Attention is currently required from: Kaiyen Chang. Hello Kaiyen Chang,
https://review.coreboot.org/c/coreboot/+/52029
Change subject: soc/intel/jasperlake: Update CpuRatio settings ......................................................................
An extra reset is observed on JSL platform while the flex ratio in CPU Straps is set to a non-zero value. The root cause is that the config of CpuRatio on JSL is fixed to zero in fsp_param.c. While FSP finds the value of CpuRatio from m_cfg is inconsistent with the value from CPU straps, it will invoke a system reset to apply the value from m_cfg.
This change adds a mechanism to set CpuRatio to allowed maximum processor non-turbo ratio (from CPU straps) when cpu_ratio_override is not set, or overriding CpuRatio with the value of cpu_ratio_override when cpu_ratio_override is set to a non-zero value instead of just fixing CpuRatio to zero.
BUG=b:181588337 BRANCH=None TEST=Boot JSL platform and observe there is no extra reset in meminit.
Change-Id: I20b9d5620b8e394201e82185eb28b67d6702b2d5 --- M src/soc/intel/jasperlake/romstage/fsp_params.c 1 file changed, 12 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/52029/1
diff --git a/src/soc/intel/jasperlake/romstage/fsp_params.c b/src/soc/intel/jasperlake/romstage/fsp_params.c index cd70807..31c9f6f 100644 --- a/src/soc/intel/jasperlake/romstage/fsp_params.c +++ b/src/soc/intel/jasperlake/romstage/fsp_params.c @@ -2,9 +2,11 @@
#include <assert.h> #include <console/console.h> +#include <cpu/x86/msr.h> #include <device/device.h> #include <fsp/util.h> #include <soc/iomap.h> +#include <soc/msr.h> #include <soc/pci_devs.h> #include <soc/romstage.h> #include <soc/soc_chip.h> @@ -29,6 +31,16 @@ m_cfg->SaGv = config->SaGv; m_cfg->RMT = config->RMT;
+ /* CpuRatio Settings */ + if (config->cpu_ratio_override) { + m_cfg->CpuRatio = config->cpu_ratio_override; + } else { + /* Set CpuRatio to match existing MSR value */ + msr_t flex_ratio; + flex_ratio = rdmsr(MSR_FLEX_RATIO); + m_cfg->CpuRatio = (flex_ratio.lo >> 8) & 0xff; + } + /* PCIe root port configuration */ for (i = 0; i < ARRAY_SIZE(config->PcieRpEnable); i++) { if (config->PcieRpEnable[i]) @@ -52,9 +64,6 @@ /* Disable BIOS Guard */ m_cfg->BiosGuard = 0;
- /* Set CPU Ratio */ - m_cfg->CpuRatio = 0; - /* Set debug interface flags */ m_cfg->PcdDebugInterfaceFlags = CONFIG(DRIVERS_UART_8250IO) ? DEBUG_INTERFACE_UART_8250IO : DEBUG_INTERFACE_LPSS_SERIAL_IO;
