Maxim Polyakov has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42919 )
Change subject: mb/supermicro/x11-lga1151: 5/5 Rewrite pad config using intelp2m ......................................................................
Take into account the remapping of reset sources [1] for the Sunrice Point PCH, to fix Reset Config fields (bit 31:30) in the corresponding macros. The intelp2m utility does this remapping automatically, but these changes in a separate patch to pay attention to them.
[1] src/soc/intel/skylake/gpio.c#n9
Change-Id: I388d39ca8314de60610588223d024e1bb1681264 Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/mainboard/supermicro/x11-lga1151-series/variants/x11ssh-tf/include/variant/gpio.h M src/mainboard/supermicro/x11-lga1151-series/variants/x11ssm-f/include/variant/gpio.h 2 files changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/42919/1
diff --git a/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssh-tf/include/variant/gpio.h b/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssh-tf/include/variant/gpio.h index d005d8b..114095a 100644 --- a/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssh-tf/include/variant/gpio.h +++ b/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssh-tf/include/variant/gpio.h @@ -284,7 +284,7 @@ PAD_CFG_GPO(GPP_D21, 0, DEEP),
/* GPP_D22 - GPIO */ - PAD_CFG_GPI_TRIG_OWN(GPP_D22, NONE, PWROK, OFF, ACPI), + PAD_CFG_GPI_TRIG_OWN(GPP_D22, NONE, RSMRST, OFF, ACPI),
/* GPP_D23 - GPIO */ PAD_NC(GPP_D23, NONE), @@ -398,7 +398,7 @@ PAD_NC(GPP_F22, NONE),
/* GPP_F23 - GPIO */ - PAD_CFG_GPO(GPP_F23, 0, PWROK), + PAD_CFG_GPO(GPP_F23, 0, RSMRST),
/* GPP_G0 - GPIO */ PAD_CFG_GPI_TRIG_OWN(GPP_G0, NONE, DEEP, OFF, ACPI), diff --git a/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssm-f/include/variant/gpio.h b/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssm-f/include/variant/gpio.h index 4f16424..df13a21 100644 --- a/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssm-f/include/variant/gpio.h +++ b/src/mainboard/supermicro/x11-lga1151-series/variants/x11ssm-f/include/variant/gpio.h @@ -298,7 +298,7 @@ PAD_CFG_GPO_GPIO_DRIVER(GPP_D21, 0, DEEP, NONE),
/* GPP_D22 - GPIO */ - PAD_CFG_GPI_TRIG_OWN(GPP_D22, NONE, PWROK, OFF, DRIVER), + PAD_CFG_GPI_TRIG_OWN(GPP_D22, NONE, RSMRST, OFF, DRIVER),
/* GPP_D23 - GPIO */ PAD_NC(GPP_D23, NONE), @@ -416,7 +416,7 @@ PAD_NC(GPP_F22, NONE),
/* GPP_F23 - GPIO */ - PAD_CFG_GPO_GPIO_DRIVER(GPP_F23, 0, PWROK, NONE), + PAD_CFG_GPO_GPIO_DRIVER(GPP_F23, 0, RSMRST, NONE),
/* GPIO Group GPP_G */
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Patch Set 3:
(3 comments)
https://review.coreboot.org/c/coreboot/+/42919/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/42919/3//COMMIT_MSG@7 PS3, Line 7: mb/supermicro/x11-lga1151: 5/5 Rewrite pad config using intelp2m Use a more descriptive commit message for the actual change?
https://review.coreboot.org/c/coreboot/+/42919/3//COMMIT_MSG@9 PS3, Line 9: Sunrice Sunri*s*e?
https://review.coreboot.org/c/coreboot/+/42919/3//COMMIT_MSG@11 PS3, Line 11: but : these changes in a separate patch to pay attention to them.
but put these changes
but make these changes
Hello build bot (Jenkins),
Change subject: supermicro/x11-lga1151/gpio: 5/5 Remap reset sources ......................................................................
Take into account the remapping of reset sources [1] for the Sunrise Point PCH, to fix Reset Config fields (bit 31:30) in the corresponding macros. The intelp2m utility does this remapping automatically, but make these changes in a separate patch to pay attention to them.
This is part of the patch set "mb/supermicro/x11-lga1151: Rewrite pad config using intelp2m":
CB:42916 - 1/5 Decode raw register values CB:42917 - 2/5 Exclude fields for PAD_CFG CB:42918 - 3/5 Fixes some field macro CB:35679 - 3/4 Convert field macros to PAD_CFG CB:42919 - 5/5 Remap reset sources
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/42919/4
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/42919/5
Maxim Polyakov has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Patch Set 5:
(3 comments)
May be "5/5 Remap reset sources"?
Sunri*s*e?
Done
but put these changes […]
Done
Maxim Polyakov has removed Paul Menzel from this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Removed reviewer Paul Menzel.
Hello build bot (Jenkins), Matt DeVillier, Benjamin Doron, Paul Menzel, Christian Walter, Angel Pons, Michael Niewöhner, Patrick Rudolph,
Change subject: [RFC] supermicro/x11-lga1151/gpio: 5/5 Remap reset sources ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/42919/6
Matt DeVillier has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Patch Set 6:
so what exactly is the net effect of this patchset? In the process of converting from the raw dataword values to macros, you've obviously changed quite a bit in the way coreboot sets these GPIOs, in terms of values/features set.
Is there a reason to make these changes, other than the macros providing a clearer indication of how the GPIO is set/used? If not, do the changes affect how the GPIOs function? If yes, how?
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Patch Set 6:
Patch Set 6:
No, it should and shall not change the way they function but just convert the ugly raw values to human-readable macros.
Patch Set 6:
Patch Set 6:
so the output from `inteltool -g` is identical before/after the patchset?
Patch Set 6:
Patch Set 6:
Patch Set 6:
No, the dump of the DW0 and DW1 registers is different before and after the patches. To convert raw values to macros, we should ignore some bit fields. For example, RX/TX Buf Disable DW0[9:8] doesn't affect the pad in native function mode (intel doc #549921) and the PAD_CFG_NF macros don't take them into account (the value is set to 0). I change the values of the DW registers in separate patches:
Thus, it is easier to find a mistake or do revert to a patch in order to repeat the testing. This is @Angel’s idea (This helped me fix some bugs in the utility. Good idea, thanks).
Similarly done for up board (Apollo Lake):
CB:42608 - 1/3 Decode raw register values CB:42915 - 2/3 Exclude fields that are not in PAD_CFG* CB:39765 - 3/3 Converts bit field macros to PAD_CFG
___
The last 5/5 patch isn't correct, as the reset source remapping is already applied in the configuration with raw values DW0 and DW1.
Patch Set 6:
Patch Set 6:
Patch Set 6:
Patch Set 6:
Well, yes, the raw values differ but that does not change "the way they [the GPIOs] function", which is exactly the reaso *why* those bits can be ignored :-)
Maxim Polyakov has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/42919 )
Abandoned
This patch isn't correct, as the reset source remapping is already applied in the configuration with raw values DW0 and DW1 (commit 71b1ed8f7)
