Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14241
commit a0046d91ab2b6d72bd2186f7c8f3890081da62ac Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Mon Apr 4 14:24:23 2016 -0500
sb/amd/sp5100: Add enable_ehci_async_data_cache CMOS option
SP5100 devices are affected by an erratum that can lock up the EHCI ports under certain conditions. Add an optional CMOS option to enable the workaround at the expense of performance.
Change-Id: I305d23dfa50f10a3dcb5c731e8923305c8956dde Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/southbridge/amd/sb700/usb.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/src/southbridge/amd/sb700/usb.c b/src/southbridge/amd/sb700/usb.c index cd7378e..7d82f05 100644 --- a/src/southbridge/amd/sb700/usb.c +++ b/src/southbridge/amd/sb700/usb.c @@ -76,10 +76,16 @@ static void usb_init(struct device *dev)
static void usb_init2(struct device *dev) { - u32 dword; + uint32_t dword; void *usb2_bar0; device_t sm_dev; - u8 rev; + uint8_t rev; + uint8_t ehci_async_data_cache; + uint8_t nvram; + + ehci_async_data_cache = 1; + if (get_option(&nvram, "enable_ehci_async_data_cache") == CB_SUCCESS) + ehci_async_data_cache = !!nvram;
sm_dev = dev_find_slot(0, PCI_DEVFN(0x14, 0)); rev = get_sb700_revision(sm_dev); @@ -174,6 +180,12 @@ static void usb_init2(struct device *dev) dword |= 1 << 8; dword &= ~(1 << 27); /* 6.23 */ } +#if CONFIG_SOUTHBRIDGE_AMD_SUBTYPE_SP5100 + /* SP5100 Erratum 36 */ + dword &= ~(1 << 26); + if (!ehci_async_data_cache) + dword |= 1 << 26; +#endif pci_write_config32(dev, 0x50, dword); printk(BIOS_DEBUG, "rpr 6.23, final dword=%x\n", dword); }
