Chris Wang has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/63132 )
Change subject: mb/google/guybrush/var/dewatt: add specific SPD hex for dewatt ......................................................................
Add the specific SPD hex file for the Samsung memory part with updating the part number into the SPD table. The ABL needs to identify the part by checking SPD data to do the proper tuning.
BUG=b:224884904 TEST=Build, validate the SPD data has been applied.
Signed-off-by: Chris.Wang chris.wang@amd.corp-partner.google.com Change-Id: Ia54726ce8c1bae46dcd4fed3df509ef184914e94 --- A src/mainboard/google/guybrush/variants/dewatt/memory/K4U6E3S4AB-MGCL.hex A src/mainboard/google/guybrush/variants/dewatt/memory/K4UBE3D4AB-MGCL.hex M src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc 3 files changed, 66 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/63132/1
diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/K4U6E3S4AB-MGCL.hex b/src/mainboard/google/guybrush/variants/dewatt/memory/K4U6E3S4AB-MGCL.hex new file mode 100644 index 0000000..639d81f --- /dev/null +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/K4U6E3S4AB-MGCL.hex @@ -0,0 +1,32 @@ +23 11 11 0E 16 21 04 08 00 00 00 00 02 22 00 00 +00 00 04 FF 92 54 05 00 87 00 90 A8 90 C0 08 60 +04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 E5 00 E0 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 4B 34 55 36 45 33 53 +34 41 42 2D 4D 47 43 4C 00 00 00 00 00 00 80 CE +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/K4UBE3D4AB-MGCL.hex b/src/mainboard/google/guybrush/variants/dewatt/memory/K4UBE3D4AB-MGCL.hex new file mode 100644 index 0000000..00b26e6 --- /dev/null +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/K4UBE3D4AB-MGCL.hex @@ -0,0 +1,32 @@ +23 11 11 0E 16 21 94 08 00 00 00 00 0A 22 00 00 +00 00 04 FF 92 54 05 00 87 00 90 A8 90 C0 08 60 +04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 E5 00 E0 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 48 34 55 42 45 33 44 +34 41 42 2D 4D 47 43 4C 00 00 00 00 00 00 80 CE +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc b/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc index c4e409d..547bada 100644 --- a/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc +++ b/src/mainboard/google/guybrush/variants/dewatt/memory/Makefile.inc @@ -13,6 +13,6 @@ SPD_SOURCES += spd/lp4x/set-1/spd-empty.hex # ID = 6(0b0110) SPD_SOURCES += spd/lp4x/set-1/spd-empty.hex # ID = 7(0b0111) SPD_SOURCES += spd/lp4x/set-1/spd-empty.hex # ID = 8(0b1000) -SPD_SOURCES += spd/lp4x/set-1/spd-1.hex # ID = 9(0b1001) Parts = K4U6E3S4AB-MGCL +SPD_SOURCES += $(src)/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/memory/K4U6E3S4AB-MGCL.hex # ID = 9(0b1001) Parts = K4U6E3S4AB-MGCL SPD_SOURCES += spd/lp4x/set-1/spd-empty.hex # ID = 10(0b1010) -SPD_SOURCES += spd/lp4x/set-1/spd-3.hex # ID = 11(0b1011) Parts = K4UBE3D4AB-MGCL +SPD_SOURCES += $(src)/mainboard/$(MAINBOARDDIR)/variants/$(VARIANT_DIR)/memory/K4UBE3D4AB-MGCL.hex # ID = 11(0b1011) Parts = K4UBE3D4AB-MGCL \ No newline at end of file
