Attention is currently required from: Maximilian Brune, Patrick Georgi, Philipp Hug, ron minnich.
Hello Martin L Roth, Maximilian Brune, Patrick Georgi, Philipp Hug,
https://review.coreboot.org/c/coreboot/+/81410?usp=email
Change subject: arch/riscv: add Kconfig variable RISCV_HAS_MENVCFG ......................................................................
Older parts do not have the menvcfg csr. Provide a Kconfig variable, default y, to enable it. Check the variable in the payload code, when coreboot SBI is used, and print out if it is enabled.
Add constants for this new CSR.
Signed-off-by: Ronald G Minnich rminnich@gmail.com
Change-Id: I627dde377708cde2491d4abe625c482d64f7aa87 --- M src/arch/riscv/Kconfig M src/arch/riscv/include/arch/encoding.h M src/arch/riscv/payload.c 3 files changed, 17 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/81410/2
