Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38196 )
Change subject: drivers/pc80/rtc: Move CMOS_POST_BANK_x definitions ......................................................................
Change-Id: I8b56df6de7529772b0f1a59002f92c4f31486bf0 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/drivers/pc80/rtc/post.c M src/include/pc80/mc146818rtc.h 2 files changed, 27 insertions(+), 31 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/38196/1
diff --git a/src/drivers/pc80/rtc/post.c b/src/drivers/pc80/rtc/post.c index 38ef241..8a8a762 100644 --- a/src/drivers/pc80/rtc/post.c +++ b/src/drivers/pc80/rtc/post.c @@ -18,6 +18,33 @@ #include <pc80/mc146818rtc.h> #include <smp/spinlock.h>
+#if CONFIG(USE_OPTION_TABLE) +# include "option_table.h" +# define CMOS_POST_OFFSET (CMOS_VSTART_cmos_post_offset >> 3) +#else +# if (CONFIG_CMOS_POST_OFFSET != 0) +# define CMOS_POST_OFFSET CONFIG_CMOS_POST_OFFSET +# else +# error "Must configure CONFIG_CMOS_POST_OFFSET" +# endif + +/* + * 0 = Bank Select Magic + * 1 = Bank 0 POST + * 2 = Bank 1 POST + * 3-6 = BANK 0 Extra log + * 7-10 = BANK 1 Extra log + */ +#define CMOS_POST_BANK_OFFSET (CMOS_POST_OFFSET) +#define CMOS_POST_BANK_0_MAGIC 0x80 +#define CMOS_POST_BANK_0_OFFSET (CMOS_POST_OFFSET + 1) +#define CMOS_POST_BANK_0_EXTRA (CMOS_POST_OFFSET + 3) +#define CMOS_POST_BANK_1_MAGIC 0x81 +#define CMOS_POST_BANK_1_OFFSET (CMOS_POST_OFFSET + 2) +#define CMOS_POST_BANK_1_EXTRA (CMOS_POST_OFFSET + 7) + +#define CMOS_POST_EXTRA_DEV_PATH 0x01 + DECLARE_SPIN_LOCK(cmos_post_lock)
int cmos_post_previous(u8 *code, u32 *extra) diff --git a/src/include/pc80/mc146818rtc.h b/src/include/pc80/mc146818rtc.h index 92d8f2f..8cc2ed4 100644 --- a/src/include/pc80/mc146818rtc.h +++ b/src/include/pc80/mc146818rtc.h @@ -181,37 +181,6 @@ int cmos_checksum_valid(int range_start, int range_end, int cks_loc); void cmos_set_checksum(int range_start, int range_end, int cks_loc);
-#if CONFIG(CMOS_POST) -#if CONFIG(USE_OPTION_TABLE) -# include "option_table.h" -# define CMOS_POST_OFFSET (CMOS_VSTART_cmos_post_offset >> 3) -#else -# if (CONFIG_CMOS_POST_OFFSET != 0) -# define CMOS_POST_OFFSET CONFIG_CMOS_POST_OFFSET -# else -# error "Must configure CONFIG_CMOS_POST_OFFSET" -# endif -#endif - -/* - * 0 = Bank Select Magic - * 1 = Bank 0 POST - * 2 = Bank 1 POST - * 3-6 = BANK 0 Extra log - * 7-10 = BANK 1 Extra log - */ -#define CMOS_POST_BANK_OFFSET (CMOS_POST_OFFSET) -#define CMOS_POST_BANK_0_MAGIC 0x80 -#define CMOS_POST_BANK_0_OFFSET (CMOS_POST_OFFSET + 1) -#define CMOS_POST_BANK_0_EXTRA (CMOS_POST_OFFSET + 3) -#define CMOS_POST_BANK_1_MAGIC 0x81 -#define CMOS_POST_BANK_1_OFFSET (CMOS_POST_OFFSET + 2) -#define CMOS_POST_BANK_1_EXTRA (CMOS_POST_OFFSET + 7) - -#define CMOS_POST_EXTRA_DEV_PATH 0x01 - -#endif /* CONFIG_CMOS_POST */ - #endif /* CONFIG_ARCH_X86 */
void cmos_post_init(void);
Hello build bot (Jenkins),
Change-Id: I8b56df6de7529772b0f1a59002f92c4f31486bf0 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/drivers/pc80/rtc/post.c M src/include/pc80/mc146818rtc.h 2 files changed, 28 insertions(+), 31 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/38196/2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38196 )
Patch Set 4: Code-Review+2
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38196 )
Patch Set 5: Code-Review+2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38196 )
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38196 )
Change-Id: I8b56df6de7529772b0f1a59002f92c4f31486bf0 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/38196 Reviewed-by: Aaron Durbin adurbin@chromium.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/pc80/rtc/post.c M src/include/pc80/mc146818rtc.h 2 files changed, 28 insertions(+), 31 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved Furquan Shaikh: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/drivers/pc80/rtc/post.c b/src/drivers/pc80/rtc/post.c index 41a664e..f993b96 100644 --- a/src/drivers/pc80/rtc/post.c +++ b/src/drivers/pc80/rtc/post.c @@ -7,6 +7,34 @@ #include <pc80/mc146818rtc.h> #include <smp/spinlock.h>
+#if CONFIG(USE_OPTION_TABLE) +# include "option_table.h" +# define CMOS_POST_OFFSET (CMOS_VSTART_cmos_post_offset >> 3) +#else +# if (CONFIG_CMOS_POST_OFFSET != 0) +# define CMOS_POST_OFFSET CONFIG_CMOS_POST_OFFSET +# else +# error "Must configure CONFIG_CMOS_POST_OFFSET" +# endif +#endif + +/* + * 0 = Bank Select Magic + * 1 = Bank 0 POST + * 2 = Bank 1 POST + * 3-6 = BANK 0 Extra log + * 7-10 = BANK 1 Extra log + */ +#define CMOS_POST_BANK_OFFSET (CMOS_POST_OFFSET) +#define CMOS_POST_BANK_0_MAGIC 0x80 +#define CMOS_POST_BANK_0_OFFSET (CMOS_POST_OFFSET + 1) +#define CMOS_POST_BANK_0_EXTRA (CMOS_POST_OFFSET + 3) +#define CMOS_POST_BANK_1_MAGIC 0x81 +#define CMOS_POST_BANK_1_OFFSET (CMOS_POST_OFFSET + 2) +#define CMOS_POST_BANK_1_EXTRA (CMOS_POST_OFFSET + 7) + +#define CMOS_POST_EXTRA_DEV_PATH 0x01 + DECLARE_SPIN_LOCK(cmos_post_lock)
int cmos_post_previous_boot(u8 *code, u32 *extra) diff --git a/src/include/pc80/mc146818rtc.h b/src/include/pc80/mc146818rtc.h index edaeb1e..353a09b 100644 --- a/src/include/pc80/mc146818rtc.h +++ b/src/include/pc80/mc146818rtc.h @@ -181,37 +181,6 @@ int cmos_checksum_valid(int range_start, int range_end, int cks_loc); void cmos_set_checksum(int range_start, int range_end, int cks_loc);
