Jan Tatje just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14032
commit 683bd27adb57d6e409b1f883756ab64eab6a75bb Author: Jan Tatje jan@jnt.io Date: Fri Mar 11 00:52:07 2016 +0100
util/ifdtool: add option to change chip density
Adds -D / --density option to change the chip density. This is only implemented for IFD version 1 as I do not have an IFD version 2 to test this. Density of both chips is changed, but second value is ignored, if there is no second chip present.
Change-Id: Iba7affbf6cbefa3147b7b0e019298d905e694716 Signed-off-by: Jan Tatje jan@jnt.io --- util/ifdtool/ifdtool.c | 81 ++++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 78 insertions(+), 3 deletions(-)
diff --git a/util/ifdtool/ifdtool.c b/util/ifdtool/ifdtool.c index 8a12725..7fabe61 100644 --- a/util/ifdtool/ifdtool.c +++ b/util/ifdtool/ifdtool.c @@ -748,6 +748,66 @@ static void set_em100_mode(char *filename, char *image, int size) set_spi_frequency(filename, image, size, freq); }
+static void set_chipdensity(char *filename, char *image, int size, int new_density) +{ + fdbar_t *fdb = find_fd(image, size); + fcba_t *fcba = (fcba_t *) (image + (((fdb->flmap0) & 0xff) << 4)); + uint32_t density = 0; + + switch (ifd_version) { + case IFD_VERSION_1: + break; + case IFD_VERSION_2: + /* I do not have a version 2 IFD nor do i have the docs. */ + printf("error: Changing the chip density for IFD version 2 has not been" + " implemented yet.\n"); + exit(EXIT_FAILURE); + default: + printf("error: Unknown IFD version\n"); + exit(EXIT_FAILURE); + break; + } + + printf("setting chip density to "); + switch (new_density) { + case 512: + density = COMPONENT_DENSITY_512KB; + printf("512KB\n"); + break; + case 1: + density = COMPONENT_DENSITY_1MB; + printf("1MB\n"); + break; + case 2: + density = COMPONENT_DENSITY_2MB; + printf("2MB\n"); + break; + case 4: + density = COMPONENT_DENSITY_4MB; + printf("4MB\n"); + break; + case 8: + density = COMPONENT_DENSITY_8MB; + printf("8MB\n"); + break; + case 16: + density = COMPONENT_DENSITY_16MB; + printf("16MB\n"); + break; + default: + printf("unknown density: error\n"); + exit(EXIT_FAILURE); + } + + /* clear lower 6 bit which are chip density */ + fcba->flcomp &= ~(0x3F); + /* set the new density */ + fcba->flcomp |= (density); /* first chip */ + fcba->flcomp |= (density << 3); /* second chip */ + + write_image(filename, image, size); +} + static void lock_descriptor(char *filename, char *image, int size) { int wr_shift, rd_shift; @@ -1075,6 +1135,7 @@ static void print_usage(const char *name) " -i | --inject <region>:<module> inject file <module> into region <region>\n" " -n | --newlayout <filename> update regions using a flashrom layout file\n" " -s | --spifreq <17|20|30|33|48|50> set the SPI frequency\n" + " -D | --density <512|1|2|4|8|16> set chip density (512 in KByte, others in MByte)\n" " -e | --em100 set SPI frequency to 20MHz and disable\n" " Dual Output Fast Read Support\n" " -l | --lock Lock firmware descriptor and ME region\n" @@ -1090,9 +1151,10 @@ int main(int argc, char *argv[]) int opt, option_index = 0; int mode_dump = 0, mode_extract = 0, mode_inject = 0, mode_spifreq = 0; int mode_em100 = 0, mode_locked = 0, mode_unlocked = 0; - int mode_layout = 0, mode_newlayout = 0; + int mode_layout = 0, mode_newlayout = 0, mode_density = 0; char *region_type_string = NULL, *region_fname = NULL, *layout_fname = NULL; int region_type = -1, inputfreq = 0; + int new_density= 0; enum spi_frequency spifreq = SPI_FREQUENCY_20MHZ;
static struct option long_options[] = { @@ -1102,6 +1164,7 @@ int main(int argc, char *argv[]) {"inject", 1, NULL, 'i'}, {"newlayout", 1, NULL, 'n'}, {"spifreq", 1, NULL, 's'}, + {"density", 1, NULL, 'D'}, {"em100", 0, NULL, 'e'}, {"lock", 0, NULL, 'l'}, {"unlock", 0, NULL, 'u'}, @@ -1110,7 +1173,7 @@ int main(int argc, char *argv[]) {0, 0, 0, 0} };
- while ((opt = getopt_long(argc, argv, "df:xi:n:s:eluvh?", + while ((opt = getopt_long(argc, argv, "df:D:xi:n:s:eluvh?", long_options, &option_index)) != EOF) { switch (opt) { case 'd': @@ -1169,6 +1232,15 @@ int main(int argc, char *argv[]) exit(EXIT_FAILURE); } break; + case 'D': + mode_density = 1; + new_density = strtol(optarg, NULL, 0); + if (!new_density) { + fprintf(stderr, "No chip density specified\n"); + print_usage(argv[0]); + exit(EXIT_FAILURE); + } + break; case 's': // Parse the requested SPI frequency inputfreq = strtol(optarg, NULL, 0); @@ -1239,7 +1311,7 @@ int main(int argc, char *argv[])
if ((mode_dump + mode_layout + mode_extract + mode_inject + mode_newlayout + mode_spifreq + mode_em100 + mode_locked + - mode_unlocked) == 0) { + mode_unlocked + mode_density) == 0) { fprintf(stderr, "You need to specify a mode.\n\n"); print_usage(argv[0]); exit(EXIT_FAILURE); @@ -1300,6 +1372,9 @@ int main(int argc, char *argv[]) if (mode_spifreq) set_spi_frequency(filename, image, size, spifreq);
+ if (mode_density) + set_chipdensity(filename, image, size, new_density); + if (mode_em100) set_em100_mode(filename, image, size);
