John Su has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/86364?usp=email )
Change subject: mb/trulo/var/uldrenite: Support x32 memory configuration ......................................................................
Use the GPP_E13 level to determine whether x32 memory configuration is supported.
BUG=b:379311559 BRANCH=firmware-trulo-15217.771.B TEST=emerge-nissa coreboot chromeos-bootimage
Change-Id: Idd3534bba0379a7bb06f8fbbeb9469e938e5a629 Signed-off-by: John Su john_su@compal.corp-partner.google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/variants/uldrenite/memory.c 2 files changed, 15 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/64/86364/1
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 58b8922..8d09f2e 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -644,6 +644,7 @@ select HAVE_WWAN_POWER_SEQUENCE select DRIVERS_WWAN_FM350GL select SOC_INTEL_COMMON_BLOCK_HDA_VERB + select ENFORCE_MEM_CHANNEL_DISABLE
config BOARD_GOOGLE_VELL select BOARD_GOOGLE_BASEBOARD_BRYA diff --git a/src/mainboard/google/brya/variants/uldrenite/memory.c b/src/mainboard/google/brya/variants/uldrenite/memory.c index 9ade7c2..949164f 100644 --- a/src/mainboard/google/brya/variants/uldrenite/memory.c +++ b/src/mainboard/google/brya/variants/uldrenite/memory.c @@ -3,6 +3,7 @@ #include <baseboard/variants.h> #include <gpio.h> #include <soc/romstage.h> +#include <soc/meminit.h>
static const struct mb_cfg variant_memcfg = { .type = MEM_TYPE_LP5X, @@ -109,3 +110,16 @@ spd_info->topo = MEM_TOPO_MEMORY_DOWN; spd_info->cbfs_index = variant_memory_sku(); } + +uint8_t mb_get_channel_disable_mask(void) +{ + /* + * GPP_E13 High -> One RAM Chip + * GPP_E13 Low -> Two RAM Chip + */ + if (gpio_get(GPP_E13)) { + // Disable all other channels except first two on each controller + return (BIT(2) | BIT(3)); + } + return 0; +}
