Jacob Garber has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/33963
Change subject: sb/intel/common: Use correct bitwise operator ......................................................................
Like the line above it, this should be & instead of | (otherwise it will always incorrectly return true).
Change-Id: I5208b523c815d15d7263594f06ccfacd8a9510b1 Signed-off-by: Jacob Garber jgarber1@ualberta.ca Found-by: Coverity CID 1402092 --- M src/southbridge/intel/common/spi.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/33963/1
diff --git a/src/southbridge/intel/common/spi.c b/src/southbridge/intel/common/spi.c index e8c8f01..e9e66dc 100644 --- a/src/southbridge/intel/common/spi.c +++ b/src/southbridge/intel/common/spi.c @@ -338,7 +338,7 @@ if (CONFIG(SOUTHBRIDGE_INTEL_I82801GX)) { return !!(readw_(&cntlr->ich7_spi->spis) & HSFS_FLOCKDN); } else { - return !!(readw_(&cntlr->ich9_spi->hsfs) | HSFS_FLOCKDN); + return !!(readw_(&cntlr->ich9_spi->hsfs) & HSFS_FLOCKDN); } }
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33963 )
Patch Set 1: Code-Review+2
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33963 )
Patch Set 1: Code-Review+1
Maybe improve commit message with possible security implications.
It was not wrong for long, two weeks, CB:33388.
Jacob Garber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33963 )
Patch Set 1:
Hmmm, I don't really know enough to know what those would be.
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33963 )
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33963 )
spi_locked() is only used locally to decide which path to take (reprogram opcodes on the fly or live with the preset, locked opcodes; IMHO, that we have two paths is a bug anyway). I don't see any security problems, though even that is worth to mention, e.g.
spi_locked() is only used internally to decide which opcodes will be used to talk the flash. If it is falsely reported as locked, worst case should be a denial of service (unless there are more bugs).
Hello Kyösti Mälkki, HAOUAS Elyes, Arthur Heymans, Paul Menzel, David Hendricks, build bot (Jenkins), Nico Huber, Patrick Georgi, Martin Roth,
Like the line above it, this should be & instead of | (otherwise it will always incorrectly return true). spi_locked() is only used internally to decide which opcodes will be used to talk to the flash, and if it is falsely reported as locked, the worst case should be a denial of service (unless there are more bugs).
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/33963/2
Nico Huber has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/33963 )
Change-Id: I5208b523c815d15d7263594f06ccfacd8a9510b1 Signed-off-by: Jacob Garber jgarber1@ualberta.ca Found-by: Coverity CID 1402092 Reviewed-on: https://review.coreboot.org/c/coreboot/+/33963 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: HAOUAS Elyes ehaouas@noos.fr Reviewed-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net Reviewed-by: Nico Huber nico.h@gmx.de --- M src/southbridge/intel/common/spi.c 1 file changed, 1 insertion(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Kyösti Mälkki: Looks good to me, but someone else must approve Nico Huber: Looks good to me, approved Paul Menzel: Looks good to me, but someone else must approve HAOUAS Elyes: Looks good to me, approved
