Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/82658?usp=email
Change subject: tree: Use Wcalloc-transposed-args command option ......................................................................
GCC-14 documentation says "The first argument to calloc is documented to be number of elements in array, while the second argument is size of each element, so calloc(n, sizeof (int)) is preferred over calloc(sizeof(int), n)."
Change-Id: I77b6f4d2eda487b087ba5665b588999633c33e8d Signed-off-by: Elyes Haouas ehaouas@noos.fr --- M Makefile.mk M src/southbridge/intel/common/rcba_pirq.c 2 files changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/82658/2
