Lijian Zhao has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/32672
Change subject: soc/intel/cannonlake: Fix pcie clock number ......................................................................
Cannonlake PCH LP have total 6 pcie clocks and Cannonlake PCH H have total 16 pcie clocks. It is different with pcie root port numbers.
BUG=CID 1381814 TEST=Build and boot up fine on sarien platform.
Signed-off-by: Lijian Zhao lijian.zhao@intel.com Change-Id: I909b5b584c596e6fe878ffe24d9cabc53c4576ed --- M src/soc/intel/cannonlake/Kconfig M src/soc/intel/cannonlake/chip.h 2 files changed, 7 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/72/32672/1
diff --git a/src/soc/intel/cannonlake/Kconfig b/src/soc/intel/cannonlake/Kconfig index c06b91e..e524275 100644 --- a/src/soc/intel/cannonlake/Kconfig +++ b/src/soc/intel/cannonlake/Kconfig @@ -183,6 +183,11 @@ default 24 if SOC_INTEL_CANNONLAKE_PCH_H default 16
+config MAX_PCIE_CLOCKS + int + default 16 if SOC_INTEL_CANNONLAKE_PCH_H + default 6 + config SMM_TSEG_SIZE hex default 0x800000 diff --git a/src/soc/intel/cannonlake/chip.h b/src/soc/intel/cannonlake/chip.h index b17df4b..f34528a 100644 --- a/src/soc/intel/cannonlake/chip.h +++ b/src/soc/intel/cannonlake/chip.h @@ -168,10 +168,10 @@ /* PCIe output clocks type to Pcie devices. * 0-23: PCH rootport, 0x70: LAN, 0x80: unspecified but in use, * 0xFF: not used */ - uint8_t PcieClkSrcUsage[CONFIG_MAX_ROOT_PORTS]; + uint8_t PcieClkSrcUsage[CONFIG_MAX_PCIE_CLOCKS]; /* PCIe ClkReq-to-ClkSrc mapping, number of clkreq signal assigned to * clksrc. */ - uint8_t PcieClkSrcClkReq[CONFIG_MAX_ROOT_PORTS]; + uint8_t PcieClkSrcClkReq[CONFIG_MAX_PCIE_CLOCKS]; /* PCIe LTR(Latency Tolerance Reporting) mechanism */ uint8_t PcieRpLtrEnable[CONFIG_MAX_ROOT_PORTS]; /* Enable/Disable HotPlug support for Root Port */
John Zhao has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32672 )
Patch Set 1: Code-Review+1
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32672 )
Patch Set 1: Code-Review+2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32672 )
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32672 )
Duncan Laurie has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/32672 )
Signed-off-by: Lijian Zhao lijian.zhao@intel.com Change-Id: I909b5b584c596e6fe878ffe24d9cabc53c4576ed Reviewed-on: https://review.coreboot.org/c/coreboot/+/32672 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: John Zhao john.zhao@intel.com Reviewed-by: Nico Huber nico.h@gmx.de Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/cannonlake/Kconfig M src/soc/intel/cannonlake/chip.h 2 files changed, 7 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved Furquan Shaikh: Looks good to me, approved John Zhao: Looks good to me, but someone else must approve Subrata Banik: Looks good to me, approved
