Eric Lai has submitted this change. ( https://review.coreboot.org/c/coreboot/+/69680 )
Change subject: soc/intel/meteorlake: Skip setting D0I3 bit for HECI devices ......................................................................
This patch skips setting D0I3 bit for all HECI devices by FSP.
The learning being made from Alder Lake platform showed that the CSE EOP cmd response time is highly nondeterministic and letting the EOP cmd issued by FSP makes the response time even worse.
The idea being pursued during Alder Lake platform is to let FSP skip sending the EOP cmd and coreboot sends it at the last minute (late sending of EOP) to ensure there is ample time for CSE to come to a state where the response to the EOP is almost immediate.
There were a number of refactoring being done to ensure the EOP cmd can be sent at the later stage.
#1: Ensure FSP is not putting those HECI devices into the D0i3. (SoC specific change) #2: Modify the CSE related boot state based operation to allow a proper window for sending late EOP cmd. (Common Code Specific change)
The entire refactoring helps us to save ~60ms of boot time.
Without those code change EOP sending timestamp as below:
943:after sending EOP to ME 1,248,328(61,954))
With those code change EOP sending timestamp as below:
943:after sending EOP to ME 1,231,660 (2,754)
Port of commit d6da4ef69e4e ("soc/intel/alderlake: Skip setting D0I3 bit for HECI devices") to incorporate the #1 which is a SoC specific code change.
BUG=none TEST=FSP-S UPD dump suggested `DisableD0I3SettingForHeci` UPD is set to `1`.
Excerpt from google/rex coreboot log: [SPEW ] DisableD0I3SettingForHeci : 0x1
Signed-off-by: Kapil Porwal kapilporwal@google.com Change-Id: I1c3765ce41f192ab5f5ff176e0a2b49b312d18d2 Reviewed-on: https://review.coreboot.org/c/coreboot/+/69680 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com --- M src/soc/intel/meteorlake/fsp_params.c 1 file changed, 55 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Eric Lai: Looks good to me, but someone else must approve
diff --git a/src/soc/intel/meteorlake/fsp_params.c b/src/soc/intel/meteorlake/fsp_params.c index 2e1820e..9b42b1f 100644 --- a/src/soc/intel/meteorlake/fsp_params.c +++ b/src/soc/intel/meteorlake/fsp_params.c @@ -383,6 +383,9 @@ static void fill_fsps_misc_power_params(FSP_S_CONFIG *s_cfg, const struct soc_intel_meteorlake_config *config) { + /* Skip setting D0I3 bit for all HECI devices */ + s_cfg->DisableD0I3SettingForHeci = 1; + s_cfg->Hwp = 1; s_cfg->Cx = 1; s_cfg->PsOnEnable = 1;
