Elyes Haouas has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69903 )
Change subject: /: Remove unnecessary space in log messages ......................................................................
Change-Id: Ic64625bdaf8c4e9f8a5c1c22cece7f4070012da7 Signed-off-by: Elyes Haouas ehaouas@noos.fr --- M src/arch/x86/pirq_routing.c M src/drivers/intel/gma/intel_ddi.c M src/lib/selfboot.c M src/security/vboot/secdata_tpm.c M src/soc/intel/broadwell/pch/pcie.c M src/soc/samsung/exynos5420/dp_lowlevel.c M src/southbridge/intel/bd82x6x/pch.c M src/southbridge/intel/i82801gx/i82801gx.c M src/southbridge/intel/lynxpoint/pch.c M src/southbridge/intel/lynxpoint/pcie.c 10 files changed, 21 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/69903/1
diff --git a/src/arch/x86/pirq_routing.c b/src/arch/x86/pirq_routing.c index 0da057f..0a1e75d 100644 --- a/src/arch/x86/pirq_routing.c +++ b/src/arch/x86/pirq_routing.c @@ -164,7 +164,7 @@ }
for (i = 0; i < CONFIG_MAX_PIRQ_LINKS; i++) - printk(BIOS_DEBUG, "PIRQ%c: %d\n", i + 'A', pirq[i]); + printk(BIOS_DEBUG, "PIRQ%c: %d\n", i + 'A', pirq[i]);
pirq_assign_irqs(pirq); } diff --git a/src/drivers/intel/gma/intel_ddi.c b/src/drivers/intel/gma/intel_ddi.c index 24bc162..6c6d13e 100644 --- a/src/drivers/intel/gma/intel_ddi.c +++ b/src/drivers/intel/gma/intel_ddi.c @@ -48,7 +48,7 @@ hsw_ddi_translations_fdi : hsw_ddi_translations_dp);
- printk(BIOS_SPEW, "Initializing DDI buffers for port %d in %s mode\n", + printk(BIOS_SPEW, "Initializing DDI buffers for port %d in %s mode\n", port, use_fdi_mode ? "FDI" : "DP");
diff --git a/src/lib/selfboot.c b/src/lib/selfboot.c index 637ad13..e21c493 100644 --- a/src/lib/selfboot.c +++ b/src/lib/selfboot.c @@ -93,7 +93,7 @@ break; } default: - printk(BIOS_INFO, "CBFS: Unknown compression type %d\n", compression); + printk(BIOS_INFO, "CBFS: Unknown compression type %d\n", compression); return 0; } /* Calculate middle after any changes to len. */ diff --git a/src/security/vboot/secdata_tpm.c b/src/security/vboot/secdata_tpm.c index 7885069..844b28d 100644 --- a/src/security/vboot/secdata_tpm.c +++ b/src/security/vboot/secdata_tpm.c @@ -15,7 +15,7 @@ #include <console/console.h>
#define VBDEBUG(format, args...) \ - printk(BIOS_INFO, "%s():%d: " format, __func__, __LINE__, ## args) + printk(BIOS_INFO, "%s():%d: " format, __func__, __LINE__, ## args)
#define RETURN_ON_FAILURE(tpm_cmd) do { \ uint32_t result_; \ diff --git a/src/soc/intel/broadwell/pch/pcie.c b/src/soc/intel/broadwell/pch/pcie.c index b37f256..61d6962 100644 --- a/src/soc/intel/broadwell/pch/pcie.c +++ b/src/soc/intel/broadwell/pch/pcie.c @@ -295,7 +295,7 @@ if (dev->enabled) continue;
- printk(BIOS_DEBUG, "%s: Disabling device\n", dev_path(dev)); + printk(BIOS_DEBUG, "%s: Disabling device\n", dev_path(dev));
/* 8.2 Configuration of PCI Express Root Ports */ pci_or_config32(dev, 0x338, 1 << 26); diff --git a/src/soc/samsung/exynos5420/dp_lowlevel.c b/src/soc/samsung/exynos5420/dp_lowlevel.c index 0cd6483..2d33873 100644 --- a/src/soc/samsung/exynos5420/dp_lowlevel.c +++ b/src/soc/samsung/exynos5420/dp_lowlevel.c @@ -229,7 +229,7 @@ CH2_PD | CH3_PD); break; default: - printk(BIOS_ERR, "DP undefined block number : %d\n", block); + printk(BIOS_ERR, "DP undefined block number : %d\n", block); return -1; }
diff --git a/src/southbridge/intel/bd82x6x/pch.c b/src/southbridge/intel/bd82x6x/pch.c index d24604c..16ffaf5 100644 --- a/src/southbridge/intel/bd82x6x/pch.c +++ b/src/southbridge/intel/bd82x6x/pch.c @@ -327,7 +327,7 @@ }
if (!dev->enabled) { - printk(BIOS_DEBUG, "%s: Disabling device\n", dev_path(dev)); + printk(BIOS_DEBUG, "%s: Disabling device\n", dev_path(dev));
/* * PCIE Power Savings for PantherPoint and CougarPoint/B1+ @@ -408,7 +408,7 @@ return pch_pcie_enable(dev);
/* Ensure memory, io, and bus master are all disabled */ pci_and_config16(dev, PCI_COMMAND, diff --git a/src/southbridge/intel/i82801gx/i82801gx.c b/src/southbridge/intel/i82801gx/i82801gx.c index 6d4e7115..4783099 100644 --- a/src/southbridge/intel/i82801gx/i82801gx.c +++ b/src/southbridge/intel/i82801gx/i82801gx.c @@ -56,7 +56,7 @@ u16 reg16;
/* Ensure memory, io, and bus master are all disabled */ reg16 = pci_read_config16(dev, PCI_COMMAND); diff --git a/src/southbridge/intel/lynxpoint/pch.c b/src/southbridge/intel/lynxpoint/pch.c index 8f7cdb8..f83f3f6 100644 --- a/src/southbridge/intel/lynxpoint/pch.c +++ b/src/southbridge/intel/lynxpoint/pch.c @@ -185,7 +185,7 @@ return;
/* Ensure memory, io, and bus master are all disabled */ pci_and_config16(dev, PCI_COMMAND, diff --git a/src/southbridge/intel/lynxpoint/pcie.c b/src/southbridge/intel/lynxpoint/pcie.c index 24fab3b..2f01560 100644 --- a/src/southbridge/intel/lynxpoint/pcie.c +++ b/src/southbridge/intel/lynxpoint/pcie.c @@ -322,7 +322,7 @@ if (dev->enabled) continue;
