Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/63094 )
Change subject: mb/google/skyrim: Implement mb_set_up_early_espi ......................................................................
This will setup the eSPI GPIOs in bootblock right before eSPI init.
BUG=b:226635441 TEST=build skyrim
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I6ff32bf840aa4b757e98d876cbd4e2ba15a760da Reviewed-on: https://review.coreboot.org/c/coreboot/+/63094 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/mainboard/google/skyrim/bootblock.c M src/mainboard/google/skyrim/variants/baseboard/gpio.c M src/mainboard/google/skyrim/variants/baseboard/include/baseboard/variants.h 3 files changed, 36 insertions(+), 0 deletions(-)
diff --git a/src/mainboard/google/skyrim/bootblock.c b/src/mainboard/google/skyrim/bootblock.c index 5a1c4da..c332aed 100644 --- a/src/mainboard/google/skyrim/bootblock.c +++ b/src/mainboard/google/skyrim/bootblock.c @@ -1,8 +1,18 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+#include <amdblocks/espi.h> #include <bootblock_common.h> #include <baseboard/variants.h>
+void mb_set_up_early_espi(void) +{ + size_t num_gpios; + const struct soc_amd_gpio *gpios; + + variant_espi_gpio_table(&gpios, &num_gpios); + gpio_configure_pads(gpios, num_gpios); +} + void bootblock_mainboard_early_init(void) { size_t num_gpios, override_num_gpios; diff --git a/src/mainboard/google/skyrim/variants/baseboard/gpio.c b/src/mainboard/google/skyrim/variants/baseboard/gpio.c index fd85b99..a262347 100644 --- a/src/mainboard/google/skyrim/variants/baseboard/gpio.c +++ b/src/mainboard/google/skyrim/variants/baseboard/gpio.c @@ -141,6 +141,23 @@ PAD_NF(GPIO_148, I2C1_SDA, PULL_NONE), };
+static const struct soc_amd_gpio espi_gpio_table[] = { + /* ESPI_CS_L */ + PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), + /* ESPI_CLK */ + PAD_NF(GPIO_77, SPI1_CLK, PULL_NONE), + /* ESPI1_DATA0 */ + PAD_NF(GPIO_81, SPI1_DAT0, PULL_NONE), + /* ESPI1_DATA1 */ + PAD_NF(GPIO_80, SPI1_DAT1, PULL_NONE), + /* ESPI1_DATA2 */ + PAD_NF(GPIO_68, SPI1_DAT2, PULL_NONE), + /* ESPI1_DATA3 */ + PAD_NF(GPIO_69, SPI1_DAT3, PULL_NONE), + /* ESPI_ALERT_L */ + PAD_NF(GPIO_22, ESPI_ALERT_D1, PULL_NONE), +}; + static const struct soc_amd_gpio tpm_gpio_table[] = { /* I2C3_SCL */ PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), @@ -222,6 +239,12 @@ *gpio = sleep_gpio_table; }
+__weak void variant_espi_gpio_table(const struct soc_amd_gpio **gpio, size_t *size) +{ + *size = ARRAY_SIZE(espi_gpio_table); + *gpio = espi_gpio_table; +} + __weak void variant_tpm_gpio_table(const struct soc_amd_gpio **gpio, size_t *size) { *size = ARRAY_SIZE(tpm_gpio_table); diff --git a/src/mainboard/google/skyrim/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/skyrim/variants/baseboard/include/baseboard/variants.h index 64a414b..7289e10 100644 --- a/src/mainboard/google/skyrim/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/skyrim/variants/baseboard/include/baseboard/variants.h @@ -37,6 +37,9 @@ /* This function provides GPIO settings before entering sleep. */ void variant_sleep_gpio_table(const struct soc_amd_gpio **gpio, size_t *size);
+/* This function provides GPIO settings for eSPI bus. */ +void variant_espi_gpio_table(const struct soc_amd_gpio **gpio, size_t *size); + /* This function provides GPIO settings for TPM i2c bus. */ void variant_tpm_gpio_table(const struct soc_amd_gpio **gpio, size_t *size);
