Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5654
commit f119833cd996fb9a60ed32607989fac34c48406c Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Fri May 2 09:40:04 2014 +0300
AGESA fam12: Add GetHeapBase()
While amd/torpedo does not select HAVE_ACPI_RESUME, backport this from fam14.
Implementation of this function is common across different families.
Change-Id: I0e5099a0991a2655ec2b6990929196900e842fc1 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/mainboard/amd/torpedo/agesawrapper.c | 2 +- .../amd/agesa/family12/fam12_callouts.c | 30 +++++++++++++++++----- .../amd/agesa/family12/fam12_callouts.h | 2 ++ 3 files changed, 26 insertions(+), 8 deletions(-)
diff --git a/src/mainboard/amd/torpedo/agesawrapper.c b/src/mainboard/amd/torpedo/agesawrapper.c index 45b591a..eb4da38 100644 --- a/src/mainboard/amd/torpedo/agesawrapper.c +++ b/src/mainboard/amd/torpedo/agesawrapper.c @@ -391,7 +391,7 @@ agesawrapper_amdinitpost ( AmdReleaseStruct (&AmdParamStruct);
/* Initialize heap space */ - BiosManagerPtr = (BIOS_HEAP_MANAGER *)BIOS_HEAP_START_ADDRESS; + BiosManagerPtr = (BIOS_HEAP_MANAGER *)GetHeapBase(&AmdParamStruct.StdHeader);
HeadPtr = (UINT32 *) ((UINT8 *) BiosManagerPtr + sizeof (BIOS_HEAP_MANAGER)); for (i = 0; i < ((BIOS_HEAP_SIZE/4) - (sizeof (BIOS_HEAP_MANAGER)/4)); i++) diff --git a/src/northbridge/amd/agesa/family12/fam12_callouts.c b/src/northbridge/amd/agesa/family12/fam12_callouts.c index 192c5dd..491f3ce 100644 --- a/src/northbridge/amd/agesa/family12/fam12_callouts.c +++ b/src/northbridge/amd/agesa/family12/fam12_callouts.c @@ -25,7 +25,23 @@ #include "OptionsIds.h" #include "heapManager.h" #include "Hudson-2.h" +#include <cbmem.h> +#include <arch/acpi.h>
+UINT32 GetHeapBase(AMD_CONFIG_PARAMS *StdHeader) +{ + UINT32 heap = BIOS_HEAP_START_ADDRESS; + +#if CONFIG_HAVE_ACPI_RESUME + /* Both romstage and ramstage has this S3 detect. */ + if (acpi_get_sleep_type() == 3) + heap = (UINT32) cbmem_find(CBMEM_ID_RESUME_SCRATCH) + + (CONFIG_HIGH_SCRATCH_MEMORY_SIZE - BIOS_HEAP_SIZE); + /* himem_heap_base + high_stack_size */ +#endif + + return heap; +}
AGESA_STATUS BiosAllocateBuffer (UINT32 Func, UINT32 Data, VOID *ConfigPtr) { @@ -49,8 +65,8 @@ AGESA_STATUS BiosAllocateBuffer (UINT32 Func, UINT32 Data, VOID *ConfigPtr) AllocParams->BufferPointer = NULL;
AvailableHeapSize = BIOS_HEAP_SIZE - sizeof (BIOS_HEAP_MANAGER); - BiosHeapBaseAddr = (UINT8 *) BIOS_HEAP_START_ADDRESS; - BiosHeapBasePtr = (BIOS_HEAP_MANAGER *) BIOS_HEAP_START_ADDRESS; + BiosHeapBaseAddr = (UINT8 *) GetHeapBase(&(AllocParams->StdHeader)); + BiosHeapBasePtr = (BIOS_HEAP_MANAGER *) BiosHeapBaseAddr;
if (BiosHeapBasePtr->StartOfAllocatedNodes == 0) { /* First allocation */ @@ -172,11 +188,11 @@ AGESA_STATUS BiosDeallocateBuffer (UINT32 Func, UINT32 Data, VOID *ConfigPtr) BIOS_HEAP_MANAGER *BiosHeapBasePtr; AGESA_BUFFER_PARAMS *AllocParams;
- BiosHeapBaseAddr = (UINT8 *) BIOS_HEAP_START_ADDRESS; - BiosHeapBasePtr = (BIOS_HEAP_MANAGER *) BIOS_HEAP_START_ADDRESS; - AllocParams = (AGESA_BUFFER_PARAMS *) ConfigPtr;
+ BiosHeapBaseAddr = (UINT8 *) GetHeapBase(&(AllocParams->StdHeader)); + BiosHeapBasePtr = (BIOS_HEAP_MANAGER *) BiosHeapBaseAddr; + /* Find target node to deallocate in list of allocated nodes. Return AGESA_BOUNDS_CHK if the BufferHandle is not found */ @@ -285,8 +301,8 @@ AGESA_STATUS BiosLocateBuffer (UINT32 Func, UINT32 Data, VOID *ConfigPtr)
AllocNodeOffset = BiosHeapBasePtr->StartOfAllocatedNodes; AllocNodePtr = (BIOS_BUFFER_NODE *) (BiosHeapBaseAddr + AllocNodeOffset); diff --git a/src/northbridge/amd/agesa/family12/fam12_callouts.h b/src/northbridge/amd/agesa/family12/fam12_callouts.h index fd08cfe..387ff30 100644 --- a/src/northbridge/amd/agesa/family12/fam12_callouts.h +++ b/src/northbridge/amd/agesa/family12/fam12_callouts.h @@ -38,6 +38,8 @@ typedef struct _BIOS_BUFFER_NODE { UINT32 NextNodeOffset; } BIOS_BUFFER_NODE;
+UINT32 GetHeapBase(AMD_CONFIG_PARAMS *StdHeader); + /* REQUIRED CALLOUTS * AGESA ADVANCED CALLOUTS - CPU */
