Matt DeVillier has submitted this change. ( https://review.coreboot.org/c/coreboot/+/77007?usp=email )
Change subject: mb/google/rex/var/karis: Remove SD card and ISH ......................................................................
BUG=b:294155897 TEST=emerge-rex coreboot
Change-Id: I1575ee1d7e4c834ad15f60a3b7d63c041a8d4890 Signed-off-by: Tyler Wang tyler.wang@quanta.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/77007 Reviewed-by: Kapil Porwal kapilporwal@google.com Reviewed-by: Subrata Banik subratabanik@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/rex/Kconfig M src/mainboard/google/rex/variants/karis/gpio.c M src/mainboard/google/rex/variants/karis/overridetree.cb 3 files changed, 10 insertions(+), 46 deletions(-)
Approvals: Subrata Banik: Looks good to me, approved build bot (Jenkins): Verified Kapil Porwal: Looks good to me, approved
diff --git a/src/mainboard/google/rex/Kconfig b/src/mainboard/google/rex/Kconfig index 388030f..ceab29e 100644 --- a/src/mainboard/google/rex/Kconfig +++ b/src/mainboard/google/rex/Kconfig @@ -65,8 +65,6 @@ def_bool n select BOARD_GOOGLE_BASEBOARD_REX select DRIVERS_GENERIC_MAX98357A - select DRIVERS_GENESYSLOGIC_GL9755 - select DRIVERS_INTEL_ISH select DRIVERS_INTEL_SOUNDWIRE select DRIVERS_SOUNDWIRE_CS42L42 select DRIVERS_SOUNDWIRE_MAX98363 diff --git a/src/mainboard/google/rex/variants/karis/gpio.c b/src/mainboard/google/rex/variants/karis/gpio.c index 4602983..8fdbc06 100644 --- a/src/mainboard/google/rex/variants/karis/gpio.c +++ b/src/mainboard/google/rex/variants/karis/gpio.c @@ -26,8 +26,8 @@ PAD_CFG_GPO(GPP_A11, 0, DEEP), /* GPP_A12 : [] ==> EN_UCAM_PWR */ PAD_CFG_GPO(GPP_A12, 0, DEEP), - /* GPP_A13 : [] ==> SD_PE_LS_PRSNT_L */ - PAD_CFG_GPI_LOCK(GPP_A13, NONE, LOCK_CONFIG), + /* GPP_A13 : Not connected */ + PAD_NC(GPP_A13, NONE), /* GPP_A14 : [] ==> WWAN_RF_DISABLE_ODL */ PAD_NC_LOCK(GPP_A14, NONE, LOCK_CONFIG), /* GPP_A15 : [] ==> WWAN_RST_L */ @@ -115,8 +115,8 @@ PAD_NC(GPP_C09, NONE), /* GPP_C10 : net NC is not present in the given design */ PAD_NC(GPP_C10, NONE), - /* GPP_C11 : [] ==> SD_CLKREQ_ODL */ - PAD_CFG_NF(GPP_C11, NONE, DEEP, NF1), + /* GPP_C11 : Not Connected */ + PAD_NC(GPP_C11, NONE), /* GPP_C12 : [] ==> WWAN_CLKREQ_ODL */ PAD_CFG_NF(GPP_C12, NONE, DEEP, NF1), /* GPP_C13 : Not connected */ @@ -142,12 +142,8 @@
/* GPP_D00 : WCAM_MCLK_R */ PAD_CFG_NF(GPP_D00, NONE, DEEP, NF1), - /* GPP_D01 : [] ==> SD_PE_WAKE_ODL */ - PAD_CFG_GPI_LOCK(GPP_D01, NONE, LOCK_CONFIG), - /* GPP_D02 : [] ==> SD_PERST_L */ - PAD_CFG_GPO_LOCK(GPP_D02, 1, LOCK_CONFIG), - /* GPP_D03 : [] ==> EN_PP3300_SD */ - PAD_CFG_GPO_LOCK(GPP_D03, 1, LOCK_CONFIG), + /* GPP_D01 : Not Connected */ + PAD_NC(GPP_D01, NONE), /* GPP_D04 : [] ==> EN_SPKR */ PAD_CFG_GPO(GPP_D04, 1, DEEP), /* GPP_D05 : net NC. Test pad. */ @@ -389,8 +385,8 @@ /* GPP_H09 : [] ==> UART_SOC_TX_DBG_RX_R */ PAD_CFG_NF(GPP_H09, NONE, DEEP, NF1),
- /* GPP_D03 : [] ==> EN_PP3300_SD */ - PAD_CFG_GPO(GPP_D03, 1, DEEP), + /* GPP_D03 : Not Connected */ + PAD_NC(GPP_D03, NONE),
/* GPP_E13 : [] ==> MEM_CH_SEL */ PAD_CFG_GPI(GPP_E13, NONE, DEEP), @@ -411,8 +407,8 @@ PAD_CFG_GPO(GPP_C23, 0, DEEP), /* GPP_E07 : [] ==> WWAN_FCPO_L */ PAD_CFG_GPO(GPP_E07, 1, DEEP), - /* GPP_D02 : [] ==> SD_PERST_L */ - PAD_CFG_GPO(GPP_D02, 1, DEEP), + /* GPP_D02 : Not Connected */ + PAD_NC(GPP_D02, NONE), };
const struct pad_config *variant_gpio_table(size_t *num) diff --git a/src/mainboard/google/rex/variants/karis/overridetree.cb b/src/mainboard/google/rex/variants/karis/overridetree.cb index 080e228..2ffdcb4 100644 --- a/src/mainboard/google/rex/variants/karis/overridetree.cb +++ b/src/mainboard/google/rex/variants/karis/overridetree.cb @@ -17,10 +17,6 @@ option WFC_USB 0 option WFC_MIPI 1 end - field DB_SD 10 11 - option SD_ABSENT 0 - option SD_GL9755S 1 - end field DB_USB 12 14 option USB_UNKNOWN 0 option USB3_PS8815 1 @@ -50,10 +46,6 @@ option VPU_DIS 0 option VPU_EN 1 end - field ISH 21 - option ISH_DISABLE 0 - option ISH_ENABLE 1 - end end
chip soc/intel/meteorlake @@ -303,13 +295,6 @@ .flags = PCIE_RP_LTR | PCIE_RP_AER, }" end # PCIE10 SSD card - device ref ish on - probe ISH ISH_ENABLE - chip drivers/intel/ish - register "firmware_name" = ""rex_ish.bin"" - device generic 0 on end - end - end device ref tbt_pcie_rp0 on end device ref tbt_pcie_rp2 on end device ref vpu on @@ -736,21 +721,6 @@ end end end #PCIE6 WWAN card - device ref pcie_rp7 on - # Enable SD Card PCIE 7 using clk 2 - register "pcie_rp[PCH_RP(7)]" = "{ - .clk_src = 2, - .clk_req = 2, - .flags = PCIE_RP_HOTPLUG | PCIE_RP_LTR | PCIE_RP_AER, - }" - chip soc/intel/common/block/pcie/rtd3 - register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D03)" - register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D02)" - register "srcclk_pin" = "2" - device generic 0 on end - end - probe DB_SD SD_GL9755S - end device ref gspi0 on probe TOUCHSCREEN TOUCHSCREEN_I2C_SPI end
