Change subject: soc/intel/cmn/pmc: Add support for early power off ......................................................................
This commit adds support for early power off on Intel platforms alongwith existing PMC based implementation to support power off at later stage (like ramsatge).
A new function, `platform_do_early_poweroff`, is added to the pmclib to handle platform-specific early power off procedures. This function is called before memory initialization (in romstage or earlier).
A weak default implementation is provided which prints an error message and halts the system if EC_GOOGLE_CHROMEEC Kconfig not present. Otherwise call into `google_chromeec_do_early_poweroff` to power off the platform.
BUG=b:339673254 TEST=Able to build and boot google/brox.
Change-Id: I39f516640b3f75ab4c6a09826922289c0533f79b Signed-off-by: Subrata Banik subratabanik@google.com --- M src/soc/intel/common/block/include/intelblocks/pmclib.h M src/soc/intel/common/block/pmc/pmclib.c 2 files changed, 39 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/86336/2
