Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/33936
Change subject: lib/romstage_stack.c: Remove unused function ......................................................................
Change-Id: I1e66ff3fe7462dfeae2a7ce7e3a8083cf90a15f9 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/include/program_loading.h M src/lib/romstage_stack.c 2 files changed, 0 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/33936/1
diff --git a/src/include/program_loading.h b/src/include/program_loading.h index 7be59e2..5644f1b 100644 --- a/src/include/program_loading.h +++ b/src/include/program_loading.h @@ -176,7 +176,6 @@ /* Determine where stack for ramstage loader is located. */ enum { ROMSTAGE_STACK_CBMEM, ROMSTAGE_STACK_LOW_MEM }; uintptr_t romstage_ram_stack_base(size_t size, int src); -uintptr_t romstage_ram_stack_top(void); uintptr_t romstage_ram_stack_bottom(void);
/* Backup OS memory to CBMEM_ID_RESUME on ACPI S3 resume path, diff --git a/src/lib/romstage_stack.c b/src/lib/romstage_stack.c index ed6f09b..d085f75 100644 --- a/src/lib/romstage_stack.c +++ b/src/lib/romstage_stack.c @@ -38,14 +38,3 @@ return romstage_ram_stack_base(ROMSTAGE_RAM_STACK_SIZE, ROMSTAGE_STACK_CBMEM); } - -uintptr_t romstage_ram_stack_top(void) -{ - uintptr_t stack_top = romstage_ram_stack_base(ROMSTAGE_RAM_STACK_SIZE, - ROMSTAGE_STACK_CBMEM); - stack_top += ROMSTAGE_RAM_STACK_SIZE; - - /* Make it aligned to a 8-byte boundary. */ - stack_top = ALIGN_DOWN(stack_top, 8); - return stack_top; -}
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33936 )
Patch Set 1: Code-Review+1
Hello Kyösti Mälkki, Paul Menzel, build bot (Jenkins),
Change subject: lib/romstage_stack.c: Remove unused functions ......................................................................
ROMSTAGE_STACK_LOW_MEM is unused.
Change-Id: I1e66ff3fe7462dfeae2a7ce7e3a8083cf90a15f9 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/include/program_loading.h M src/lib/romstage_stack.c 2 files changed, 3 insertions(+), 27 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/33936/2
Kyösti Mälkki has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33936 )
Patch Set 2:
Let's just remove _top() and _bottom() now. I have to look into it, but AGESA/binaryPI probably no longer really needs _base().
See CB:15473 why LOW_MEM was introduced. We can push the remaining code under cpu/amd and hope that fam10-15 hits deprecation (lack of RELOCATABLE_RAMSTAGE & POSTCAR).
Kyösti Mälkki has uploaded a new patch set (#3) to the change originally created by Arthur Heymans. ( https://review.coreboot.org/c/coreboot/+/33936 )
Change-Id: I1e66ff3fe7462dfeae2a7ce7e3a8083cf90a15f9 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/include/program_loading.h M src/lib/romstage_stack.c 2 files changed, 0 insertions(+), 18 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/33936/3
Kyösti Mälkki has uploaded a new patch set (#4) to the change originally created by Arthur Heymans. ( https://review.coreboot.org/c/coreboot/+/33936 )
Change-Id: I1e66ff3fe7462dfeae2a7ce7e3a8083cf90a15f9 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/include/program_loading.h M src/lib/romstage_stack.c 2 files changed, 0 insertions(+), 19 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/33936/4
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33936 )
Patch Set 4: Code-Review+2
Kyösti Mälkki has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/33936 )
Change-Id: I1e66ff3fe7462dfeae2a7ce7e3a8083cf90a15f9 Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/33936 Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/include/program_loading.h M src/lib/romstage_stack.c 2 files changed, 0 insertions(+), 19 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
diff --git a/src/include/program_loading.h b/src/include/program_loading.h index 7be59e2..223fc0b 100644 --- a/src/include/program_loading.h +++ b/src/include/program_loading.h @@ -176,8 +176,6 @@ /* Determine where stack for ramstage loader is located. */ enum { ROMSTAGE_STACK_CBMEM, ROMSTAGE_STACK_LOW_MEM }; uintptr_t romstage_ram_stack_base(size_t size, int src); -uintptr_t romstage_ram_stack_top(void); -uintptr_t romstage_ram_stack_bottom(void);
/* Backup OS memory to CBMEM_ID_RESUME on ACPI S3 resume path, * if ramstage overwrites low memory. */ diff --git a/src/lib/romstage_stack.c b/src/lib/romstage_stack.c index ed6f09b..4fe1459 100644 --- a/src/lib/romstage_stack.c +++ b/src/lib/romstage_stack.c @@ -32,20 +32,3 @@ return CONFIG_RAMTOP - size; return 0; } - -uintptr_t romstage_ram_stack_bottom(void) -{ - return romstage_ram_stack_base(ROMSTAGE_RAM_STACK_SIZE, - ROMSTAGE_STACK_CBMEM); -} - -uintptr_t romstage_ram_stack_top(void) -{ - uintptr_t stack_top = romstage_ram_stack_base(ROMSTAGE_RAM_STACK_SIZE, - ROMSTAGE_STACK_CBMEM); - stack_top += ROMSTAGE_RAM_STACK_SIZE; - - /* Make it aligned to a 8-byte boundary. */ - stack_top = ALIGN_DOWN(stack_top, 8); - return stack_top; -}
