Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11993
commit f6d89833d4576011a1098bfb8dfd8a13cc6d12fb Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Thu Jun 18 11:48:02 2015 -0500
southbridge/amd/sb700: Add option to disable SATA ALPM
The AMD Register Programming Reference states that the user should have the option to disable Active Link Power Management for two reasons. First, some drives may not function correctly with the ALPM implementation of the SP5100, and second there are some situations where low latency access is more important than the power savings created by using ALPM.
Allow the user to disable ALPM if desired.
Change-Id: I88055cbb4df4d7ba811cef7056c0a6ca2612fcb0 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kgpe-d16/cmos.default | 1 + src/mainboard/asus/kgpe-d16/cmos.layout | 7 ++++--- src/southbridge/amd/sb700/sata.c | 12 ++++++++++++ 3 files changed, 17 insertions(+), 3 deletions(-)
diff --git a/src/mainboard/asus/kgpe-d16/cmos.default b/src/mainboard/asus/kgpe-d16/cmos.default index 3473bc9..9994dad 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.default +++ b/src/mainboard/asus/kgpe-d16/cmos.default @@ -18,6 +18,7 @@ interleave_memory_channels = Enable cpu_c_states = Enable cpu_cc6_state = Enable sata_ahci_mode = Enable +sata_alpm = Disable maximum_p_state_limit = 0xf ieee1394_controller = Enable power_on_after_fail = On diff --git a/src/mainboard/asus/kgpe-d16/cmos.layout b/src/mainboard/asus/kgpe-d16/cmos.layout index 0bc6db8..21765e3 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.layout +++ b/src/mainboard/asus/kgpe-d16/cmos.layout @@ -41,9 +41,10 @@ entries 465 1 e 1 cpu_c_states 466 1 e 1 cpu_cc6_state 467 1 e 1 sata_ahci_mode -468 4 h 0 maximum_p_state_limit -472 2 e 13 dimm_spd_checksum -474 1 r 0 allow_spd_nvram_cache_restore +468 1 e 1 sata_alpm +469 4 h 0 maximum_p_state_limit +473 2 e 13 dimm_spd_checksum +475 1 r 0 allow_spd_nvram_cache_restore 477 1 e 1 ieee1394_controller 728 256 h 0 user_data 984 16 h 0 check_sum diff --git a/src/southbridge/amd/sb700/sata.c b/src/southbridge/amd/sb700/sata.c index fdf32c7..c61fa01 100644 --- a/src/southbridge/amd/sb700/sata.c +++ b/src/southbridge/amd/sb700/sata.c @@ -104,6 +104,7 @@ static void sata_init(struct device *dev) int i, j; uint8_t nvram; uint8_t sata_ahci_mode; + uint8_t sata_alpm_enable; uint8_t port_count; uint8_t max_port_count;
@@ -111,6 +112,10 @@ static void sata_init(struct device *dev) if (get_option(&nvram, "sata_ahci_mode") == CB_SUCCESS) sata_ahci_mode = !!nvram;
+ sata_alpm_enable = 0; + if (get_option(&nvram, "sata_alpm") == CB_SUCCESS) + sata_alpm_enable = !!nvram; + device_t sm_dev; /* SATA SMBus Disable */ sm_dev = dev_find_slot(0, PCI_DEVFN(0x14, 0)); @@ -229,6 +234,13 @@ static void sata_init(struct device *dev) dword &= ~(0x1 << i); write32(sata_bar5 + 0x0c, dword);
+ /* Disable ALPM if ALPM support not requested */ + if (!sata_alpm_enable) { + dword = read32(sata_bar5 + 0xfc); + dword &= ~(0x1 << 11); /* Disable ALPM */ + write32(sata_bar5 + 0xfc, dword); + } + /* Write protect Sub-Class Code */ byte = pci_read_config8(dev, 0x40); byte &= ~(1 << 0);
